Toymods » Tech & Conversions » 4agte
4agteseca
central coast.NSW
4agte Wed, 30 June 2004 10:01 Go to next message
hi all,
i have a 4agze,converted to turbo...its running via a microtech mtx8...
it has been running fine up untill last month wen i was just driving and it kicked my computer out of memcal(memory) 1.
now wen i drive,just when accelerating just before reaching boost it cuts the engine off,it isnt the rpm cut out or boost cut...and it isnt a faukt within the computer or map sensor,ive had it all checked already...what im wondering is...could the crank angle sensor cause this or the tps ?
please get back to me if you know or have an idea,
cheers...
dave
old_mr2
Re: 4agte Mon, 05 July 2004 09:26 Go to previous messageGo to next message
feral4mr2 or pulcino may be able to help
they're GTE owners
feral4mr2
Bundaberg, Qld.
Re: 4agte Mon, 05 July 2004 12:20 Go to previous messageGo to next message
i dont have a microtech, so know nothing of how it works.
but i would think that if the car runs bad after the microtech lost it's memory and nothing else was changed then i would be pointing at it.
10sec_rx7
Syndey
Re: 4agte Tue, 06 July 2004 04:38 Go to previous messageGo to next message
the only way it will loose its memory is if someone plays with the handset and laods the other memcal,
i have never heard or seen a case where the ecu has just lost its memory,
pulcino
Mackay QLD
Re: 4agte Fri, 09 July 2004 08:45 Go to previous messageGo to next message
it may be getting a lean signal from the o2 sensor which will shut down the fun. I wanna know if it has no map how does it run?
NVD05X
parra
Re: 4agte Fri, 09 July 2004 10:08 Go to previous messageGo to next message
as far as i know the microtech doesnt use a o2 sensor...
only water temp, inlet air temp, map sensor, engine speed (dizzy or cas)and tps...
YelloRolla
On your mum!
Re: 4agte Fri, 09 July 2004 22:13 Go to previous messageGo to next message
sounds like it may be related to MAP sensor. Does the Microtech have any switching for different boost applications (for better tuning resolution)?
10secRX7 will be the one to know the answer to this.
4agteseca
central coast.NSW
Re: 4agte Fri, 09 July 2004 23:32 Go to previous messageGo to next message
thanks for the replies guys,the computer is at microtech now and i am checking all the wiring...
thanks again Smile
dave
10sec_rx7
Syndey
Re: 4agte Sat, 10 July 2004 12:10 Go to previous message
i have heard of one case where water got into the map sensor and caused problems like this, 90% of the other problems similer to this are caused by tuning, if it is too rich/lean it will cut out like your saying
Dale
Previous Topic:Swaybar link to be made adjustable... any ideas?
Next Topic:MIGHTY 4AC
Current Time: Wed Nov 18 21:04:18 UTC 2026
Total time taken to generate the page: 0.0057070255279541 seconds
