Toymods » Tech & Conversions » hiace diff ratio?
V8_MA61
hiace diff ratio? Sun, 11 July 2004 11:48 Go to next message
Im interested in getting this hiace diff available to me.
Its out of an 89 Diesel hiace. Open centre non lsd
Anyone know what ratio itd be??
Ta
Blake
Re: hiace diff ratio? Sun, 11 July 2004 12:17 Go to previous messageGo to next message
I'm only taking a stab in the dark here, but I'll put one vote up for 4.88 Evil or Very Mad
V8_MA61
Re: hiace diff ratio? Sun, 11 July 2004 12:27 Go to previous messageGo to next message
holy crap, i dont think the old 302'd like that much Razz
TA22-3SGTE
MACKAY
Re: hiace diff ratio? Sun, 11 July 2004 13:55 Go to previous messageGo to next message
You will have to check the code on the ID plate as the HiAce has a few different ratios , The last diff I pulled out of a hiace was a 4.3 , And yeah a 4.88 would not be any good for the windsor I put a windsor into a 1990 2wd hilux with 4.5 gears and they were way to low , A mate has a v6 como motor in his hilux and he bought a set of 3.5 gears for about $400 , I think he bought them at a place in Rockhampton , A set of 3.5's would be Ideal in the MA .
Trevor
Re: hiace diff ratio? Sun, 11 July 2004 21:58 Go to previous messageGo to next message
V8_MA61 wrote on Sun, 11 July 2004 22:27
Depends just how wild the 302 is! Evil or Very Mad
Steve_Reynolds
Gold Coast
Re: hiace diff ratio? Mon, 12 July 2004 01:37 Go to previous messageGo to next message
My money's on 4.55:1's if it's diesel.
Fattony
Re: hiace diff ratio? Mon, 12 July 2004 08:54 Go to previous messageGo to next message
When i was shopping round for a diff i found that the hiace open centre diffs were limited to taller ratios, i.e 4.11, 3.9 not 4.88, but then again becauce its a diesel that might change things or i could just be flat out wrong. Chase up the id plate and get the diff code of that, that will tell you if its g or f series diff and ratios and how many pinion wheels are in the diff. Personaly i wouldnt waste my time with a f or g series 2 pinion diff, the pick of the bunch would be a g series 4 pinion diff.
V8_MA61
Re: hiace diff ratio? Mon, 12 July 2004 10:16 Go to previous messageGo to next message
nah it was alreayd out of a car, so no idea on model code Sad
The 302 will be wild, but needs to be sane on a highway.
3.5 would be perfect, but a 3.7/ 3.9 would suffice
SeptemberSquallIndustries
Re: hiace diff ratio? Mon, 12 July 2004 10:33 Go to previous messageGo to next message
Hiace is (most commonly) a 1500kg (tare) 2400CC four-cylinder light commercial. When fully loaded ours can tip 3.5t (estimated gross).
Work it out, what sort ratio do you think it'd have to make it move, 3.1???? 2.8????? Shocked Shocked Shocked Shocked Shocked Shocked Shocked
[Updated on: Mon, 12 July 2004 10:33]
Steve_Reynolds
Gold Coast
Re: hiace diff ratio? Tue, 13 July 2004 02:27 Go to previous message
SeptemberSquallIndustries wrote on Mon, 12 July 2004 20:33
Exactly, that's why petrol models (usually earlier 1800cc & 2000cc) often have 5.2:1 or 4.88:1 diffs.
Lots of weight for a small engine to lug away from traffic lights.
Previous Topic:ke20 diff
Next Topic:HEAD STUDS vs. HEAD BOLTS
Current Time: Mon Nov 2 03:35:51 UTC 2026
Total time taken to generate the page: 0.0058410167694092 seconds
