Toymods » General Car Talk » Hilux diff conversion?
chris_RA40
icon2.gif  Hilux diff conversion? Tue, 21 May 2002 23:04 Go to next message
How much work/cost is involved with getting a hilux diff to fit my RA40? does it need to be shortened etc.?
Thanx for the help,
chris.
Re: Hilux diff conversion? Wed, 22 May 2002 02:02 Go to previous messageGo to next message
RN41 Hilux diff is approx 1410mm across from hub to hub with the drums on. What is the width of your RA40? Look at the difference (if there is any) and work it out.
chris_RA40
Re: Hilux diff conversion? Wed, 22 May 2002 02:06 Go to previous messageGo to next message
Thanx for the help Smile
chris
Darren
Re: Hilux diff conversion? Thu, 23 May 2002 11:36 Go to previous messageGo to next message
My RA40 diff was 1415mm.
Darren.
Fattony
Re: Hilux diff conversion? Thu, 23 May 2002 11:45 Go to previous messageGo to next message
This is just rough costing, but for my RA23 i was told that the diff centre itself was about $450, and about $1000 to get the whole thing hooked up, re-spline and shorten axles etc.
Re: Hilux diff conversion? Thu, 23 May 2002 12:02 Go to previous messageGo to next message
Darren wrote on Thu, 23 May 2002 9:36 PM
Darren.
There you go, no need to do anything except to weld on the mounts.
Re: Hilux diff conversion? Thu, 23 May 2002 12:08 Go to previous messageGo to next message
What about fitting disk brakes to the hilux diff? any ideas?
Re: Hilux diff conversion? Thu, 23 May 2002 21:50 Go to previous messageGo to next message
Whatever disc/caliper combo you end up running, you will need a caliper mounting bracket made up. I'll be running 300 mm Merc discs with Volvo 4 spots with no handbrake.... I suppose a handbrake is doable using a MS112 or MA61 backing plate and internal drum mechanism, but it's not something I'll be pursuing. If you want in on that parade, email me....the brackets will work out cheaper for all that way. I'd imagine a couple of hundred bucks. It wont be till the end of this year though.
Cheers Dave.
TOY77
Re: Hilux diff conversion? Fri, 24 May 2002 06:46 Go to previous messageGo to next message
G'day,
Hey Darren are you sure bout that width? it though the 40 and the 28 had the same diff? i'm sure mine is bout 1370 from outside to outside....
Another option for a diff which is what i am sorting is a volvo diff. Benefits:-
Only slightly wider that the celica
HUGE!!! axles
Got good discs already
Cheap as (about $150 - 250)
Can purchase brand new detroit locker centre for bout $1000.
At the end of the day bout $1600, but will be heaps stronger and have a better centre.
Stew
Sam
Sydney, Australia
Re: Hilux diff conversion? Fri, 24 May 2002 08:02 Go to previous messageGo to next message
Hey Stew, what ratios do the volvo's come out with, and what stud pattern?
TOY77
Re: Hilux diff conversion? Sun, 26 May 2002 01:24 Go to previous messageGo to next message
The volvos come with a huge range of centres. but you won't find one of the factory lsd's, they are rare as - only came out behind the turbo. but if you are buying one of the after market centres you can choose your ratio.
As for the stud pattern, they are 5 stud, part of the cost to convert it to fit the celica included chaging the stud pattern to the celica.
Stew
Re: Hilux diff conversion? Sun, 26 May 2002 12:47 Go to previous message
Hey Stew, What length are the Volvo diffs? And what size are the disks?
And what model of Volvo are we talkin about here? Are the diffs all the same?
Shane
Previous Topic:motor sport
Next Topic:making a web forum
Current Time: Sun Oct 25 22:27:04 UTC 2026
Total time taken to generate the page: 0.0045881271362305 seconds
