Toymods » Tech & Conversions » ma61 rear into a ta23
HYPA-NOVA
Brisbane QLD
ma61 rear into a ta23 Thu, 01 July 2004 08:26 Go to next message
how much work and what sort of modifications would I need to fit a ma61 rear (lsd, axel & brakes) into a TA23??
Re: ma61 rear into a ta23 Thu, 01 July 2004 09:18 Go to previous messageGo to next message
A hell of a lot more than it's worth. An MA61 is IRS, so you'd have to modify a shiteload. You'd be better to find an F-series live-axle diff from a Crown(?) or something, and then fit an MA61 LSD centre to it.
As for the specifics of a live-axle F-series diff, a search would find it fairly easily.
V8_MA61
Re: ma61 rear into a ta23 Thu, 01 July 2004 09:22 Go to previous messageGo to next message
Yeah im here to piss off my sale..but anyway
Talk to COOL1 on these forums...id put a hilux live axle diff in it. Strong as all hell...MANY ratios available also.
Blake
Re: ma61 rear into a ta23 Thu, 01 July 2004 11:21 Go to previous messageGo to next message
I put a corona MKII live axle rear end in my RA28, these share the same centres as MA61's so you can use the LSD from one of these.
IRS would be unreal but a huge job and with something like that no corners can be cut.
Re: ma61 rear into a ta23 Thu, 01 July 2004 23:32 Go to previous messageGo to next message
What he said; an F series live axle (eg Corona MkII) is the way to go if you want a stronger diff. A Hilux diff is another option but it's heavier, it has the wrong stud pattern, and it's almost certainly overkill for your application.
Re: ma61 rear into a ta23 Thu, 01 July 2004 23:43 Go to previous messageGo to next message
Everytime you dismember a Corona Mk2, God kills a kitten.
Use a Crown MS112 diff. F series, same width, bigger axles and bearings, disc brakes and common as dirt.
Re: ma61 rear into a ta23 Fri, 02 July 2004 00:16 Go to previous messageGo to next message
There are plenty of already-dismembered MkII's out there willing to donate diffs! The big advantage with the MkII diff is it has the correct 4x4.5" stud pattern for a Celica, while the Crown diff will have a 5-stud pattern.
Re: ma61 rear into a ta23 Fri, 02 July 2004 00:22 Go to previous messageGo to next message
MS112 diff is more like 1440mm wide, the MKII is 1410 or so? Thats my understanding anyway.
Re: ma61 rear into a ta23 Fri, 02 July 2004 00:29 Go to previous messageGo to next message
Not in this neck of the woods. Leave the hard to find old school stuff alone for the genuine old schoolers.
There are plenty of MS112s. Initial purchase price is the same. The cost to get either modified to fit in a Celica is the same. It might cost another $50 to get it restudded to a 4 stud.
There are 2 pluses:
  1. MS112 comes with disc brakes (and if the brakes aren't big enough, I have outlined a multitude of upgrades in multiple posts), and
  2. MS112 diff is a better diff (bigger axles and double row axle bearings).
RA28, they are the same width (roughly 1410mm as measured with a tape measure). I put an MS112 diff in my MX13.
[Updated on: Fri, 02 July 2004 00:30]
CLG
Perth, Western Australia
Re: ma61 rear into a ta23 Fri, 02 July 2004 01:25 Go to previous messageGo to next message
gianttomato wrote on Fri, 02 July 2004 07:43
Hehehehehehe! RA28 is 1365mm from drum to drum, RN25/27 Hilux is 1370mm drum to drum, all the live axle F series diffs are larger than that.
joecoolmk2
Re: ma61 rear into a ta23 Fri, 02 July 2004 01:46 Go to previous messageGo to next message
gianttomato is da' man! you make much funny, ha ha ha Laughing i have a corona mark 2 diff, but you's can't have it. if you want one, i can get one from the wreckers here in tassie, there's like three last time i checked.
ViPeR_NiPPleX
VIC, Sth Frankston.
Re: ma61 rear into a ta23 Fri, 02 July 2004 02:28 Go to previous messageGo to next message
If you were going to install IRS on the ta23, i wouldnt bother with the suspension setup the ma61 has. I'd rather go with something much more adjustable. Semi trailing arms can be a pain.
gold28
Madrid - Spain
Re: ma61 rear into a ta23 Fri, 02 July 2004 03:27 Go to previous messageGo to next message
Agreed, the MA61 setup is OK for a standard road car, but is too wide for an early celica and would require heaps of work to get it in. Better to go for a custom job and use silvia gear. Fabricate a cradle, make it structural and hang some fabricated upper and lower wishbones off it.
Cyber-punk
Brisbane, QLD
Re: ma61 rear into a ta23 Fri, 02 July 2004 08:13 Go to previous messageGo to next message
joecoolmk2 wrote on Fri, 02 July 2004 11:46
whats the bet GT is now planning a road trip to tassie? Evil or Very Mad
HYPA-NOVA
Brisbane QLD
Re: ma61 rear into a ta23 Fri, 02 July 2004 11:49 Go to previous messageGo to next message
ok.... so how much and where can I get either a hilux, crown or corona LSD diff with disk brakes?
Re: ma61 rear into a ta23 Sat, 03 July 2004 13:37 Go to previous message
If you really must have disc brakes, only the Crown diff comes with them from the factory, although the others can be converted to disc with a bit of work (search if you want details). As for where and how much, pick up the phone and ask your local wrecking yards!
Previous Topic:how strong is it?
Next Topic:Wheels studs for AE93 Corolla
Current Time: Thu Oct 29 06:28:49 UTC 2026
Total time taken to generate the page: 0.05520486831665 seconds
