Toymods » Tech & Conversions » AE82 4AGE Air Con advice needed
Toby AE82 Twin
Travelling overseas
AE82 4AGE Air Con advice needed Mon, 09 September 2002 05:06 Go to next message
My twinky does not have air conditioning and as the weather is starting to warm up a bit I want to have a crack at installing air conditioning myself.
Couple of questions:
What parts do I need?
How much do I need to spend on the parts roughly?
How much work would it be and would I need any specialised type tools/equipment?
Any other advice on air con appreciated.
Toby
haggis
Re: AE82 4AGE Air Con advice needed Mon, 09 September 2002 05:50 Go to previous messageGo to next message
Head down to your local aircon place and ask them a few questions. I looked into it my self at one time, and while its poiisble, it could be annoying. For example, if you get one rubber component in the system that doesnt like the gas, it could cost a lot to repair the aircon system. The differences betweem R12 and Rwhatever it is these days are considerable.
Mechanicly, it isnt too hard to install the components (except mabey getting at the parts under the dash!!) and its worth the money to get a professional to look over it before filling it with gas. You will need to get someone who has the right equipment and qualification to regas the system.
Most parts are probably available from a jap wreckers, so you may be able to get a complete setup form there.
I have no idea on the cost tho...
Craig.
Toby AE82 Twin
Travelling overseas
Re: AE82 4AGE Air Con advice needed Wed, 18 September 2002 04:02 Go to previous messageGo to next message
I spoke to someone who reckoned it would cost around $1500-1800 to get it professionally done!!
I was also told that it would be very very difficult job to do myself.
Might just have to get hot in summer I think Crying or Very Sad
rollaboy
Coffs
Re: AE82 4AGE Air Con advice needed Wed, 18 September 2002 05:06 Go to previous messageGo to next message
My AE82 4AGE is missing the compressor, so if i got a compression and tooked it up do i only have to get it re-gased??
or is there something else i have to get done??
Toby AE82 Twin: does ur ae82 have power steering??
haggis
Re: AE82 4AGE Air Con advice needed Wed, 18 September 2002 05:19 Go to previous messageGo to next message
Rollaboy: In theory yes, thats all you would need to do.
In reality, you would need to give the system a check over, and make sure the absence of a compressor hasnt let any unwanted bits get into the system, and that the rest of the system hasnt degarded too much. You might well need a new condensor (or valve thingy). They usualy need replaced if the system has been idle for a long time any way.
Also, you would have to get a compressor that is compatable with the same gas the the rest of the system used to run, other wise you may need to rebuild the compresor or the rest of the system to be compatable. The older R12 and the new R(whatever it is) will destroy any gaskets that are ment for the other type of gas.
Craig.
Toby AE82 Twin
Travelling overseas
Re: AE82 4AGE Air Con advice needed Mon, 23 September 2002 08:38 Go to previous messageGo to next message
Brett
Yeah I do have power steering, why do u ask that?
Toby
rollaboy
Coffs
Re: AE82 4AGE Air Con advice needed Mon, 23 September 2002 10:53 Go to previous messageGo to next message
Because i have heard that the AE82 twin cams never came out with both p/s and a/c, there was a opinion or something..thats what i have been told.
Sorry about that i think i was prob half asleep.
[Updated on: Tue, 24 September 2002 02:36]
Toby AE82 Twin
Travelling overseas
Re: AE82 4AGE Air Con advice needed Mon, 23 September 2002 23:04 Go to previous messageGo to next message
Your post doesn't make sense Brett??
rollaboy
Coffs
Re: AE82 4AGE Air Con advice needed Tue, 24 September 2002 05:33 Go to previous messageGo to next message
Toby AE82 Twin
What does your twincam idle at??
What kinda Revs does it do in 5th doing about 100km/h??
Youngy
Eskilstuna, Sweden
Re: AE82 4AGE Air Con advice needed Tue, 24 September 2002 14:38 Go to previous messageGo to next message
A little off topic but will help.
Myself and a friend of mine both have AE86s and we have converted his car to air-con and are in the process of doing mine. Sourced all the parts (condensor, evaporator, compressor, hoses etc) from a wreck for less than 500 bucks.
Put is all in ourselves, not hard at all! And then off to pro to get pressure tested and regassed as well as the idler set. To re-gas the thing they change the valves to the new gas standard etc. All for just over 200 bucks.
Sweet.
Toby AE82 Twin
Travelling overseas
Re: AE82 4AGE Air Con advice needed Wed, 25 September 2002 00:51 Go to previous messageGo to next message
When I start it and its cold, it idles at around 1500-1900. I was told this was too high. But when it warms up it drops down to around 900 so I thought thats ok.
In 5th at 100km/h I think its about 3500rpm then 4000rpm at 120km/h.
What does your idle @ and @ 100km/h?
I'll ask the question in the general forum about p/s & a/c, see if anyone knows.
Thanks for the imput Youngy, sounds like it might be a goer then.
[Updated on: Wed, 25 September 2002 00:52]
rollaboy
Coffs
Re: AE82 4AGE Air Con advice needed Wed, 25 September 2002 01:05 Go to previous messageGo to next message
When warm it idles at about 2500rpm and when hot about 1000-1100.
At a 100 km/h i forget so i'll have a look today.
Whats your timing at?? Mines at 35degs which i think is way to much. I think its making my car want to stall.
Youngy: Thanks heaps I'll prob get a compressor now and go get it regased.
rollaboy
Coffs
Re: AE82 4AGE Air Con advice needed Thu, 26 September 2002 03:50 Go to previous messageGo to next message
100km/h in 5th @ 3300-3400
80km/h in 5th @ 2600-2700
80km/h in 4th @ 3200-3300
60km/h in 2nd @ 4600-4800
Is it easy to change the timing???
Toby AE82 Twin
Travelling overseas
Re: AE82 4AGE Air Con advice needed Thu, 26 September 2002 04:26 Go to previous message
Dunno what my timing is nor do I know how to change it but from what I gather its easy to do.
Those speeds and rpm sound pretty close to mine.
Previous Topic:3S-GTE into AE86
Next Topic:SURGE when cornering ??
Current Time: Sat Nov 21 15:35:21 UTC 2026
Total time taken to generate the page: 0.0059449672698975 seconds
