Toymods » Tech & Conversions » What happens with no Oxy sensor
adamb131
What happens with no Oxy sensor Fri, 02 July 2004 01:25 Go to next message
Can I drive my car without the oxy sensor hooked up?
What will happen?
adamb131
Re: What happens with no Oxy sensor Fri, 02 July 2004 01:31 Go to previous messageGo to next message
More info:
Custom extractors off a 4ag with carbs... I want to use them on my car but they have no oxy sensor inlet.
Can I fit them and drive the car (without the oxy sensor) to a guy who is gonna place an fitting into my engine pipe.
Will the car go or will it cause any damage...
Oh they are going on a early GZE.
Aust162
Melb, Victoria
Re: What happens with no Oxy sensor Fri, 02 July 2004 01:38 Go to previous messageGo to next message
u can drive it without O2 sensor but it stuffs up ur mixtures and u get real bad fuel economy.
joecoolmk2
Re: What happens with no Oxy sensor Fri, 02 July 2004 01:40 Go to previous messageGo to next message
the oxy sensor tells the ecu what air/fuel mixture the engine needs, if it isn't there, it won't work properly or not at all. either way, refit an oxy sensor, it needs to be in a location where it gets exhaust from all cylinders.
ed_ma61
Lost in the K hole
the people in the car behind you will have tears in their eyes at the lights...
adamb131
Re: What happens with no Oxy sensor Fri, 02 July 2004 01:43 Go to previous messageGo to next message
ed_ma61 wrote on Fri, 02 July 2004 11:40
Is that from laughter or breathing my tasty emmisions or both???
ed_ma61
Lost in the K hole
Re: What happens with no Oxy sensor Fri, 02 July 2004 01:45 Go to previous messageGo to next message
rich as shit exhaust Nod
adamb131
Re: What happens with no Oxy sensor Fri, 02 July 2004 01:47 Go to previous messageGo to next message
Thanks... I just gotta drive it about 12k's to my mates workshop. Was just worried about breaking down or wrecking something along the way.
Re: What happens with no Oxy sensor Fri, 02 July 2004 04:05 Go to previous messageGo to next message
It won't cause any problems apart from worse than average fuel economy. And I doubt it will run "rich as shit", ie black smoke from the exhaust, since the ECU only trims the mixtures by a few % in closed-loop mode.
Chris Davey
sunny coast, qld
Re: What happens with no Oxy sensor Fri, 02 July 2004 04:34 Go to previous messageGo to next message
i drove my car with no 02 sensor for a little while because the mechanic was too lazy to refit it Rolling Eyes
it wasn't THAT rich, bit of smoke but not that much and not all the time either.
anyway, should be alright Smile
hemi twofifteen turbo
Re: What happens with no Oxy sensor Fri, 02 July 2004 16:50 Go to previous messageGo to next message
dam... if oxy sensors were so good as knowing a/f ratio's that the car wouldn't run w/o it then why bother with airflow sensors?!?
If it's a 3 or 4 wire type you can put it lower down, if it's a single wire type you need it as close to the engine as possible.
Why not put it on the extractors and not on your pipe?
Re: What happens with no Oxy sensor Sat, 03 July 2004 00:08 Go to previous messageGo to next message
hemi twofifteen turbo wrote on Sat, 03 July 2004 02:50
'cause (without a map sensor) there's no way the ECU will know what the engine is doing (apart from rpm from the dizzi and throttle position). Different air flows require differing ingition and injection timings.
tho... with ion sensing ignition (it checks result of each ignition/burn event via the spark plug) the ECU could do an even better job of tuning the fuel use and ignition timing during cruise.
V8_MA61
Re: What happens with no Oxy sensor Sat, 03 July 2004 07:46 Go to previous messageGo to next message
lol ask me about faulty o2 sensors! I have two of em Wink
Getting 400km highway driving / tank of fuel isnt very good for a 7mge!
I need to do a diagnosis on mine to make sure thats definetly the problem
Re: What happens with no Oxy sensor Sat, 03 July 2004 13:20 Go to previous messageGo to next message
Narrow-band O2 sensors are only used under low-load, cruise conditions because (a) they're only good for keeping the mixtures at stoich (not what you want at WOT) and (b) they don't respond quickly enough to transient conditions.
Re: What happens with no Oxy sensor Sat, 03 July 2004 14:11 Go to previous messageGo to next message
V8_MA61 wrote on Sat, 03 July 2004 17:46
blake, to get codes from ECU:
-open <www.cygnusx1.net/supra/library/TSRM/fi/FI_001. html>
-click on "Diagnosis System"
-print pages Fi-23 to FI-29
-go out to car with pages and follow instructions
you car only has one O2 sensor? did you get a spare that was a dud? ;-(
how many wires on back ofth O2 sensor?
SIMDOG
Bayside Melbourne.
Re: What happens with no Oxy sensor Sat, 03 July 2004 16:52 Go to previous messageGo to next message
thechuckster wrote on Sun, 04 July 2004 00:11
I replaced mine on my 7MGE and it was a dud. I then fitted an aftermarket one and adapted the plug to fit. There is only one wire on these O2 sensors.
WiLo
wollongong NSW
Re: What happens with no Oxy sensor Mon, 05 July 2004 10:57 Go to previous messageGo to next message
nothin bad just like everyone says just runs rich but i wouldnt suggest driving for long distances cos i was following a mate that just did a gze conversion that didnt have to O2 sensor in yet and the cat was glowing bright red
actually that was the time when it was running without the O2 and only on 2 cylinders because the coil had exploded or something
Re: What happens with no Oxy sensor Mon, 05 July 2004 23:09 Go to previous messageGo to next message
Um, I think you'll find it was the running on 2 cylinders part that caused the glowing cat, not the missing O2 sensor. With no O2 sensor the ECU will just run in open-loop mode, which is what it does when you crack the throttle open anyway. In other words it will run richer but not stupidly rich.
celicamad
newcastle
Re: What happens with no Oxy sensor Tue, 06 July 2004 12:32 Go to previous messageGo to next message
Norbie is dead right in fact we have done a full a/f ratio test and comparison on two almost identical engine setups and the variation in the mixtures was almost undetectable .
Yes it ran SLIGHTLY richer with no o2 sensor but the differnce was so slight it was barley worth even getting the plate for the 02 sensor cut for my twin dumps.
i stll dont run one and fuel economy is about the same as 1js with 02 sensor
[Updated on: Tue, 06 July 2004 12:32]
V8_MA61
Re: What happens with no Oxy sensor Tue, 06 July 2004 12:46 Go to previous messageGo to next message
SIMDOG wrote on Sun, 04 July 2004 02:52
How much did your afdtermarket o2 sensor cost?
ZZT231
melbourne.vic.au
Re: What happens with no Oxy sensor Tue, 06 July 2004 13:05 Go to previous messageGo to next message
Drive a 5M-E. And watch fuel economy Sad
Re: What happens with no Oxy sensor Tue, 06 July 2004 13:11 Go to previous messageGo to next message
ZZT231 wrote on Tue, 06 July 2004 23:05
Drive a 5M-E. And watch fuel economy :
isn't that an oxymoron like "army inteligence" and "fresh frozen"?
Laughing Laughing Laughing
ed_ma61
Lost in the K hole
Re: What happens with no Oxy sensor Tue, 06 July 2004 13:29 Go to previous message
Norbie wrote on Fri, 02 July 2004 14:05
ask rob about the last time he drove behind me from a toymods meeting Rolling Eyes
Previous Topic:XT130 bolt on AE86?
Next Topic:corona/pug/hilux convo for a different car
Current Time: Mon Oct 26 20:22:26 UTC 2026
Total time taken to generate the page: 0.05706000328064 seconds
