Toymods » Tech & Conversions » 4k swap
sykotic
New Zealand
4k swap Tue, 06 July 2004 12:28 Go to next message
Hi all,
Can someone tell me if there are any engines out there that will drop into the mount for a toyota 4k?
My beach buggie has a 4k in it and the head has cracked, hehe, its spent to long at 7000 rpm (or wateva it redlines at when the thottle is wide open, i don't have a tacho on it)
Thanks.
alex_ta22
Newcastle, Hunter Valley
Re: 4k swap Tue, 06 July 2004 12:41 Go to previous messageGo to next message
5k? 7k?
sykotic
New Zealand
Re: 4k swap Tue, 06 July 2004 12:47 Go to previous messageGo to next message
both the 5k and the 7k have the same mounts as the 4? hmm, ok, that gives me a bit more freedom (basically first decant motor i come across that fits ill buy). Are the 5k and 7k injected or carb?
Ramtech
Tasmania
Re: 4k swap Wed, 07 July 2004 06:18 Go to previous messageGo to next message
slot the mounts on a 2tg and it will fit. might have to play with rubber sections aswell. but it would be more fun than a k
sykotic
New Zealand
Re: 4k swap Wed, 07 July 2004 09:49 Go to previous messageGo to next message
Whats a 2tg? carbed or injected? reason is because the engine i use will get a VERY hard life, and i think carbed will handle it better. I'm very surpirsed at how long the 4k lasted accutly.
Thank you.
Ramtech
Tasmania
Re: 4k swap Fri, 09 July 2004 01:07 Go to previous messageGo to next message
2tg= dohc 8 valve 1600cc twin carb or efi. go to for sale there is a twin carb 2tg for sale i think for $600. just do a google search of 2tg and you will find heaps of stuff. also go here http://www.geocities.com/jonnyr_1973/ the reason i say this is because this dude has put a 2tg in place of a k engine. just about all the info you need
[Updated on: Fri, 09 July 2004 01:08]
sykotic
New Zealand
Re: 4k swap Fri, 09 July 2004 08:41 Go to previous message
Ok, thanks for that info, ill go have a read. And unfortunly i live in NZ, so the for sale forum isnt much help. Thanks tho.
--Sykotic
Previous Topic:Smallest stock box air filter known to man?
Next Topic:What aftermarket cams duration and lift do i need? Going for set of TODA Cams
Current Time: Thu Nov 19 03:46:57 UTC 2026
Total time taken to generate the page: 0.005681037902832 seconds
