Toymods » Tech & Conversions » 83mm ca18det pistons.
feral4mr2
Bundaberg, Qld.
83mm ca18det pistons. Fri, 02 July 2004 14:11 Go to next message
has anyone here ever tried the 83mm ca18det pistons in a 4age/ze? these have the same 20mm gudgeon pin.
i have seen reference to 4agze and later 7 rib 4age's running these pistons on the net before.
as the bore would need to be over bored by 2mm, how would that effect the heat of the engine and it's between bore strength? (specialy in a boosted application).
anyone seen it done? and know what c/r they are.
fatmr2
Re: 83mm ca18det pistons. Fri, 02 July 2004 14:15 Go to previous messageGo to next message
It would all depend on how far you can bore a 4age/ze.
Alainve
Newcastle NSW
Re: 83mm ca18det pistons. Fri, 02 July 2004 14:33 Go to previous messageGo to next message
try www.club4ag.com their tech is the best i have seen yet.
i have read it is possible to do an 83mm bore but be wary of it getting too thin between bores and having head gasket troubles.
but search is your best friend here.
[Updated on: Fri, 02 July 2004 14:34]
feral4mr2
Bundaberg, Qld.
Re: 83mm ca18det pistons. Fri, 02 July 2004 14:51 Go to previous messageGo to next message
i have been searching Alainve, and still am. Smile
but also would like to know if anyone that frequents this forum has had any up close experience with the topic and knows about these pistons.
mmm.. yeah headgasket thickness between bores might be the worst problem. Confused
Alainve
Newcastle NSW
Re: 83mm ca18det pistons. Fri, 02 July 2004 14:57 Go to previous messageGo to next message
good to see your doing your research but sorry ive no direct expeience here. but try to find valve angles of both heads and valve positions to see if the flycutting on the pistons will line up correctly. there may be issues there
Re: 83mm ca18det pistons. Fri, 02 July 2004 23:51 Go to previous messageGo to next message
would there actually be any cylinder wall left between the cylinders if you went out 2mm???
feral4mr2
Bundaberg, Qld.
Re: 83mm ca18det pistons. Sat, 03 July 2004 12:43 Go to previous messageGo to next message
it has been done on the 4age/gze engine Karl. i have lost the damn links i used to have about it though..
mmm.. just found this one again.
http://www.brisbaneperformance.com/cars.php?id=229
i'll have to try his e-mail addy. Smile
[Updated on: Sat, 03 July 2004 13:04]
Re: 83mm ca18det pistons. Sun, 04 July 2004 09:44 Go to previous messageGo to next message
... ahh yes, i know that young fellow.
feral4mr2
Bundaberg, Qld.
Re: 83mm ca18det pistons. Sun, 04 July 2004 09:49 Go to previous messageGo to next message
i hope he replies to my e-mail. i am intersted to know how his 4agte runs heat wise etc..
EMP-2TG
Carlingford, Sydney
Re: 83mm ca18det pistons. Mon, 05 July 2004 16:05 Go to previous messageGo to next message
unless your going with aftermarket ca18det pistons your flogging a dead horse, 4agze pistons are much much better
feral4mr2
Bundaberg, Qld.
Re: 83mm ca18det pistons. Mon, 05 July 2004 21:14 Go to previous messageGo to next message
thanks for the reply Josh. one thing i havnt seen yet on the net is reference to whether they are forged like the gze ones and their c/r.?? (spose i need to search some nissan forums).
the only reason i am looking at the idea is a friend may still have a set that i would get much cheaper than the gze ones, so thought it might be worth a shot. Confused
EMP-2TG
Carlingford, Sydney
Re: 83mm ca18det pistons. Mon, 05 July 2004 23:55 Go to previous messageGo to next message
u can buy new gze pistons from toyota for less than $100 each
they come in oversize as well
feral4mr2
Bundaberg, Qld.
Re: 83mm ca18det pistons. Tue, 06 July 2004 03:14 Go to previous messageGo to next message
yes i realise that dude.. Wink
toyota deal through us at work so i should get them a little cheaper than that.
doesnt hurt to explore other avenues when building hybrid engines.. Smile
old_mr2
Re: 83mm ca18det pistons. Tue, 06 July 2004 03:21 Go to previous messageGo to next message
I think your cat might be taking amphetamines.
feral4mr2
Bundaberg, Qld.
Re: 83mm ca18det pistons. Tue, 06 July 2004 11:11 Go to previous message
Laughing Laughing ummm... yeah. Razz
Previous Topic:1ggte 6spd gearbox to 1uzfe
Next Topic:Wheel offset
Current Time: Sun Oct 25 13:51:43 UTC 2026
Total time taken to generate the page: 0.077373027801514 seconds
