Toymods » Tech & Conversions » AE86 Steering/Suspenison delima?
FKN16V
NSW, East Coast
AE86 Steering/Suspenison delima? Wed, 07 July 2004 12:41 Go to next message
Ive had the car for about 2yrs, and this delima has been seen by all the (so called) steering and suspesion expert.
When driving along a smoothish road all is fine, but when i drive over a series of potholes/bumps general bad condition road , i get a weird knocking sound/feel thru the steering wheel, like something is loose/broken, ive been the 4 different shops and they cant find anything. I got a whell balance and alignment, that helped a liitle but the same noise is still there.
Any idea's, has someone dealt with this before.
TE72_Turbo
Re: AE86 Steering/Suspenison delima? Wed, 07 July 2004 13:23 Go to previous messageGo to next message
Have you checked the large nuts that hold the front strut cartridges inside the strut leg? If these are not down tight against the cartridge, then the cartridge can move around inside the strut making a knocking noise.... Its quite loud, you'd definately notice it. A reputable steering specialist once left mine loose after doing some work on my suspension, took a while to figure out what was wrong.
Phil
FKN16V
NSW, East Coast
Re: AE86 Steering/Suspenison delima? Thu, 08 July 2004 10:38 Go to previous messageGo to next message
TE72_Turbo wrote on Wed, 07 July 2004 23:23
Phil
thanks for the reply Phil, i can only assume that when i say "check everything" these so called professionals did just that "check everything"
I intend on jacking the car up on the weekend and giving "everything i can think of" a look at.
I intend on checking,
struts: rubbers/nuts&bolts
coil/spring: make sure its seating/seated properly.
control arms: rubbers/cracks
If anybody else can suggested area's i should check please do?
Cheers Phil
Steve
Re: AE86 Steering/Suspenison delima? Thu, 08 July 2004 10:47 Go to previous messageGo to next message
Check out the uni joint on the top of the rack - I had a similiar problem with mine, I always presumed it was just wear in the rack, until I decided to check it out one day.
Rex_Kelway
Re: AE86 Steering/Suspenison delima? Thu, 08 July 2004 11:20 Go to previous messageGo to next message
Rex has this problem also, quite horrific really. He's narrowed it down to a set of fucked dampers and 3mm or so freeplay in each rack-end.
Flogbag
Sydney (Campbelltown...!)
Re: AE86 Steering/Suspenison delima? Thu, 08 July 2004 11:23 Go to previous messageGo to next message
wat about your sway bar link rubbers when there worn out they make that kinda noise
also check play in the steering rack as on my sprinter the end bush in the rack is worn and when i go over pot holes i get a clunk knock noise
Dodgy_Haro
Re: AE86 Steering/Suspenison delima? Fri, 09 July 2004 01:37 Go to previous messageGo to next message
mrshin wrote on Thu, 08 July 2004 20:47
Check out the uni joint on the top of the rack.
Ever price a lower uni-joint for an AE86?
Over $200 from Toyota ... Sad
dcleyne
Re: AE86 Steering/Suspenison delima? Fri, 09 July 2004 07:05 Go to previous messageGo to next message
Probably not applicable in your case but...
I had a knock/shudder develop in the steering on my '86. Turned out the steering wheel was just ever so slightly loose on the boss. When I went to put the new Boss Kit on I discovered it. Up to that point I thought the rack might be on it's way out.
Dan
FKN16V
NSW, East Coast
Re: AE86 Steering/Suspenison delima? Fri, 09 July 2004 12:17 Go to previous messageGo to next message
I had a good look at it today and everything appears intake except the uni joint you refer too, the drivers side has roughly 3-4mm play in it, i can only assume this is wear the noise is coming from.
Thanx for all the reply's, i will check all of your suggestions and post my findings.
FKN16V
NSW, East Coast
Re: AE86 Steering/Suspenison delima? Fri, 09 July 2004 12:22 Go to previous messageGo to next message
Dodgy_Haro wrote on Fri, 09 July 2004 11:37
Any suggestions where to get one cheaper?
Steve
turbokid
Re: AE86 Steering/Suspenison delima? Sun, 11 July 2004 11:03 Go to previous messageGo to next message
along with what dcleyne said. check that your steering wheel is fully on.
Re: AE86 Steering/Suspenison delima? Sun, 11 July 2004 22:01 Go to previous messageGo to next message
FKN16V wrote on Fri, 09 July 2004 22:22
Steve
Sure, either buy an aftermarket branded one, or do what I did, take the joint in one hand, walk up to a big shelf full of junk in your shed, scrounge around, and smile when you have one that matches. From memory mine was from a 50K old AE92 half cut
[Updated on: Sun, 11 July 2004 22:01]
dar_sbb
Re: AE86 Steering/Suspenison delima? Sun, 11 July 2004 23:54 Go to previous messageGo to next message
Do u have the right bump stops on?
Bobski
Re: AE86 Steering/Suspenison delima? Mon, 12 July 2004 10:50 Go to previous messageGo to next message
hmm seems like every1 has this problem....does it happen when u slowly reverse off a curb/driveway if u dont firmly hold the wheel?
If so then more then likely it will be the uni joint, both my cars have the problem so i cant even swap the uni between em Neutral
i think it might be caused by rubbing curbs at speed Smile
FKN16V
NSW, East Coast
Re: AE86 Steering/Suspenison delima? Mon, 12 July 2004 11:08 Go to previous messageGo to next message
dar_sbb wrote on Mon, 12 July 2004 09:54
Ive never changed anything, all original except fo the springs, 30mm lower and a whiteline front sway bar, I definatly know there is a noise coming from the uni joint at the end of the rack, i might just buy from toyota, unless someone has some they would like to sell. I need my car for work everyday so its a little hard to take it of the road and search for parts.
MRSHIN you say look for aftermarket ones but i wouldnt know where to start looking, can you suggest someone.
Steve
FKN16V
NSW, East Coast
Re: AE86 Steering/Suspenison delima? Sat, 18 September 2004 12:01 Go to previous message
Turns out that the left control arm bushes were shot, and the actual steering rack was completly rooted, all fixed, im happy now.
Cheers everyone
Steve
Previous Topic:Getting 15's from a 2TG...ideas?
Next Topic:Want to turn over an engine that's been sitting for a few months...[1GGTE]
Current Time: Mon Oct 19 17:53:49 UTC 2026
Total time taken to generate the page: 0.0068578720092773 seconds
