Toymods » Tech & Conversions » idle playing up on sv21 camry
OnAHigh
idle playing up on sv21 camry Fri, 09 July 2004 17:37 Go to next message
hey guys,
as the title says my idle is playing up.Here what happens, after downgearing from second, whether you put it in first or neutral as soon as you press the clutch, the idle quickly jumps to about 2000.
but if i just tap the accelerator the idle drops down to normal operating temperature straight away. This only happens after pressing the clutch when downgearing from second. Any guys have any idea or suggestions to where i should be looking to fix this problem?
dave
FKN16V
NSW, East Coast
Re: idle playing up on sv21 camry Fri, 09 July 2004 22:34 Go to previous message
Heres a few things i do when idle is what it should be,
Clean throttle body with carby/throttle cleaner thoroughly
clean airfilter or replace it which ever apply's
thoroughly clean pcv
set timing if needed
set idle if needed
See how that goes
CHeers
Steve
Previous Topic:filer neck/fuel pressure
Next Topic:Custom engine mounts
Current Time: Wed Nov 18 13:46:00 UTC 2026
Total time taken to generate the page: 0.066438913345337 seconds
