Toymods » Tech & Conversions » 1JZ-GTE Single turbo conversion. How common?
deskjob
Milky Way
1JZ-GTE Single turbo conversion. How common? Sat, 10 July 2004 10:34 Go to next message
People,
As you can see this is my first post at toymods. That said, I would like to start of with a typical newbie question.
The 1JZ-GTE....
My understanding is that the current model is a single turbo VVTI hotstick. Apparently its an outstanding engine. However, the older version are twin tubo non-VVTI and have some issues.
Is converting one of the older model 1JZ engines to single turbo as fairly straightforward job? Is it a common conversion? Is it expensive?
Remember... first question, so please be gentle...
YelloRolla
On your mum!
Re: 1JZ-GTE Single turbo conversion. How common? Sun, 11 July 2004 00:30 Go to previous messageGo to next message
converting to single turbo should be no more of a job than fitting a single turbo to any six cylinder.
The manifolding, exhaust system, and pipe work are the main issues. Apart from that, paying attention to water lines and oil lines so that they are reliable is the only other area to consider (how hard could it be?).
Good luck
Jag7799
Re: 1JZ-GTE Single turbo conversion. How common? Sun, 11 July 2004 00:43 Go to previous messageGo to next message
"issues".. what issues may these be?.. i havent had any with mine.. great engine
when you can buy complete single turbo conversion kits it cant be hgard right?
Re: 1JZ-GTE Single turbo conversion. How common? Sun, 11 July 2004 01:04 Go to previous messageGo to next message
you are aware that 220 rwkw is a fairly easily obtainable figure on the stock turbos, aren't you?
Jag7799
Re: 1JZ-GTE Single turbo conversion. How common? Sun, 11 July 2004 01:15 Go to previous messageGo to next message
draven wrote on Sun, 11 July 2004 11:04
though if u try and claim it u get flamed Razz
deskjob
Milky Way
Re: 1JZ-GTE Single turbo conversion. How common? Sun, 11 July 2004 02:27 Go to previous messageGo to next message
I've got no doubt that the kw are easy to come by with the twin turbo setup. I was just thinking that the single turbo would overcome any "dips" in the power curve that plague most TT engines.
As far as the mod goes... would you keep the stock ECU?
Re: 1JZ-GTE Single turbo conversion. How common? Sun, 11 July 2004 03:08 Go to previous messageGo to next message
There are no dips in the power curve with a 1JZ. You're probably thinking of the 2JZ, which has sequential twin turbos, and yes it does have a dip in the power curve as the second turbo kicks in. The 1JZ has parallel twin turbos so there are no such issues.
Re: 1JZ-GTE Single turbo conversion. How common? Sun, 11 July 2004 03:27 Go to previous messageGo to next message
depends on the car you're putting it in, if you've got a half cut, and how much power you want
generally, for less than 250rwkw I'd say keep the stock computer... it does a pretty good job of things.
if you're going to change the turbos/injectors, it's time for a new computer (or a piggyback possibly if the engine is in a jzXXXX chassis)
deskjob
Milky Way
Re: 1JZ-GTE Single turbo conversion. How common? Sun, 11 July 2004 04:13 Go to previous messageGo to next message
The 1JZ has parallel twin turbos...
Thanks for clearing that up for me, Norbie. Clearly I haven't done my homework.
Chris Davey
sunny coast, qld
Re: 1JZ-GTE Single turbo conversion. How common? Sun, 11 July 2004 04:36 Go to previous messageGo to next message
as Draven said the stock turbos are good for around 220rwkw (or 250rwkw if you are Martin Donnon Razz) The main failure is the ceramic exhaust wheels falling off due to extreme heat.
If you upgrade to a larger single turbo you will be looking at a lot of money to do it properly eg. ECU, injectors, intercooler etc. As well as making sure the driveline is able to hold the power.
Jag7799
Re: 1JZ-GTE Single turbo conversion. How common? Sun, 11 July 2004 10:37 Go to previous messageGo to next message
mine has a "dip in the power curve".. not sure why.. but you barely even notice cause ur redlining before u get a chance
http://members.optushome.com.au/jag7799/car/johal_dyno.jpg
deskjob
Milky Way
Re: 1JZ-GTE Single turbo conversion. How common? Sun, 11 July 2004 14:22 Go to previous messageGo to next message
There's a dip? Really? Cool
Chris Davey
sunny coast, qld
Re: 1JZ-GTE Single turbo conversion. How common? Sun, 11 July 2004 21:58 Go to previous messageGo to next message
johal: get some twin dumps and a real exhaust and see if still have that dip Smile
Re: 1JZ-GTE Single turbo conversion. How common? Sun, 11 July 2004 22:23 Go to previous messageGo to next message
draven wrote on Sun, 11 July 2004 13:27
Interesting theory! Inteceptors can help, but completely stock mapping + 250 at the wheels = I don't think Donnon could manage that, even down the pub! Evil or Very Mad
deskjob
Milky Way
Re: 1JZ-GTE Single turbo conversion. How common? Mon, 12 July 2004 03:55 Go to previous messageGo to next message
Pardon my ignorance... A further question about the parallel turbo setup on the 1JZ
Do both turbos spool up to supply the TOTAL boost to the engine {eg 5psi+5psi=10psi} or does each turbo only supply 3 cylinders?
Re: 1JZ-GTE Single turbo conversion. How common? Mon, 12 July 2004 03:58 Go to previous messageGo to next message
Both turbos supply equal pressure, but each supplies half the volume of air. The output of each turbo is joined before the intercooler, so the combined volume of air supplies all six cylinders.
Jag7799
Re: 1JZ-GTE Single turbo conversion. How common? Mon, 12 July 2004 05:58 Go to previous messageGo to next message
im workin on it chris.. respray 1st
and boost controller this week
dumps and exhaust are for later this year
just punctured my fm901's
260 each Sad
lucky i got road hazard insurance
acmtt
Re: 1JZ-GTE Single turbo conversion. How common? Mon, 12 July 2004 13:29 Go to previous messageGo to next message
That dip you mention on your 1JZ dyno chart, JAG7799, is fueling. Over fuelling!
When you have a fuel trimmer correctly tuned you will remove that and gain approx 10rwkw. I used the IFT made by perfect power and was happy with it to about 230rwkw. Upgraded to E-Manage since, works in progress.
My graph showed a greater dip than that before fuel trimming.
Jag7799
Re: 1JZ-GTE Single turbo conversion. How common? Mon, 12 July 2004 13:31 Go to previous messageGo to next message
yah.. my fuel atm is running as good as a std ecu can.. its 12:1 on full power
thats good for an auto ecu on man box
acmtt
Re: 1JZ-GTE Single turbo conversion. How common? Mon, 12 July 2004 13:38 Go to previous messageGo to next message
yes i noticed your AFR. its good on full power and a little rich low down.
Not bad at all, i didn't know you were running the auto ecu in limp mode. Smile
Jag7799
Re: 1JZ-GTE Single turbo conversion. How common? Mon, 12 July 2004 13:44 Go to previous messageGo to next message
its not in limp mode
the only reason they ever go in limp mode is because of people trying to wire them when they dont have the skill
if its all wired correctly and the box is swapped over it WONT go into limp mode.
obviously people tell u that cause they beleive its the ecu's fault and not their own hopeless inability to wire cars correctly Smile
my auto ecu is doing a damn fine job
acmtt
Re: 1JZ-GTE Single turbo conversion. How common? Mon, 12 July 2004 22:01 Go to previous messageGo to next message
My bad Very Happy
acmtt
Re: 1JZ-GTE Single turbo conversion. How common? Tue, 13 July 2004 09:51 Go to previous message
Its reasonably common to put a single on.
I have driven this car in the link and it performs very well. Lights up the tyres and is very responsive. An ideal single turbo. Currently producing about 250rwkw at 13psi.
http://www.lexussoarer.com/gallery.html
Previous Topic:black seals/thingys around windows (ae82)
Next Topic:TA23 with 2TGEU, what brake booster???
Current Time: Sat Nov 21 00:29:57 UTC 2026
Total time taken to generate the page: 0.015221834182739 seconds
