Toymods » Tech & Conversions » MX83 transmission question.
SIMDOG
Bayside Melbourne.
MX83 transmission question. Sat, 10 July 2004 15:02 Go to next message
My auto is doing strange things... I have searched the site and google about kickdown cables and whatnot but need to know more.
Basically the problems are this. The transmission seems to shift when it should under moderate to low throttle application. The 1st problem is that it gives a jolt when shifting from 1st to second. More of a jolt if I accelerate a little quicker.
The second, more worrying problem is that when I hammer it or accelerate hard, the transmission will allow the engine to bounce off the rev limiter before it changes gear. It will stay up at redline bouncing for about 2-3sec. Shocked Not good.
I have been told to look at the kickdown cable. Are these likely results of a poorly adjusted cable? What else could it be?
Final question. What box would I have in this car and is it a ECT?
V8_MA61
Re: MX83 transmission question. Sun, 11 July 2004 06:26 Go to previous messageGo to next message
yeah they are electronic, and its an A340e
Also found in ma70 non turbos, jza70s and others
mrsmart
Melbourne Eastern Suburbs
Re: MX83 transmission question. Sun, 11 July 2004 06:40 Go to previous messageGo to next message
Fluid level?
SIMDOG
Bayside Melbourne.
Re: MX83 transmission question. Sun, 11 July 2004 07:47 Go to previous messageGo to next message
Transmission got serviced 800km before the problems starting. The engine go reco'd then and the problems have been infuriating me ever since then. Could a loose plug be the culprit?
Fluid level is spot on and the fluid is clean and new.
Re: MX83 transmission question. Sun, 11 July 2004 08:01 Go to previous messageGo to next message
A340e gearbox has at least three connectors (and possibly four if there's two speed sensors) - plus it's own loom and that loom is tightly enmeshed with the factory engine ECU.
the 1G-GTE+A340e setup has 8 wires going from the engine ECU to the gearbox ECU or gearbox related things (o/d switch, gear indicator switch, etc)
the US ma61 (5mge i think?) has 5 lines between the ecu's then another 15 going to/from the gearbox ECU to elsewhere (inc gearbox).
your's will be similarly complex.
... go back over your wiring - is likely that re-installation was not 100% - it's the gearbox ECU doing a fair amount of the gear shifting, not just the kickdown cable.
SIMDOG
Bayside Melbourne.
Re: MX83 transmission question. Mon, 12 July 2004 02:07 Go to previous message
The reason I was wondering if a missing connection or plug could be the problem was because it still changes gears. It just doesn't change nicely or before the rev limiter. I would have thought that it would really f*ck things if it had a missing wire(s) not just do what I have described. Confused
Previous Topic:18rc electronic disributor
Next Topic:3tgte ecu
Current Time: Sun Nov 1 05:02:18 UTC 2026
Total time taken to generate the page: 0.0052680969238281 seconds
