Toymods » Tech & Conversions » 2 4agze Questions
GZETrueno
icon5.gif  2 4agze Questions Thu, 08 July 2004 09:12 Go to next message
There are two hoses comming out of the throttle body one of which I know goes to the charcol canister, I'm assuming I should just plug it, but where does the other go?
In the second picture, what does this screw/thing adjust?
http://www.webpages.uidaho.edu/~ward5154/Pictures_files/TB.jpg
http://www.webpages.uidaho.edu/~ward5154/Pictures_files/Thing.jpg
feral4mr2
Bundaberg, Qld.
Re: 2 4agze Questions Thu, 08 July 2004 11:39 Go to previous messageGo to next message
is there a 2 wire plug for it? could be the a/c idle up soleniod? i am not familuar with all the later model gze bits, they got a few more than the early ones had.
GZETrueno
Re: 2 4agze Questions Thu, 08 July 2004 16:11 Go to previous messageGo to next message
It does have a two wire plug comming out of it, which I didn't connect to anything. Could this be the reason the engine isn't idling? How should I adjust the valve?
feral4mr2
Bundaberg, Qld.
Re: 2 4agze Questions Thu, 08 July 2004 21:53 Go to previous messageGo to next message
thing is, my a/c idle up doesnt have that pot doobie with the vacum line out of the top of it like the one in your pic appears to have. so i cant be 100% that it is your a/c idle up.
the a/c idle up solenoid normaly only changes the idle when the a/c is turned on (raises idle to compensate the load), as long as the 2 pipes are conected correctly i cant see that it would do anything when unplugged.
have you tried winding the needle valve in or out and seen if it effects the idle in any way?
chrizer
Re: 2 4agze Questions Fri, 09 July 2004 02:03 Go to previous messageGo to next message
I think those two pipes are coming from the idle speed sensor. If so i'm pretty sure they should go to the water pipes down below. Anyone wan to correct me?
chrizer
Re: 2 4agze Questions Fri, 09 July 2004 02:20 Go to previous messageGo to next message
Just had another look. And yes i'm wrong. Embarassed Sad
GZETrueno
Re: 2 4agze Questions Fri, 09 July 2004 04:57 Go to previous messageGo to next message
The thing is I can't get the car to idle for more than a few seconds.
rolla kid
Brisbane (AUS)
Re: 2 4agze Questions Sat, 10 July 2004 08:03 Go to previous message
If you are talking about those two pipes pretty much in line with each other you will find they are vacum lines and they both run down to the pw/steering rack on the gz
Previous Topic:Good Dif workshop in Melb?
Next Topic:4A-GZE conversion into AE92 can't be easy as it sounds!?!
Current Time: Wed Nov 18 18:53:14 UTC 2026
Total time taken to generate the page: 0.0078589916229248 seconds
