Toymods » Tech & Conversions » manifolds on 5m's
joecoolmk2
manifolds on 5m's Fri, 02 July 2004 01:34 Go to next message
are 5M-E inlet manifolds the same as 5M-GE? all i wanna know really is if the flanges that bolt to the head are the same and are mounted at about the same angle. what size ports does a 5M-GE have? 40mm?
joecoolmk2
Re: manifolds on 5m's Fri, 02 July 2004 03:01 Go to previous messageGo to next message
please help. Crying or Very Sad if someone has a digital camera handy, take a pic of the flange that bolts to the head and send it to me or post it here please. or pis of the two manifolds already available would be nice. Very Happy
Re: manifolds on 5m's Fri, 02 July 2004 03:28 Go to previous messageGo to next message
Nope. Different.
5MGE ports are 34mm in diameter.
[Updated on: Fri, 02 July 2004 03:35]
rsdeo
Burlington, On. Canada
Re: manifolds on 5m's Fri, 02 July 2004 04:45 Go to previous messageGo to next message
I have a Doug Thorley header (sold by TRD) I used on '84 Supra years ago sitting in the garage. I'll take some pics and post them for you.
If I'm not mistaken all M series engines have interchangable parts. You can take a head, block, intake manifold or exhaust manifold and interchange them on 5M, 6M and 7M engines.
Re: manifolds on 5m's Fri, 02 July 2004 04:52 Go to previous messageGo to next message
i think 4me and 5me are interchangeable
but 5mge is not
ed_ma61
Lost in the K hole
Re: manifolds on 5m's Fri, 02 July 2004 05:51 Go to previous messageGo to next message
only twin cam parts are swapable between twin cams, ie 7mgte turbo manifold onto a 5mge, or 6mge race headers onto a 7mge etc
single cam parts are not swapable with twin cam
mteu 4me and 5me SOHC bits are generally swapable (i think)
entire heads can be swapped b/w DOHC and SOHC but this requires a LOT of work - timing covers, dizzys, crank perhaps (not sure if the woodruff key is the same accross all models) anyway you get the idea...
joecoolmk2
Re: manifolds on 5m's Tue, 06 July 2004 01:47 Go to previous messageGo to next message
the reason i asked is because i'm putting 5M-GE head on a 4M, and i'm making a manifold to fit triple solex's.
ed_ma61
Lost in the K hole
Re: manifolds on 5m's Tue, 06 July 2004 01:55 Go to previous messageGo to next message
watch for dsitributor fouling
Re: manifolds on 5m's Tue, 06 July 2004 03:11 Go to previous messageGo to next message
There's a bit more to it than just bolting on the head.
5MGE runs a timing belt, 4M/5M/5ME runs a chain so you'll have to swap all of that over.
Depending on which 4M you plan to run, your compression ratio at best will be 8.5:1. You will increase combustion chamber capacity and decrease the swept volume.
With the 5MGE head, the distributor will not foul....only on the SOHC head does this happen.
Re: manifolds on 5m's Tue, 06 July 2004 23:25 Go to previous messageGo to next message
What's the point of building a 4M/5M-GE hybrid? Just chuck a complete 5M-GE in and be done with it.
Re: manifolds on 5m's Tue, 06 July 2004 23:28 Go to previous messageGo to next message
Maybe he has some class restrictions where he has to leave the original block in it? or leave it the original capacity.
Who knows...
Re: manifolds on 5m's Tue, 06 July 2004 23:51 Go to previous messageGo to next message
Norbie wrote on Wed, 07 July 2004 09:25
Norbie ticked the correct box.
joecoolmk2
Re: manifolds on 5m's Thu, 08 July 2004 08:48 Go to previous message
i didn't get a whole engine 'cause i'm not a millionaire. it was much cheaper to get the head and fit it to a 4m. this way i don't have to get an engine inspection as well. i also thought about running two dizzy's, cuz i got three spares layin' round. if anybody has a 5m-ge head off an engine, could they measur the bore of the combustion cahmber please. Very Happy or pics.
Previous Topic:ae86 master cylinder
Next Topic:4AGE 20v or 4AGE 16v????
Current Time: Sun Nov 1 05:09:24 UTC 2026
Total time taken to generate the page: 0.0057039260864258 seconds
