Toymods » The Outhouse » DVDShrink
Les
DVDShrink Mon, 05 July 2004 01:37 Go to next message
I want to back up a DVD ...
umm i get lost after i press the back up button
can anyone help ??
i.e. select target drive, select target drive for DVD output files ??
help plz !
gabe
Re: DVDShrink Mon, 05 July 2004 06:31 Go to previous messageGo to next message
which version?
3.1?
Les
Re: DVDShrink Mon, 05 July 2004 06:40 Go to previous messageGo to next message
yea mate 3.1
gabe
Re: DVDShrink Mon, 05 July 2004 06:47 Go to previous messageGo to next message
3.1 automatically adjusts the compression settings for you.
Click backup and choose where you want to dump the files.
I uncheck the "automatically create VIDEO_TS and AUDIO_TS" box
Dump the files into a folder called VIDEO_TS.
Dont worry about any other tabs.
do you have nero on your machine?
Les
Re: DVDShrink Mon, 05 July 2004 07:01 Go to previous messageGo to next message
yep and dvd decrypter
gabe
Re: DVDShrink Mon, 05 July 2004 07:16 Go to previous messageGo to next message
Use nero to burn the folder VIDEO_TS onto a dvd if you so wish.
what do you use DVD decrypter for. you shouldnt need it for 'backing up' dvd's
Les
Re: DVDShrink Mon, 05 July 2004 07:20 Go to previous messageGo to next message
argh
so basically burn it from the hard drive from nero right ?
gabe
Re: DVDShrink Mon, 05 July 2004 07:30 Go to previous messageGo to next message
Yep,
Open Nero and drag the VIDEO_TS folder straight to the DVD
the folder must be in capitals exactly as you see it above.
It will play on your dvd player too.
Les
Re: DVDShrink Mon, 05 July 2004 07:48 Go to previous messageGo to next message
gabe wrote on Mon, 05 July 2004 16:47
where is the box that says "automatically create VIDEO_TS and AUDIO_TS" ??
gabe
Re: DVDShrink Mon, 05 July 2004 08:03 Go to previous messageGo to next message
you can make DVD shrink automatically create a VIDEO_TS and AUDIO_TS folder.
All the DVD files are dumped into the VIDEO_TS folder. When I do it, I manually create the VIDEO_TS folder.
either way you end up with the same result
Les
Re: DVDShrink Mon, 05 July 2004 08:08 Go to previous messageGo to next message
ok i'm trying now ..
then just use nore to burn .. i didnt know that nero does dvds as well as cds ??
gabe
Re: DVDShrink Mon, 05 July 2004 08:48 Go to previous messageGo to next message
Depending on version......nero does do DVDs.
You do have a DVD burner dont you?
Les
Re: DVDShrink Mon, 05 July 2004 08:59 Go to previous messageGo to next message
LOL yeh i do
ok i get this message
Could not perform end of Disc-at-once
Burn Process failed
whats the deal ?
from Nero this message is
[Updated on: Mon, 05 July 2004 08:59]
Les
Re: DVDShrink Mon, 05 July 2004 09:00 Go to previous messageGo to next message
could it be some setting ??
gabe
Re: DVDShrink Mon, 05 July 2004 09:04 Go to previous messageGo to next message
Did that message come up before it started to burn or right at the end?
did you opt to close the session/disc?
To be honest I dont use nero so I might be wrong
Les
Re: DVDShrink Mon, 05 July 2004 09:05 Go to previous messageGo to next message
fcuk man - and here i am thinking u are a nero expert !! hahaha
right at the end .. i do not get the option to end session .. it does that automatically when burning cds previously too
WHAT CAN BE WRONG !??!?!
[Updated on: Mon, 05 July 2004 09:06]
gabe
Re: DVDShrink Mon, 05 July 2004 09:10 Go to previous messageGo to next message
Fuck im no expert at anything........ Crying or Very Sad
Id take that dvd and try to play it on your telly.......my guess is that it wont play........which means its a coaster!!
Les
Re: DVDShrink Mon, 05 July 2004 12:18 Go to previous messageGo to next message
it works dude
Les
Re: DVDShrink Mon, 05 July 2004 14:09 Go to previous messageGo to next message
i meant the dvd works on a dvd player .. but does not burn
someone helllp
EMP-2TG
Carlingford, Sydney
Re: DVDShrink Mon, 05 July 2004 16:17 Go to previous messageGo to next message
- check no multisession
- check finalise
might help Razz
i just use those settings and it works 4 me
Geoff
HORNSBY
Re: DVDShrink Tue, 06 July 2004 00:15 Go to previous messageGo to next message
Do you just want to use DVDSHRINK??
you can use dvd95copy i have a copy if you like
it does it all for you and burns on to the dvd
gabe
Re: DVDShrink Tue, 06 July 2004 00:49 Go to previous messageGo to next message
Does that software actually compress the video? As most DVD's are duel layer and can hold up to around 9 gig.
Obviously 9 gig wont fit onto a regular DVD
monkeymajik
Re: DVDShrink Tue, 06 July 2004 01:05 Go to previous messageGo to next message
DVDShrink is the best single click dvd backup software around.
Newer versions of dvd shrink can output straight to an image file, rather than video_ts/audio_ts folders, so you can burn that with just about any software, DVD Decrypter is good for that.
peewee
adelaide
Re: DVDShrink Tue, 06 July 2004 01:19 Go to previous messageGo to next message
i've got the newer version, it's a free download from their site, get it cos it'll make it all a lot easier for you. get a copy of nero6 onto your computer as well and you can do 1 click backup and very very easy re-authoring. plus it seems to encode etc a lot quicker than other software i've tried.
i was tryin to wokr out what you were all talkin about earlier, cos i never used the older version, but with this one you don't have to root around the transport streams and crap
Geoff
HORNSBY
Re: DVDShrink Tue, 06 July 2004 02:04 Go to previous messageGo to next message
yes it does it all for you
havent done it in awhile but ill copy one now
all you need to do is find the ts_video and when you want the files and then i burns it for you
and i dont think you need to have nero ill copy 1 now and let know know
Geoff
Geoff
HORNSBY
Re: DVDShrink Tue, 06 July 2004 03:59 Go to previous messageGo to next message
yes DVD shrink is the better one
dvd95copy is easier to use but takes longer
Les
Re: DVDShrink Tue, 06 July 2004 13:41 Go to previous messageGo to next message
FCUKKKKKKKKKKKK
i cant seem to get nero to burn it !??!?!
the dvds im looking at are ALL less than 4.7 gigs ... so no need to re-author ...
NERO just does not finish it !??!?!
i have checked NO MULTISESSION and the finalise function is greyed out .... anymore tips ??
pissoing me off!!
Les
Re: DVDShrink Wed, 07 July 2004 07:18 Go to previous messageGo to next message
NERO just stuffed up AGAIN
Invalid field in commmand ... ? fark
gabe
Re: DVDShrink Wed, 07 July 2004 09:42 Go to previous messageGo to next message
You should have got some burning software with your burner.
Try using that to perform the burn.
Sounds like Nero might benifit from a re-install too
Siktoy ra23
Plumpton/sydney
Re: DVDShrink Wed, 07 July 2004 10:00 Go to previous messageGo to next message
Les
What version of nero are you using?
As for DVDShrink it sucks if you try to copy the disk after you burn it 80% of the time it will fuck up, I use dvd decripter to get it of the disc then dvd2one to compress it to 4.7gig
BEN
Les
Re: DVDShrink Thu, 08 July 2004 02:24 Go to previous messageGo to next message
Using Nero burning rom 6 mate ...
ummm
its the burning part i am sure that i am having problem with .. DVD shrink compresses the dvd to under 4.5 gigs and thats fine
im backin up ORIGINAL dvds and not copies by the way ... could it be that it is encrypted in some way ?
gearb0x
Re: DVDShrink Thu, 08 July 2004 02:34 Go to previous messageGo to next message
use dvdxcopy
use the Retard mode
i found the advanced mode likes to be gay
and it burns it for you
Les
Re: DVDShrink Thu, 08 July 2004 04:58 Go to previous messageGo to next message
Ok i have worked it out
if anyone else has any problems just gimme a yell !!
thanks guys
(note nero does not work with pioneer!!)
Siktoy ra23
Plumpton/sydney
Re: DVDShrink Thu, 08 July 2004 08:21 Go to previous messageGo to next message
I am using nero 6.3 and it works fine with my pioneer burner if you try to use nero express it is a lot easer.
BEN
Les
Re: DVDShrink Thu, 08 July 2004 08:26 Go to previous messageGo to next message
nero 6 must not be compatible then ?
Siktoy ra23
Plumpton/sydney
Re: DVDShrink Thu, 08 July 2004 09:09 Go to previous messageGo to next message
it should be I was using nero 5 befour and it worked fine
EvilJack
Sutho/Hills NSW
Re: DVDShrink Mon, 12 July 2004 01:17 Go to previous messageGo to next message
If you have problems straight copying DVD Decrypter works a treat.
Then use DVDShrink
Then Burn Cool
Re: DVDShrink Mon, 12 July 2004 08:26 Go to previous messageGo to next message
LEs + computer = BAD!
latest copy of DVD Shrink works FUKINAWESOMELY, takes about 3 clicks to copy a DVD.
1. Open DVD Shrink
2. Instert original DVD
3. Click "Open Disc"
4. select original source disc
5. wait for it to work its magic
6. Select destination disc
7. Wait for more magic
YAY!
Geoff
HORNSBY
Re: DVDShrink Mon, 12 July 2004 08:59 Go to previous messageGo to next message
also some dvd dont like burning on the out side it the dvd's so make then 4 gigs and youll be fine
thats what i ahve found out on some of the cheaper brands
Geoff
Re: DVDShrink Mon, 12 July 2004 12:52 Go to previous messageGo to next message
solution, dont buy cheap DVD blanks.
Buy, FORIS, they rock
available at, www.jaycar.com.au
FORTIS = XC4730, XC4731 and XC4736.
Currently i use the XC4736, cheapest 8x DVD blanks available, and DAMN GOOD quality.
4AGE
Re: DVDShrink Mon, 27 December 2004 10:52 Go to previous messageGo to next message
i know this is a oldish topic but i did do a search.
Problem 1:
When i use nero. I get a copyright popup. DUH. But doing some very quick research it is something related to CCS encoding. I have installed dvd shrink.
Problem 2:
WHY THE FUCK DOES IT TAKE SO LONG?
I'm using a 16x pioneer drive. SO many processes. Am i doing something wrong?
Someone that can help me. can they do so? Coz i am so stumped.
Even if u gotta add me to msn. Please do so.
Choony_AE86
Melbourne, South East
Re: DVDShrink Mon, 27 December 2004 10:58 Go to previous messageGo to next message
Stop downloading porn with viruses, its screwing with your programs now Razz
ra23mad
Re: DVDShrink Tue, 28 December 2004 01:20 Go to previous messageGo to next message
4age: Dvd shrink takes around an hour to do a full rip and compress.
Then with nero 15minutes to half an hour to burn. (at least on my system - anyway)
the longest part of the dvd 'rip' is the compression - compression will kill most computers in a matter of seconds. Unless you have a decent p4 or an amd64 (kind of makes me think of comodore 64) with poodles of ram...compression will always be one of the slowest things your computer will do.
beterthenu
Dubbo NSW
Re: DVDShrink Tue, 28 December 2004 13:15 Go to previous messageGo to next message
or you could just let dvdshrink do it all for you. it will burn straight to the dvd its self. its really not that hard. dont know where people are getting the idea of using nero from.
4AGE
Re: DVDShrink Tue, 28 December 2004 21:46 Go to previous messageGo to next message
figured it out.
But what happened to "on the fly" burning.
Insert source. Insert target.
No encoding or ripping e.t.c
just a direct clone/copy.
It works n all. But isn't there a faster way to do it?
Chooney: Fugg off. It aint my computer thats screwed with porn. ITS YOURS! WAHAHAHAA!!!
beterthenu
Dubbo NSW
Re: DVDShrink Tue, 28 December 2004 22:00 Go to previous messageGo to next message
4AGE wrote on Wed, 29 December 2004 08:46
figured it out.
the reason it cant copy it on the fly, is because you are modifing the contents of the dvd. if the original dvd will fit in the recording medium, you can do an on the fly disk to disk copy. if the source disk is quite large, it may have to re-encode it to be able to fit it on the destination disk.
[Updated on: Tue, 28 December 2004 22:01]
4AGE
Re: DVDShrink Wed, 29 December 2004 03:33 Go to previous messageGo to next message
Dvdshrink reads the contents of the drive when u "open" the disc.
I do not make any image or audio alterations n do a "backup" straight away. And it has to "encode" it.
What software can i use to copy a <4.7 gig dvd to a 4.7 gig disc ON THE FLY.
beterthenu
Dubbo NSW
Re: DVDShrink Wed, 29 December 2004 03:40 Go to previous messageGo to next message
well there u can use either nero or alcohol. The good thing about dvdshrink is that it removes region coding and alike.
dvd decrypter is another great tool, but you still have the problem of not being able to copy on the fly.
if you just want a disk for disk copy, its just the same process as copying any old cd/dvd, providing your burning software doesnt prevent you to copy copyrighted media.
*Edited*
[Updated on: Wed, 29 December 2004 03:41]
ra23mad
Re: DVDShrink Thu, 30 December 2004 23:14 Go to previous messageGo to next message
One of my friends uses 'dvdclone - by elby software' personally I hate it...
I'd rather use dvdshrink and nero any day of the week.
with dvdclone all you do is put dvd in put dvd-r(w) in and press the copy button.
It does 4.7gb dvd's and larger dvd's *seemingly* on the fly...
(just make sure you have at least 5gb free hdd space for 'temp' files)
4AGE
Re: DVDShrink Tue, 04 January 2005 02:13 Go to previous message
bottom line is.
i think dvd shrink has to be used for any copy protection.
and
dvd clone in the other scenario.
I think it will be a while til anyone gets their shit together for a good burning program.
Previous Topic:Exercise
Next Topic:1 million dollars to sit on his ass
Current Time: Fri Nov 20 06:15:07 UTC 2026
Total time taken to generate the page: 0.015106916427612 seconds
