Toymods » Tech & Conversions » TA22 diff strength?
sebta22
icon5.gif  TA22 diff strength? Sun, 08 September 2002 11:07 Go to next message
Does anyone know how much the TA22 diff can take power wise?? Also I have problems with a 2 1/2" exhaust over the diff, when there is some weight in the back the exhaust always hits the diff, is this something I have to put up with??
rob_RA40
c'town, NSW
Re: TA22 diff strength? Sun, 08 September 2002 11:19 Go to previous messageGo to next message
ive read/heard the figure 250HP a few times but as far as im concerned it all depends on how u drive and treat it..
sebta22
Re: TA22 diff strength? Sun, 08 September 2002 11:42 Go to previous messageGo to next message
Would the unit hold a 4AGTE unit the same as micheal's article??
dorikin
NE Melbourne
Re: TA22 diff strength? Sun, 08 September 2002 15:25 Go to previous messageGo to next message
the diff will last about 5 seconds if treated bad... if driven nicely i could last a little while, but deffinately not a long term solution... something more serious is a must!!!
as for the exhaust, i'm a big fan of having the exhaust going under the diff housing, just to one side of the diff centre. although i have not done this, or ever seen it done, i hear that APEXi make an exhaust for the AE86 that goes under the diff, their N1 spec!!! with short stroke shocks, i imagine it could be a possibility, and i'm keen to try it one day on my TA22. who has? i'd love to know if it's a good idea!!!
TOY77
Re: TA22 diff strength? Mon, 09 September 2002 04:07 Go to previous messageGo to next message
G'day,
i have busted a couple of diffs...
both behind my 18rg... used to drive it pretty hard.
and behind my 1ggte... drive it VERY softly.
basically they are pretty weak if you want to drive your car hard...
I have my 3in mandrel bend under the diff.... to pass engineering i fitted rally style straps (made from seatbelts) that limit the drop of the diff... not neccesary if you want to buy shorter shocks....
Stew
Classique71
Colac, Victoria
Re: TA22 diff strength? Tue, 10 September 2002 02:33 Go to previous messageGo to next message
I know of a celica in adelaide putting out 230KW thru a stock ta22 diff ..
hasnt broken yet ..
hes running a worked 3tgte too , thru stock t50 ( heacier clutchplate ) and stock diff .. been running perfectly so i believe for 2 years ..
I guess it comes down to how you drive - If you drop the clutch it will go BOOm - drive sensibly and feed the power and alls sweet ..
thetoyman75
Club President
Re: TA22 diff strength? Tue, 10 September 2002 03:58 Go to previous messageGo to next message
Sebta22,
The diffs are a good lightweight unit if you don't expect to much out of them. It really does come down to how you drive it and your level of Traction.
I have had very worked 2TG's in front of stock diffs and had no problems.
Then again Last time Tina's car made an attempt at eastern creek it got limped home with a sheared axel, Blown centre and busted rear uni joint (all on 102 RWHP) so yeah comes down to how you drive it !
I would suggest it will not be up to your requirement however !
sebta22
Re: TA22 diff strength? Tue, 10 September 2002 05:35 Go to previous messageGo to next message
Thanks guys!
I most probably will replace diff. I am looking at having discs at rear, I have read that there several options: shorten hilux, shortened pintara or VN shortened and pattern change. Which option is the best?? Cost and modification wise??
sbyder
Ipswich QLD
Re: TA22 diff strength? Tue, 10 September 2002 05:53 Go to previous messageGo to next message
sebta22 wrote on Tue, 10 September 2002 15:35
Thanks guys!
I ask the same question as above, but for use in a RA28????
Ben
GIN51E
Berowra-Sydney
Re: TA22 diff strength? Tue, 10 September 2002 09:46 Go to previous messageGo to next message
is a 22 the same diff as a 23? if so then my brother blew one, claims he hit a big pot hole and thats when it happened but hard to belive think it had something to do with him always getting compression lockups anyway that was in a 18-RC and when we drained it we got a big tooth fall out Rolling Eyes thats why i refuse in doing dohnuts (often) Razz as i don't count on the diff being able to take it.
corolla coupe 18rgu
Townsville NQ
Re: TA22 diff strength? Tue, 10 September 2002 10:05 Go to previous messageGo to next message
hilux is the way to go, how strong are the carona diffs, the sedans are very close to fitting in, has anyone tryed this mod
[Updated on: Tue, 10 September 2002 10:10]
Re: TA22 diff strength? Tue, 10 September 2002 12:04 Go to previous messageGo to next message
Depends which model, but the mid 70's ones (RT104) came with the same T series diff as RWD Celicas.
Re: TA22 diff strength? Wed, 11 September 2002 00:52 Go to previous messageGo to next message
Skyline, not pintara - avoid that tiny little 2 pinion one at all costs. The 4 pinion skyline one is the same centre as a falcon/commodore (I stole my LSD from a clubsport)
corolla coupe 18rgu
Townsville NQ
Re: TA22 diff strength? Thu, 12 September 2002 10:39 Go to previous message
it a 78 and a 79 carona, are theses the same aswell, thanks
Previous Topic:did the 2WD hilux ever come factory with the 4Y-C ???
Next Topic:5M-E Oxygen sensor?
Current Time: Sat Nov 21 01:43:12 UTC 2026
Total time taken to generate the page: 0.0046460628509521 seconds
