Toymods » Tech & Conversions » R154 output shaft bush ?? anyone help ??
slylux
perth WA
    nup
R154 output shaft bush ?? anyone help ?? Wed, 07 July 2004 11:40 Go to next message
i have got my r154 gearbox out for repair .. suspect thust washer broken .. well its not broken but i will upgrade it while it apart .. BUT also the rear seal where the slip yoke / tailshaft goes in, ive replaced it 4 times .. it still leaks oil!! while its out i wanna replace a bush that is in the housing , but toyota dont list this as a part .. i even have a downloaded manual for the gearbox and still no luck .. looks like a white metal bearing ... has anyone ever replaced it ???
or do i have to get a custon one made
Stenno
Re: R154 output shaft bush ?? anyone help ?? Wed, 07 July 2004 21:19 Go to previous messageGo to next message
I've never heard of this bush on the output shaft you speak of - it's possibly added during casting of the rear housing?
I'd be looking at your slip yoke if you've replaced that seal 4 times and it still leaks. You're using the correct rear seal?
slylux
perth WA
    nup
Re: R154 output shaft bush ?? anyone help ?? Wed, 07 July 2004 23:20 Go to previous message
yes its the correct seal .. slip yoke doesnt have grooves or notches in yoke , only thing it could be is someone has machined the yoke . or the bush is stuffed .. there has to be a replacement , toyota arent goin to have it supported on the alloy casing .. this is white metal bearing and also looks lik it will press out easy enough ..
Previous Topic:Help Need With 1ggze Blower Pls
Next Topic:URGENT - AE86 Rear Spring Size
Current Time: Thu Oct 22 07:47:56 UTC 2026
Total time taken to generate the page: 0.0041699409484863 seconds
