Toymods » Tech & Conversions » MX83 Brakes
DigitalAE86
icon5.gif  MX83 Brakes Wed, 30 June 2004 09:57 Go to next message
I've picked up a set of front brake rotors (that can't be returned) for my 89 MX83 only to find out that the models between '88-'90 and '90-'92 have different size rotors.
By different size I mean that the thickness of '88-'89 is 20mm and the '90-'92 is 22mm.
My question is therefore two fold:
Will the 22mm rotors fit on my car?
And if they won't, would there be any benefit in sourcing the '90-'92 model calipers and replacing mine (assuming that is possible without needing to modify anything)?
Failing all of the above I'll have a brand new set of rotors up for sale soon.
Thanks for any help that you can provide.
Brad
M.J.H
Re: MX83 Brakes Wed, 30 June 2004 10:06 Go to previous messageGo to next message
Providing that the bearings and hub seal are the same and they don't sit out or in from where the original ones are then yes you should be able to use them with your calipers.
You may have enogh clearance to get the pads to fit but if not then you can get some materail taken off the pads or better yet get the dics machined down a bit but not to far and all should be well.
Thats what i would do anyway.
IRA11Y
Club Member
Re: MX83 Brakes Wed, 30 June 2004 10:11 Go to previous messageGo to next message
take a pic of the discs and give me all the dimensions, if they suit my application i might buy them from you.
DigitalAE86
Re: MX83 Brakes Wed, 30 June 2004 13:13 Go to previous messageGo to next message
The details are as follows. Sorry, but I don't have a camera
Vented
Diameter: 256 mm
Orig. Height: 68 mm
Orig. Thickness: 22 mm
Min. Thickness: 21 mm
Centre Hole: 60 mm
Num. Bolt Holes: 5
Weight: 6 kg
IRA11Y
Club Member
Re: MX83 Brakes Wed, 30 June 2004 21:04 Go to previous messageGo to next message
ok ill measure what ive got here and see if its a match.
Re: MX83 Brakes Wed, 30 June 2004 23:02 Go to previous messageGo to next message
If you're changing your brakes, why not change to something decent? Stock MX83 brakes are pissweak!
I'm doing a brake upgrade on my Supra using MX83 struts, BA Falcon rotors and R33 Skyline 4-piston alloy calipers. It all bolts right up and it will be a massive improvement over stock MX83 brakes.
DigitalAE86
Re: MX83 Brakes Wed, 30 June 2004 23:25 Go to previous messageGo to next message
The brake upgrade sounds good, but unless I can buy the package already done, I'm stuffed. I have no skills in that area.
What sort of money wound we be talking about? I seem to remember reading that even the brake pads for that set up are hugely expensive.
Re: MX83 Brakes Thu, 01 July 2004 01:50 Go to previous messageGo to next message
The brake upgrade I'm talking about here is no more difficult than what you're doing already; it's just a matter of bolting on discs and calipers.
As for pads, I haven't priced them yet but all you need is R32/R33 Skyline or Z32 300ZX pads, and I can't see why they'd be hugely expensive compared to other cars?
DigitalAE86
Re: MX83 Brakes Thu, 01 July 2004 02:24 Go to previous messageGo to next message
Sorry Norbie, must have been the calipers that I read where expensive. I just priced a pair of '91 MX83 calipers at $60.00 each, so I think that will be the way I go (seeing that I've already got the rotors and don't really have a budget for anything more).
www.discpads.com.au have good prices on pads and rotors.
joecoolmk2
Re: MX83 Brakes Thu, 01 July 2004 02:29 Go to previous messageGo to next message
can you make that setup fit on an mx22?! it has a different setup(double wishbone, not struts), but tey might be similar hey?
Re: MX83 Brakes Thu, 01 July 2004 03:25 Go to previous messageGo to next message
No.
M.J.H
Re: MX83 Brakes Thu, 01 July 2004 12:11 Go to previous messageGo to next message
Norbie wrote on Thu, 01 July 2004 09:02
start highjack
Are you upgrading the rears as well or just the fronts?
If so what is the plan for the rears?
end highjack
bbaacchhyy
Re: MX83 Brakes Thu, 01 July 2004 12:42 Go to previous messageGo to next message
M.J.H wrote on Thu, 01 July 2004 22:11
start highjack
end highjack
He is leaving his stock at the moment (they are pretty good with vented discs athat are about 260mm dia.
I just upgraded the rears on mine to W140 Merc rears (300mm dia x 22mm thic vented) to go with the upgraded fronts - Scubie WRX STi 326mm dia x 30mm thick.
Michael B
Re: MX83 Brakes Thu, 01 July 2004 23:23 Go to previous messageGo to next message
What he said. I'll upgrade the rears only if they prove to be inadequate, which frankly is unlikely to happen unless I circuit race it on a regular basis.
bbaacchhyy
Re: MX83 Brakes Thu, 01 July 2004 23:47 Go to previous messageGo to next message
Norbie wrote on Fri, 02 July 2004 09:23
I am to do a bit of cct work at Mallala which is VERY hard on brakes.
Besides Norbs, those PINK wipers will help the braking as well hehehe
Re: MX83 Brakes Fri, 02 July 2004 00:18 Go to previous messageGo to next message
You're just jealous, like everyone else. Razz
bbaacchhyy
Re: MX83 Brakes Fri, 02 July 2004 01:07 Go to previous messageGo to next message
Norbie wrote on Fri, 02 July 2004 10:18
Not really, 'cos I'm gonna paint mine Flouro Green - they make it go faster Up To Something
M.J.H
Re: MX83 Brakes Fri, 02 July 2004 06:31 Go to previous messageGo to next message
bbaacchhyy wrote on Fri, 02 July 2004 11:07
But everyone knows that red is the fastest color. Laughing
Thanks for the info guys.Really helpful for the next clubman project. Twisted Evil
BrianW
Perth, Australia
Re: MX83 Brakes Sun, 11 July 2004 15:14 Go to previous messageGo to next message
I have a MX83 89' with a 1JZGTE and want it to feel better when it needs to stop.
For the upgrade using the R33 calipers and BA rotors- is that using the standard 298mm or the 325mm rotors from the XR8?
Do the R33 calipers bolt on using the standard holes on the MX83 struts?
b
Re: MX83 Brakes Sun, 11 July 2004 23:55 Go to previous message
That's using the 298mm rotors, and yes you use the standard holes in the struts.
Previous Topic:3tgte ecu
Next Topic:Whats the difference between AE86 gtv and gt-apex?
Current Time: Sun Nov 1 16:10:10 UTC 2026
Total time taken to generate the page: 0.0056400299072266 seconds
