Toymods » Tech & Conversions » V160/V161 6 Speed gearbox info req'd
bbaacchhyy
V160/V161 6 Speed gearbox info req'd Tue, 06 July 2004 01:08 Go to next message
Hiya all,
Through work, I can get hold of the new 6 speed gearbox from Aisin Shocked , and whilst it is not the same as the Toyota one used behined the JZA80 Supra's, I'm hoping that it is similar enough that it is an alternative .
Can somebody tell me if the bellhousing is removable (a la W5* boxes) ?
If the bellhousing is seprable, are they available to suit a 7M engine or is it a custom jobbie ? Or can a 2JZ one be butchered to fit ?
Anyone got sone more detailed pics of the bellhousing to gearbox bolt pattern ?
I have got the ratios from Norbs, but need some othetr general info, and anything will help.
I'm off to get some drawings and ratios from our server to see what I can find Cool
Michael B
wastegate
Gold Coast
Re: V160/V161 6 Speed gearbox info req'd Tue, 06 July 2004 01:25 Go to previous messageGo to next message
bbaacchhyy wrote on Tue, 06 July 2004 11:08
Hiya all,
From Aisin?? It's not the 6speed for the IS200 is it??
The Supra 6speed is a Getrag.
No. The bellhousing is part of the casing.
Can be butchered to fit. But it's easier to put a 2JZ in. Very Happy
It's part of the casing as stated.
Here, http://www.turbosupras.com/pages/technical/V160.ht m
Michael B
bbaacchhyy
Re: V160/V161 6 Speed gearbox info req'd Tue, 06 July 2004 01:55 Go to previous messageGo to next message
Oh bugger. Cheers for that info Wastegate, I have to do some more searching.
The gearbox that I am after details on is the Aisin, but not the IS200 one, it is a GM usage product, and is also known as D173 for the local, or D171 for the US market.
I'm trying to have a perve at one here to get some more info on it.
Michael B
PS As for putting in a 2JZ rather than butcher the gearbox, I'll stick with the gearbox, as I don't hav ethe time, patience or money for that matter to do both Sad
wastegate
Gold Coast
Re: V160/V161 6 Speed gearbox info req'd Tue, 06 July 2004 02:24 Go to previous messageGo to next message
The only cars the V160 (and it's sisters) are used in are the JZA80 Supra, R34 GTR..
Here is the product chart.
http://www.en.getrag.de/176/176
[Updated on: Tue, 06 July 2004 02:26]
bbaacchhyy
Re: V160/V161 6 Speed gearbox info req'd Tue, 06 July 2004 03:28 Go to previous messageGo to next message
The box I'm looking at (still trying to get a dwg) has the following ratio's ;
GM D173......................Toyota V160
1st......4.475 : 1................3.827 : 1
2nd......2.577 : 1................2.360 : 1
3rd......1.633 : 1................1.685 : 1
4th......1.193 : 1................1.312 : 1
5th..........1 : 1................1.000 : 1
6th......0.752 : 1................0.793 : 1
Rev......3.954 : 1................3.280 : 1
It takes a 10" clutch plate, and typically would have a diff ratio of 2.87 : 1. The engine is a NA V6
If I find more, I'll let you know
Michael B
Re: V160/V161 6 Speed gearbox info req'd Tue, 06 July 2004 23:24 Go to previous messageGo to next message
wastegate wrote on Tue, 06 July 2004 12:24
And the M3 apparently!
wastegate
Gold Coast
Re: V160/V161 6 Speed gearbox info req'd Wed, 07 July 2004 01:55 Go to previous messageGo to next message
No Norbie. Have a look on that getrag site. Different. slap! Very Happy
Skip
Re: V160/V161 6 Speed gearbox info req'd Wed, 07 July 2004 02:03 Go to previous messageGo to next message
With a first gear ratio like that sounds like it's a 4WD box.
Chris Davey
sunny coast, qld
Re: V160/V161 6 Speed gearbox info req'd Wed, 07 July 2004 02:12 Go to previous messageGo to next message
a 4wd with a 2.87:1 diff ratio doesn't sound right to me?
bbaacchhyy
Re: V160/V161 6 Speed gearbox info req'd Wed, 07 July 2004 03:05 Go to previous messageGo to next message
Definitely not a 4WD, but a 2WD 4 door sedan. V6 N/A too. Was also surprised when I looked up the option string to see the ratio as well.
The tyres are 235/45x17's as well.
I'm still digging Confused
Soarer
Wollongong
Re: V160/V161 6 Speed gearbox info req'd Wed, 07 July 2004 04:27 Go to previous messageGo to next message
From memory the V160 was available in 1995+ Mitsubishi 3000GT VR4 models.
Joshstix
Toymods Vice President
Re: V160/V161 6 Speed gearbox info req'd Wed, 07 July 2004 05:22 Go to previous messageGo to next message
The 3000GT runs an east to west style 4WD box.
Soarer
Wollongong
Re: V160/V161 6 Speed gearbox info req'd Wed, 07 July 2004 10:15 Go to previous message
My bad Embarassed Assumed engine config was similar to the 300ZX. They do use a Getrag, but the WM6G1 model.
Previous Topic:GMC ARC Welder **Opinions Please**
Next Topic:Drive IN drive out MA61 1JZ conversion
Current Time: Sun Oct 18 10:51:35 UTC 2026
Total time taken to generate the page: 0.041677951812744 seconds
