Toymods » Tech & Conversions » corona/pug/hilux convo for a different car
Mr DOHC
corona/pug/hilux convo for a different car Tue, 06 July 2004 10:34 Go to next message
i have just found out my calipers, pads, rotors and M/C are fucked, Mad
and i was looking at the XT130/pug/lux convo for the RA23/28/40 celicas and have done some researching
from what i am lead to beleive, u dont need different wheel bearings from the std XT130 {since u r using the stub axle from an XT130}, is this correct.
If it is, then i am safe assume it'll fit my RT104 cause the XT130 and the RT104 use the same bearing kit.
I asked about the LN106 calipers from my local wrecker, he quoted me $75 each, is that worth it.
I can buy the DBA rotors {DBA272} from my work nice and cheap {115 each side for slotted or 91 for std} and my brother in law works for aussie auto so i can get the pads/bearings cheap too. Very Happy
i can use a 1" bore XC master cylinder which is basically a bolt up unit except for a bit of messing around with moving the piping ans maybe a slight adjustment to the boosted rod length.
but i just had a look and i have a 7/8" bore already, and i was told by a 25 year veteran to the brake industry that a 7/8" would be ok. what do u think
where do u measure the bolt holes from, for the caliper to bracket measurement
Quote:
CALIPERS: Hilux 4WD 4 piston items (front). These are off model no. LN106 (1989-1993), with this being the most common model found at 4WD wreckers with these calipers fitted (they are also fitted to later model Hilux's, but I don't know if the mounting bolt holes are the same). The mounting bolt holes should be 90mm apart.
because if my car has different all this effort is shot to shit Confused
i have worked out the price to be
rotors $116 x 2
pads $110 for ultimates
calipers $75 x 2
new master cylinder $100
bearings $30 kit
$600 odd
does that sound like a good price
[Updated on: Thu, 08 July 2004 09:55]
GOT_M.I.L.F.
adelaide
Re: brake upgrade for my ride Tue, 06 July 2004 12:59 Go to previous message
No Message Body
Previous Topic:What happens with no Oxy sensor
Next Topic:Ct26 going into Sv21
Current Time: Mon Oct 26 14:21:19 UTC 2026
Total time taken to generate the page: 0.030677080154419 seconds
