Toymods » Tech & Conversions » What aftermarket cams duration and lift do i need? Going for set of TODA Cams
AE86T
Forums sponsor
What aftermarket cams duration and lift do i need? Going for set of TODA Cams Fri, 09 July 2004 07:25 Go to next message
Hi guys,
I need some advice and experience with choosing some cams.
I am about to run a 4agze bottom with custom forge pistons with a 20 valve silvertop head. I have a custom exhaust manifold to bolt on an hks or s15 turbo. I have a custom plenum intake manifold made up to be used with the quad throttle bodies.
My question I will be purchasing a set of cams, valve springs, cam gears and valve train kit(if need it). What lift before i need the valve train kit, brand prob be toda.
I would like some advice on what sort of cam duration and lift will i need, I dont mind the car idling rough,What sort of cams would suit the turbo setup to extract most power? What sort of lift can i go b4 i have to get the valve train kit? Will i need to change the valves to something stronger because of running force induction? I was thinking something along the lines of 272 duration and 9mm lift. Is this too much?
Advice and opinons please
Joshstix
Toymods Vice President
Re: What aftermarket cams duration and lift do i need? Going for set of TODA Cams Fri, 09 July 2004 07:50 Go to previous message
You really should be asking these questions of your cam supplier, if they can't answer them then go to someone who can.
You will need stronger valve springs both for the bigger cams and the fact that there will be pressure behind the intake valves trying to push them open.
Previous Topic:4k swap
Next Topic:Carby overhaul??
Current Time: Thu Nov 19 04:13:25 UTC 2026
Total time taken to generate the page: 0.027997016906738 seconds
