Toymods » Tech & Conversions » What Turbo???
gabe
What Turbo??? Mon, 09 September 2002 04:48 Go to next message
time to pick your brains again guys....
The turbo on my 3t-gte siezed over the weekend. Mad should i get it rebuilt(quoted $800), get a garret t28 i have rebuilt(quoted $800) or fit a turbo off a '90 model lancer gsr for $400. are the lancer turbos any good??keeping in mind it is 12 years old.
any advice appreciated.
thanks.
FLY PSI
Re: What Turbo??? Mon, 09 September 2002 09:55 Go to previous messageGo to next message
either go the reco or try and pick up one from the paper that is in good nic,then you could get something a little larger Very Happy
Chriph
Re: What Turbo??? Mon, 09 September 2002 10:22 Go to previous messageGo to next message
I wouldn't bother getting the stock turbo rebuilt, I did that with mine and $750 later I still had the same shitty little turbo. I'd try and replace it with a ct26 from a supra, they bolt up pretty much the same (I think you need a little mounting plate made up but it's a pretty simple job) and it flows a hell of a lot more, certainly on the exhaust side of things, though you'll also need to get a new dump pipe made up (also pretty simple), though you can often buy them with them attached. You can get them in decent condition for around $400. When I had the exact same thing happen to me a few years ago I unfortunatly got a ct26 off an mr2 and it's a fair bit different to the supra one (it was stuffed anyway so I sent it back) so I got a hold of a Garrett T3, this required a fair bit more pain to put on than the ct26 though they are comparable in their operation. The swap gave my 3t-gt a fair bit more kick, particularly up in the higher revs and was smoother too, it certainly didn't take any longer to spool up than the old ct20 so you've really got nothing to lose in the swap. The ct26 also has a hell of a lot more scope in terms of future modification to tailor it to your engine and any other mods you do (changing turbine and compressor wheels and the like). If you needed just a short term fix someone on the forum might have a spare ct20 lying around that you caould pick up for $150-200 that would keep you going for a while while you plan a better upgrade (i've often seen them posted). Good luck, Chris.
Purple_Beasty
New Zealand
icon14.gif  Re: What Turbo??? Mon, 09 September 2002 10:53 Go to previous messageGo to next message
The Supra CT26 doesn't need a mounting plate, apparently you just slot the holes on the turbo a few mm for it to bolt onto the standard manifold. May also pay to to give the manifold a quick porting job to improve flow.
(read this in a previous post so don't blame me if it is wrong, all sounds very feasible)
gabe
Re: What Turbo??? Tue, 10 September 2002 01:46 Go to previous messageGo to next message
very helpful thanks.
does anyone know wot the lancer gsr turbos are like??
im only thinking this because it is the cheaper option
Re: What Turbo??? Tue, 10 September 2002 02:19 Go to previous messageGo to next message
Tiny comes to mind.
FLY PSI
Re: What Turbo??? Tue, 10 September 2002 03:24 Go to previous messageGo to next message
I now have a T3 that is for sale Very Happy so let me know if you are intrested!i will take around $450 Very Happy
gabe
Re: What Turbo??? Tue, 10 September 2002 04:20 Go to previous messageGo to next message
wot condition is it in??
can it be arranged to be freighted to perth???
FLY PSI
Re: What Turbo??? Tue, 10 September 2002 04:26 Go to previous messageGo to next message
it was rebuilt just before i got it & i have done about 2000k,s since then Very Happy but then the motor died Mad i will look into the freight thingy!
lvn-ra65c
Wichita, Ks, USA
Re: What Turbo??? Tue, 10 September 2002 22:12 Go to previous messageGo to next message
anyone tried an upgraded supra ct26 on the 3tgte?
i'm about to get my ct26 rebuilt/upgraded and want to know what the best option would be. Since my 2nd ct20 is deciding to call it quits Mad ...exhaust is starting to smell really bad :-
[Updated on: Tue, 10 September 2002 22:15]
Re: What Turbo??? Wed, 11 September 2002 00:56 Go to previous messageGo to next message
I'd probably suggest you fit a standard CT26, try it out, see how you like the feel of it. If you think you could live with a bit more lag, then get it upgraded, if not just get it rebuilt (if it needs it)
lvn-ra65c
Wichita, Ks, USA
Re: What Turbo??? Wed, 11 September 2002 01:09 Go to previous message
the ct26 i have needs a rebuild so that's why i'd like to maybe upgrade it at the same time also.
Previous Topic:how low can i go ???
Next Topic:1JZ Alternator Problems
Current Time: Fri Nov 20 10:25:11 UTC 2026
Total time taken to generate the page: 0.005605936050415 seconds
