Toymods » Tech & Conversions » Fixing coolant leak
demuire
Ipswich
Fixing coolant leak Tue, 06 July 2004 22:39 Go to next message
Right, I've got this SV21 Camry. Sort of a drivearound car.
Anyway, driving around town the car is great, very smooth, no issues or anything. Then I took it long distance on the weekend, and it appears that when I drive it long distance it loses radiator coolant - I'm guessing when driving for long distance the coolant pressure builds enough to leak out?
On closer inspection, it appears to have seeped out from somewhere between the head and block, could perhaps be head gasket?
Apart from ripping the head off and stuff is there any easier way to fix this? I think I've seen some sort of stuff you put in your radiator that fixes leaks? Someone else told me to put ground pepper in the radiator??? Does any of that work?
Re: Fixing coolant leak Tue, 06 July 2004 22:43 Go to previous messageGo to next message
No, none of that works beyond a dodgy stop-gap measure. If your headgasket is blown, there's only one way to fix it... get your wallet out!
demuire
Ipswich
Re: Fixing coolant leak Tue, 06 July 2004 23:00 Go to previous messageGo to next message
Oh darn, oh well... Hmm, never taken an engine apart before, this could be interesting Smile
Re: Fixing coolant leak Tue, 06 July 2004 23:27 Go to previous messageGo to next message
It might end up being cheaper to swap in another engine. 3S-GE conversion perhaps? Smile
demuire
Ipswich
Re: Fixing coolant leak Tue, 06 July 2004 23:40 Go to previous messageGo to next message
Cheaper? How expensive would a head gasket be?
And haha, no Smile Tempting, but no Smile It's a Camry. Camry's don't go fast. Especially white ones of the wagon variety Smile If an engine swap is required (after all mine has done almost 320000k's) then I think another 3SFE would suffice...
I think my money is better spent playing with the Corolla (LSD and cage and hydrolic handbrake would absolutely kickass at the moment... Need to win a lottery sometime soon)
[Updated on: Tue, 06 July 2004 23:41]
Celica_John
Re: Fixing coolant leak Wed, 07 July 2004 03:00 Go to previous messageGo to next message
it could be a welsh plug?
demuire
Ipswich
Re: Fixing coolant leak Wed, 07 July 2004 03:04 Go to previous messageGo to next message
Possible, and I thought about that at first (because at first I saw that there was a bit of coolant sitting in the middle of the welsh plug) but upon closer inspection it looks like it's seeping INTO the welsh plug and not around it, as in from above, where the head meets the block. Well, that's what it looks like anyway...
Bugman
Re: Fixing coolant leak Wed, 07 July 2004 03:10 Go to previous messageGo to next message
sounds about the right kms for a welsh plug to go.
demuire
Ipswich
Re: Fixing coolant leak Wed, 07 July 2004 03:21 Go to previous messageGo to next message
Hmm, maybe. How do I check if it is the welsh plug or something else? It doesn't leak when the engine is just running at idle, and even rev'ing it doesn't get it to leak...
Is it expensive to get a welsh plug replaced?
M.J.H
Re: Fixing coolant leak Wed, 07 July 2004 04:28 Go to previous messageGo to next message
Why don't you take it to a workshop and let them have a look at it for you,just don't tell them what you think is wrong.
If it is the headgasket and you haven't done one before then it might be cheaper for you to get them to fix it,or there is some copper sealer stuff that is meant to work a treat.With 320 klms it might be the best option.At least then you can still drive it till it stops then do a eng swap with the money you save.
demuire
Ipswich
Re: Fixing coolant leak Wed, 07 July 2004 04:37 Go to previous messageGo to next message
MJH: Erm... For some reason I didn't really understand that... Surely my bumbling around to change the headgasket would end up cheaper than getting a workshop to change it for me (which would become parts plus labour instead of just parts plus my time)?
And umm... drive it till it stops and then do an engine swap?
M.J.H
Re: Fixing coolant leak Wed, 07 July 2004 07:12 Go to previous messageGo to next message
demuire wrote on Wed, 07 July 2004 14:37
Why not.
With 320,000 klms on the eng it's going to be tired,new H/G or not.
If it was my car i would put some sealer in like chemiweld or seal up(?) and just keep driving it.Save the $$$ and get a new mtr when it finally shits itself.
But it's your car and if you want to do the H/G then go for it,i was just offering my opinion.
people100
Rocklea qld
Re: Fixing coolant leak Wed, 07 July 2004 07:31 Go to previous messageGo to next message
organise a time with me and bring it around. Ill get the pressure pump from work and we can sort out exactly what it is.
Celica_John
Re: Fixing coolant leak Wed, 07 July 2004 07:42 Go to previous messageGo to next message
Your talking about swapping the engine over something that could be as simple as a $3.95 welsh plug. :s
My mate has 350,000+ kms on his car and its still going strong.
My car has only done 30,000 kms since we put a reco engine in and now its just out of warranty and the engine is blowing white smoke.
Just something to consider. . .
Celica_John
Re: Fixing coolant leak Wed, 07 July 2004 07:43 Go to previous messageGo to next message
Btw its a 3sge gen1 thats blowing the smoke
M.J.H
Re: Fixing coolant leak Wed, 07 July 2004 07:56 Go to previous messageGo to next message
Celica_John wrote on Wed, 07 July 2004 17:42
No.I thought i made it clear i was talking bout if the headgasket needed doing.
joecoolmk2
Re: Fixing coolant leak Thu, 08 July 2004 09:17 Go to previous messageGo to next message
it could also be the manifold gasket, tighten the bolts on that and see if it still leaks. put some maniseal around the area too just to be sure.
Mr*Beach
Re: Fixing coolant leak Fri, 09 July 2004 07:48 Go to previous messageGo to next message
Cheap option is a bottle of chem-i-weld and an engine swap somewhere down the road when the motor blows up, but what i would (and did) do is rip the head off, get it serviced (new guides and seals, acid dip and a machine.
The machine + pressure test is just about essential with a headgasket because when the engine got hot enough to blow the gasket it could have warped or even cracked the head). Then replace the gasket, put it all back together (with much care, ofcourse) and cross your fingers that the bottom end holds strong for as long as you own the car.
A head service should cost you no more than $400 anywhere you go. Most places will also give you a VRS kit which gives you the headgasket, manifold gaskets, cam seals and sparkplug tube seals which is everything you need. The job should take you no longer than a weekend. Good luck buddy. Hope this helps.
Mr*Beach
Re: Fixing coolant leak Fri, 09 July 2004 07:50 Go to previous messageGo to next message
<----That picture is the cause of me knowing all about this subject.
~Josh
demuire
Ipswich
Re: Fixing coolant leak Fri, 09 July 2004 12:36 Go to previous message
joecoolmk2: Umm... as in exhaust manifold gasket? Why would that cause it to leak?
MrBeach: Thanks for that... Hmm. Okay, that's a bit more than what I was hoping to spend... Will think about it.
Previous Topic:How much does it cost to rebuild an engine ?
Next Topic:corona/pug/hilux convo for a different car
Current Time: Wed Nov 18 23:09:00 UTC 2026
Total time taken to generate the page: 0.0074770450592041 seconds
