Toymods » Tech & Conversions » 4agze into KE55 ?
Sik-7
Tassie
4agze into KE55 ? Thu, 08 July 2004 13:32 Go to next message
hi all,
Just want to know if its a big job to put a 4agze into a KE55 ...and what is involved?
Sik-7
Tassie
Re: 4agze into KE55 ? Fri, 09 July 2004 05:18 Go to previous messageGo to next message
bump !
Re: 4agze into KE55 ? Fri, 09 July 2004 05:32 Go to previous messageGo to next message
what do you think Wink
you need engine mounts, gearbox mounts, bigger diff, radiator, IC, wiring and evertying else that you need for putting in a motor that doesn't belong..
how hard it is depends on your abilities and cash flow.
Sik-7
Tassie
Re: 4agze into KE55 ? Fri, 09 July 2004 05:36 Go to previous messageGo to next message
Hey im new to the ke55's i wasnt sure what had to be done
Super Jamie
On Probation
North East NSW
Re: 4agze into KE55 ? Fri, 09 July 2004 06:50 Go to previous message
nobody has written a howto for doing this, perhaps i'll add a section to the faq...
but basically first you'll need to figure out some way of mounting the engine. some people make new angle brackets and rubbers, some people move the mounts on the engine crossmemeber
the t50 gearbox will bolt to the std crossmember after you drill the crossmember hole out a bit more. ke20 onwards have two sets of holes in the chassis rails to accomodate this gearbox, use the rearmost holes
you'll either need an ae86 gearbox and a custom tailshaft, or a ta22 gearbox and a custom bellhousing. search for posts on toymods by "demuire" for the trouble he's having using a ta22 t50 in his 4age ke35
actually would a gze lunch a t50 gearbox? i don't know. next step up is a w55/6/7/8 box, which will need transmission tunnel mods and an adapter plate or new bellhousing (niteparts in nz make a good one). check matti kalahati's webpage to see what cars these boxes come out of (google his name if you don't know the site)
you'll need to convert the engine to rwd, of which there is plenty of info on here and club4ag
and you'll probably shred the stock diff pretty quick. nothing "bolts in" so be prepared to spend up to $1500 for a larger diff with lsd. you will NEED lsd with this much power
and of course it will need to be engineered so talk to an engineer before you spend anything. expect at least a front brake upgrade to be required
Previous Topic:wots a good engine to put in a 76 crown
Next Topic:Cheap upgrades for more horsepower? Help please?
Current Time: Thu Nov 19 07:15:46 UTC 2026
Total time taken to generate the page: 0.012043952941895 seconds
