Toymods » Tech & Conversions » driveshaft issues (st162)
dar_sbb
driveshaft issues (st162) Sun, 04 July 2004 05:06 Go to next message
front left drive shaft broke just behind the hub nut. The issue is that it has broken 3 times in bout 2 years.
I have replaced hubs and bearings and it still broke....
ne suggestions??
daz
Re: driveshaft issues (st162) Sun, 04 July 2004 07:40 Go to previous messageGo to next message
Quote:
bored to 2.2l
King Springs: Super low
This could have something to do with it
Aust162
Melb, Victoria
Re: driveshaft issues (st162) Sun, 04 July 2004 10:22 Go to previous messageGo to next message
the left drive shaft is the main spinner right? Smile .
is so then it sounds like it can take the power of ur modified engine. maybe look at using different d/shafts to use or make custom ones. my 0.02c
RWDboy
Re: driveshaft issues (st162) Mon, 05 July 2004 06:29 Go to previous messageGo to next message
Suspension set up may have something to do with it dude...
You driveshafts should easily handle the HP you are giving it.
Celica_John
Re: driveshaft issues (st162) Mon, 05 July 2004 07:28 Go to previous messageGo to next message
probably depends a lot on how you drive it too Rolling Eyes
RWDboy
Re: driveshaft issues (st162) Mon, 05 July 2004 07:37 Go to previous messageGo to next message
You could try an MR2 gearbox with GT4 driveshafts if you feel that you are breaking them from too much power.
Note : Wheel spin generally doesn't break driveshafts, the torque and power being applied to a spinning wheel is minimal - however excessive torque might kill it (hard launches, excessive load, like full throttle 1st gear application). Also, stress on the bearing may be screwing it up due to the driveshafts' non-stock 'resting' angle.
charliechalk
Re: driveshaft issues (st162) Mon, 05 July 2004 09:37 Go to previous messageGo to next message
What he said Smile
But lowering would be putting extra compression on the shaft and joints.
Draza
Wahroonga
Re: driveshaft issues (st162) Mon, 05 July 2004 09:53 Go to previous messageGo to next message
I take it that the shafts off the mr2 box and the GT4 shafts are the same, cos the GT4 shafts and the MR2 turbo box shafts were different.
RWDboy
Re: driveshaft issues (st162) Mon, 05 July 2004 12:00 Go to previous messageGo to next message
I meant MR2 turbo box...
For an ST162 you use the MR2 turbo box and ST165 shafts??? I have never done this so I don't know.
wiso
Re: driveshaft issues (st162) Mon, 05 July 2004 13:48 Go to previous messageGo to next message
hmmm ST165/85 left driveshaft would fit, but only the left you can't use the right, otherwise try a camry driveshaft (are they any stronger anyone know?)
The main shaft actually sheared behind the hub net, yeah that wouldn't have to do with power though, if it was a power problem the cv would just shit itself and would spin freely, (happened to me) sounds like too much stress, are you doing the nuts up to the right torque?
RWDboy
Re: driveshaft issues (st162) Tue, 06 July 2004 01:09 Go to previous messageGo to next message
Could you get custom made joints to reduce the stress on the shaft? You'd probably need custom shafts as well though...
Just drive slower if you want really low suspension???
Having looked at the ST162 shafts, they certainly aren't weak or piddly or anything. I'm not sure that ST165 shafts would be much better seeing that your problem isn't really related to torque...it's just related to the angle that everything is at.
This isn't exactly my speciality per se Smile
Also - I'm guessing the right driveshaft from an ST165 is shorter due to the front gearbox having two diffs (is that right?)
RWDboy
Re: driveshaft issues (st162) Tue, 06 July 2004 01:13 Go to previous messageGo to next message
It's unlikely a camry driveshaft would be any stronger...
I think ST184 driveshafts fit as well, but again, I doubt they are any stronger...just newer Smile
wiso
Re: driveshaft issues (st162) Tue, 06 July 2004 07:07 Go to previous messageGo to next message
Yeah the ST165/85 have the same length driveshaft on each side they are the same length as the left on the 162, just beefed up CV's but the shaft is the same size.
I just refer to every thing from the ST184/204 as camry stuff cause its all the same stuff, they all use the same drive shafts, the St162 are a bit different though.
Classique71
Colac, Victoria
Re: driveshaft issues (st162) Tue, 06 July 2004 08:40 Go to previous messageGo to next message
mine did that on the left hand ( gt4 shaft )
same thing - castle nut fell out into my hand .. ( one week after i bought the gt4 and $700 + later to get it fixed )
looks like it was overtightened to the point of stressing the stub or metal fatigue
box one is more likely than box 2
dar_sbb
Re: driveshaft issues (st162) Wed, 07 July 2004 02:03 Go to previous messageGo to next message
The suspenssion was only modified in the last couple of months, and that was only the springs...
the left shaft is shorter due to the box
it has showed fatigue at the end of the thread wr the hub nut holds everything together
Thanks for the help guyz, i got another shaft... for free from a the same guy i got the other one from... hope this holds!
RWDboy
Re: driveshaft issues (st162) Wed, 07 July 2004 03:59 Go to previous message
Sounds like you are just one unlucky man Sad
Previous Topic:Mods Please Delete
Next Topic:Conversion Pros & Cons
Current Time: Tue Oct 20 03:58:36 UTC 2026
Total time taken to generate the page: 0.0061299800872803 seconds
