Toymods » Tech & Conversions » filer neck/fuel pressure
mrf_ool
Taree (4 hrs north of syd...
filer neck/fuel pressure Fri, 09 July 2004 13:43 Go to next message
mates got ae86 with rwd 4age fitted and its got a problem left it in the sun all day and the tank pressurised and started pissing out fuel .. do i just have to put a breather in in the neck but do we just t piece it to the chacoal line..
[Updated on: Fri, 09 July 2004 13:46]
Callifo
Gawler, SA
Re: filer neck/fuel pressure Fri, 09 July 2004 13:55 Go to previous messageGo to next message
I had this problem and it was because the fuel caps seal had gone, fixed it by buying another from toyota @ $37.
FKN16V
NSW, East Coast
Re: filer neck/fuel pressure Fri, 09 July 2004 22:51 Go to previous messageGo to next message
mrf_ool wrote on Fri, 09 July 2004 23:43
Fuel cap should have a pressure release built into it, i say replace the cap or drill a TINY hole in the one you have.
Steve
Fattony
Re: filer neck/fuel pressure Sat, 10 July 2004 01:17 Go to previous message
Um your tank should already be quiped with a breather, and the purpose that serves is to stop your tank becoming to pressurised when you fill it up. Otherwise you would be standing at the petrol bowser with the pump clicking the shit out of it self. I wouldnt go drilling holes in your fuel cap its ment to be pressurised when the cap is on. Your tank venting is done via the tank vent line which runs to your charcoal canister. You are not ment to have fuel vapour spilling out into the air. Check your charcoal canister for a clog or your tank vent lines.
Previous Topic:1GGTE injectors
Next Topic:idle playing up on sv21 camry
Current Time: Wed Nov 18 13:13:15 UTC 2026
Total time taken to generate the page: 0.0059661865234375 seconds
