Toymods » Tech & Conversions » how to change fuel filter
papercut
how to change fuel filter Tue, 06 July 2004 04:25
hi guys,
i've done my searching and the best i could find was this post from someone giving tips on changing the filter:
mk1sc wrote on Wed, 23 June 2004 17:59
pretty much oil filter is covered, just remember to replace new sump plug washer aswell. running engine to optimal temp will speed up the draing heaps faster, shouldnt take more then few minute
fuel filters little trickier.
-firstly, before undoing any bolts/nuts make sure u release the pressure out of the system by removing the fuel cap, disconnecting the fuel pump either thru fuse or unplug the fuel pump connector usually located somewhere under rear seat then crank the engine til it stalls
-typical toyota filter u need 14mm pipe spanner, 19mm open end spanner and 17mm ring spanner or socket preferably single hex.
-always use open end spanner to hold the neck of the filter when cracking the bolt to take inlet and outlet pipe off otherwise u end up twisting or breaking the pipe.
-then undo bolt from brackets that hold filter and swap them over if necessary. remember to replace or put back any washers u taken out otherwise it will leak and might not start
-note: try not to look at directly at hose etc.. when disconnecting them otherwise there might still be pressure build up and not very good sight when fuel start sprayin in the eye
It makes sense, but i just need some opinions and tips. my current filter is a Ryco item and i just wanted to straight replace it with the same one. Would Crimping both sides do the trick?
anyone? advice?
Previous Topic:mustard colour on a ms85
Next Topic:Custom Wheels
Current Time: Tue Oct 27 03:51:41 UTC 2026
Total time taken to generate the page: 0.086713790893555 seconds
