Toymods » Tech & Conversions » 18rc electronic disributor
ehendrikd
ballarat
18rc electronic disributor Mon, 05 July 2004 23:20 Go to next message
hi all
just wondering if there are any factory electronic distributors i could get for my 18rc. my friend is building me electronic ignition for my celica and said this would be very useful.
possiblities i have thought of were an 18rgeu dizzy (possibly hard to get hold of) or maybe a 22re dizzy.
do these simply bolt in? any other suggestions?
thanks in advance
evan
ViPeR_NiPPleX
VIC, Sth Frankston.
Re: 18rc electronic disributor Mon, 05 July 2004 23:31 Go to previous messageGo to next message
you have three options for triggering transitorized ignition.
1. Use the points as a switch instead of a current path. Means you can keep your standard dizzy. Will require an ignitor that can use points switching as a trigger. Jaycar has a kit.
2. Find an 18rg elec. dizzy. Harder to find, but should be a direct swap in. Could use the ignitor from 18rg setup to, all swaps over.
3. Gut 18rc dizzy and put in 21rc/22re gear in it. I'm not sure how hard this is to do. I've heard of someone on here doing it. I think holes had to be redrilled?? This setup you could also take the ignitor from the donor car for ease of installation.
If I am wrong anywhere, plz let me kno.
ehendrikd
ballarat
Re: 18rc electronic disributor Mon, 05 July 2004 23:59 Go to previous messageGo to next message
thnx viper, pretty much exactly what i needed to know Very Happy
people100
Rocklea qld
Re: 18rc electronic disributor Tue, 06 July 2004 07:15 Go to previous messageGo to next message
22re dizzy guts into 18rc dizzy is very easy to do. Just gotta watch out on your springs on the buttum and remember to swap the whole shaft.
Maurice c
Re: 18rc electronic disributor Tue, 06 July 2004 18:28 Go to previous messageGo to next message
Would option 2 above not suffer from points bounce affecting the ignitor timing?
Blaze
Re: 18rc electronic disributor Wed, 07 July 2004 00:35 Go to previous messageGo to next message
The 18rg dizzy will not fit on the single cam engine. I tried it. that is taking the whole assembly and shaft for a straight swap.
ViPeR_NiPPleX
VIC, Sth Frankston.
Re: 18rc electronic disributor Wed, 07 July 2004 02:21 Go to previous messageGo to next message
I thought the 18r-c/g both had the dizzy driven from the crank? Did they change gears or something?
Maurice c
Re: 18rc electronic disributor Wed, 07 July 2004 21:57 Go to previous messageGo to next message
They mount in different positions. The RC is on the back drivers side of the engine, driven by the crank and the RG is on the front drivers side, driven by one of the cams I think. (Might be wrong about drive but not position).
Maurice c
Re: 18rc electronic disributor Sun, 11 July 2004 23:10 Go to previous messageGo to next message
Has anybody had good results with Jaycars ignition system?
munki
Gold Coast
Re: 18rc electronic disributor Mon, 12 July 2004 02:36 Go to previous message
the 18rc distributor drives the oil pump that is what the little notch in the bottom is for. Both the RG and RC Dizzy drive off the centeral shaft. RGEU Electric dizzy'may not have this notch (mine doesnt) and the body is different and wont fit unless you swap the internals over.
why not do the 22re way?
Previous Topic:4AGZE ecu or Aftermarket ECU
Next Topic:MX83 transmission question.
Current Time: Sun Nov 1 05:02:46 UTC 2026
Total time taken to generate the page: 0.0053558349609375 seconds
