Toymods » Tech & Conversions » Leaning out 3sgte
Draza
Wahroonga
Leaning out 3sgte Mon, 05 July 2004 10:52 Go to next message
ok after the dyno on the weekend i found out that i am running the car too rich. I was wondering if u turn the screw clockwise or anti-clockwise to lean out the mixture. The screw i am talking about is located on the airflow meter.
7M-Brisbane
Re: Leaning out 3sgte Mon, 05 July 2004 11:12 Go to previous messageGo to next message
The screw you are talking about shouldn't be touched, but if you insist, then it should be done ON THE DYNO BY A PROFESSIONAL to check that you're not going too lean.
wiso
Re: Leaning out 3sgte Mon, 05 July 2004 13:50 Go to previous messageGo to next message
are you for real... you can adjust how lean/rich it runs, so If I took it to dynotune they could lean it out right, cause mine has the same problem, way to rich.
Re: Leaning out 3sgte Mon, 05 July 2004 14:03 Go to previous messageGo to next message
yeah the idle mixture can be played with, which has an effect across the whole RPM range.
I would also recommend this on a dyno
Draza
Wahroonga
Re: Leaning out 3sgte Mon, 05 July 2004 14:18 Go to previous messageGo to next message
ok so i will take it to a dyno and get it tuned. I guess i can use the $150 i just won on the pokies, dam and i was going to see about getting some 15x8 rims for dragging with.
DunkyMonkey
Brissy QLD
Re: Leaning out 3sgte Mon, 05 July 2004 23:35 Go to previous messageGo to next message
damn, i don't have an AFM, and i have this distinct ultimate fuel smell out the back of my car, i think its only bad when its cold.
spectral
Re: Leaning out 3sgte Tue, 06 July 2004 03:08 Go to previous messageGo to next message
You can also tighten the spring inside the AFM by a notch or two.
Once again, only do it on a dyno with an accurate o2 sensor hooked up.
Bugman
Re: Leaning out 3sgte Tue, 06 July 2004 05:32 Go to previous messageGo to next message
back to the orignal Q, anti clockwise leans it right?
Draza
Wahroonga
Re: Leaning out 3sgte Tue, 06 July 2004 05:53 Go to previous messageGo to next message
thats what i'm asking.
DunkyMonkey
Brissy QLD
Re: Leaning out 3sgte Tue, 06 July 2004 07:33 Go to previous messageGo to next message
i feel so left out with a map sensor, if it weren't better then i might be disappointed.
3S-GE_Man
Gold Coast
Re: Leaning out 3sgte Tue, 06 July 2004 14:59 Go to previous messageGo to next message
whne i got my car ont he dyno it read real rich too, the guy said a malpassi fuel regualator can sort this out and also when u uping the boost it would just give a bit more fuela dn that, and the also it would do u for ages till u get into insane power with bigger turbos and internal work!
Nezza Cool
RWDboy
Re: Leaning out 3sgte Wed, 07 July 2004 08:08 Go to previous message
Where is this screw btw? I'm guessing there is one on the 3S-GE as well on the AFM somewhere - my car has run rich for donkeys years and I've never thought of leaning it out a fraction by adjusting the idle mix?
Previous Topic:Suspension bushes for GZ20
Next Topic:Sports Seats into ST162 Celica
Current Time: Sun Oct 18 22:59:15 UTC 2026
Total time taken to generate the page: 0.0050668716430664 seconds
