Toymods » Tech & Conversions » Hitching and stuttering 4AC
Azrael
Crapberra
Hitching and stuttering 4AC Thu, 01 July 2004 04:50 Go to next message
I'm looking for any clues as to why the Corolla is hitching and stuttering, It's only happening when the car is first started (and warmed for a few minutes) then driven down the road. It's been serviced (two weeks ago) by a fairly well trusted mechanic and he reackons the auto choke is fine. It does seem to go fine when the engine is at running temp.
Any clues?
thanks in advance
Az
Super Jamie
On Probation
North East NSW
Re: Hitching and stuttering 4AC Thu, 01 July 2004 05:40 Go to previous messageGo to next message
it's getting old? Smile does hitching mean bunny hopping and surging? possibly could be running lean like it's got a vacuum leak somewhere? or if it stumbles but builds power perhaps its running rich and your mechanic friend has played with the idle mixture? has the timing been set correctly for the fuel it's running? have a look at the autochoke yourself if you doubt it's working, it should be closed when the coolant is cold, open when it warms up (or do they have electric choke? i don't know)
Azrael
Crapberra
Re: Hitching and stuttering 4AC Thu, 01 July 2004 06:17 Go to previous messageGo to next message
Thanks Super Jamie - by Hitching its a stuttering and reluctance to move more than a bunny hop.
The mechanic did play with the timing but I have faith that he did it well as it was even crappier before he fixed it (due to a dodgey mechanic previously stuffing around and trying to create business for himself). It did have a problem with an air leak in the fuel line above the charcoal canister that was causing the petrol to drain back to the fuel tank, so there is a good possibility a vacumn leak could be elsewhere also.
I am still curious though as wouldn't these problems still be affecting the engine after it has been warmed? Cause it runs fine after it reached running temp...?
ps. How do you check the auto choke?
[Updated on: Thu, 01 July 2004 06:20]
Super Jamie
On Probation
North East NSW
Re: Hitching and stuttering 4AC Thu, 01 July 2004 11:47 Go to previous messageGo to next message
things warm up and expand and close miniscule clearances. not totally unheard of. just giving you ideas of things to check Smile maybe the motor has excessive piston-to-bore clearance and just wants to warm up more before you use it. perhaps the idle is running too rich or lean
without being there or knowing an awful lot about 4ACs (these are just general troubleshooting tips) it's difficult to troubleshoot just on description. good luck!
Ko Ko
Re: Hitching and stuttering 4AC Thu, 01 July 2004 22:31 Go to previous message
Maybe the carby is cloged up try cleaning out the carby too.
Previous Topic:5m-7m flywheel, and bellhousing
Next Topic:New here - 88 rolla questions!
Current Time: Sat Nov 21 16:30:52 UTC 2026
Total time taken to generate the page: 0.004378080368042 seconds
