Toymods » Tech & Conversions » should 1JZ's have turbo gaskets
Mr DOHC
icon5.gif  should 1JZ's have turbo gaskets Mon, 12 July 2004 09:44 Go to next message
basically, should they have a gasket between the manifold and turbo and turbo to dumps.
whether it SHOULD be just goo Rolling Eyes , or a multi layer metal gasket and maybe some additional goo
Soarer
Wollongong
Re: should 1JZ's have turbo gaskets Mon, 12 July 2004 10:42 Go to previous messageGo to next message
Metal gaskets on mine when I pulled the turbos off about a month ago. Definitely factory items, as the turbos had never been removed.
Mr DOHC
Re: should 1JZ's have turbo gaskets Mon, 12 July 2004 10:48 Go to previous messageGo to next message
AH-HAH
chris davey's 1JZ corona that we have been having the ticking problem with, it has NO gaskets at all in those spots, just a shit load of goo Mad
dodgy dump-pipe-making/fitting bastards
V8_MA61
Re: should 1JZ's have turbo gaskets Mon, 12 July 2004 10:50 Go to previous messageGo to next message
goo between turbos operating at that temperature? Rolling Eyes
Thats a pretty piss poor effort!
When i helped norbie pull out his 2jz, it had gaskets made to fit the manifold/ dump pipe
[Updated on: Mon, 12 July 2004 10:50]
Mr DOHC
Re: should 1JZ's have turbo gaskets Mon, 12 July 2004 10:55 Go to previous messageGo to next message
should chris go back and make them put new one in that they should have put in there in the first place, or at least re-used his, cause from what i am aware, turbo gaskets are re-usable.
the company shouldnt really be making dumps if they dont even realise they need gaskets Shocked
Chris Davey
sunny coast, qld
Re: should 1JZ's have turbo gaskets Mon, 12 July 2004 11:02 Go to previous messageGo to next message
I wouldn't call it a company! Laughing
Ok, I want some gaskets. I have been told about the kits that you can make them yourself. Could I use one of these or should I get some from Toyota?
Chris
V8_MA61
Re: should 1JZ's have turbo gaskets Mon, 12 July 2004 11:06 Go to previous messageGo to next message
make them urself, but get the right material and make sure you are accurate
Mr DOHC
Re: should 1JZ's have turbo gaskets Mon, 12 July 2004 12:02 Go to previous messageGo to next message
if u r just talking about everyday gasket paper then think again, that shits useless against anything except for a 202/308 tapper cover gasket
Chris Davey
sunny coast, qld
Re: should 1JZ's have turbo gaskets Mon, 12 July 2004 23:11 Go to previous messageGo to next message
can you get the kits to make gasket out of metal?
Skip
Re: should 1JZ's have turbo gaskets Mon, 12 July 2004 23:15 Go to previous messageGo to next message
Haha Chris always thinks the worst has happened to his engine, as we've said it's probably just leaking exhaust gas!!
ke382TG
Re: should 1JZ's have turbo gaskets Mon, 12 July 2004 23:32 Go to previous messageGo to next message
If it helps,
I make my manifold to turbo - turbo to dump pipe gaskets out of copper. I just buy a small sheet of 1.?mm thick copper sheet and cut the gasket out of that, it works a treat and has never leaked. They can be used twice on my car before they become to thin and need replacing. I have made an initial template from cardboard that I keep in a safe place and use it whenever I need to make a new gasket.
The only reason I was forced to go down this route was because no one where I live could supply me with the turbo to dump pipe gasket and I needed it quickly.
Shane.
Chris Davey
sunny coast, qld
Re: should 1JZ's have turbo gaskets Mon, 12 July 2004 23:50 Go to previous messageGo to next message
Skip wrote on Tue, 13 July 2004 09:15
I hoped it was something simple but just haven't found anything yet? Smile Will be testing for exhaust leaks tonight.
ke382tg: thanks for that, sounds pretty easy to do.
so you are not sure exactly what thickness copper to get?
anyone else know?
Skip
Re: should 1JZ's have turbo gaskets Tue, 13 July 2004 02:22 Go to previous messageGo to next message
Something like 1.6mm would be fine. But what happened to the factory gaskets? I reused mine when i made my dumps.
Perhaps you can buy a sheet of that silver perforated looking exhaust gasket material from an exhaust shop?
V8_MA61
Re: should 1JZ's have turbo gaskets Tue, 13 July 2004 04:05 Go to previous messageGo to next message
chris, speak to someone whos qualified on this topic. I.e turbo + exhaust shop.
Chris Davey
sunny coast, qld
Re: should 1JZ's have turbo gaskets Tue, 13 July 2004 04:08 Go to previous messageGo to next message
Skip wrote on Tue, 13 July 2004 12:22
probably the same thing that happened to my stock Y - pipe Confused
not returned? or in the gasket case, refitted.
I will not be going to this mechanic again.
I will give the exhaust shop a call now.
Chris Davey
sunny coast, qld
Re: should 1JZ's have turbo gaskets Tue, 13 July 2004 04:57 Go to previous messageGo to next message
they said 1.6mm copper Smile
thanks Skip
ke382TG
Re: should 1JZ's have turbo gaskets Tue, 13 July 2004 05:41 Go to previous message
anyone else know?
Yep it was 1.6mm copper (I knew it was 1.6mm or 1.8mm but couldn't remember).
But I see the exhaust place told you this too so it's all sorted then. Very Happy
Previous Topic:Nissan Silvia J 1992 Help!
Next Topic:2TGEU extractors/exhaust manifold
Current Time: Sun Jun 28 03:28:45 UTC 2026
Total time taken to generate the page: 0.0054149627685547 seconds
