Toymods » Tech & Conversions » Gear Box for 1G-GE in RA28
RA28midge
Adelaide and Queenstown T...
Gear Box for 1G-GE in RA28 Tue, 10 September 2002 01:42 Go to next message
What gear box can you get away with having for a 1G-GE, does it have to be the supra W58 or can I leave my trusty standard RA28 box in place??
I have read all the tech articles but are there any other words of wisdom for doing the conversion?
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
Re: Gear Box for 1G-GE in RA28 Tue, 10 September 2002 04:53 Go to previous messageGo to next message
What box does the RA28 have? Can you find a 1G bellhousing for it?
blackRA28
adelaide
Re: Gear Box for 1G-GE in RA28 Tue, 10 September 2002 05:14 Go to previous messageGo to next message
Yeah i would love to hear a good answer to this one because i may be attempting this conversion early next year. if a good efi 18Rg doesnt come into my life by then
Did you have trouble sourcing your 1g and around what sort of price did front up for it?
sorry to be so intrusive i have jst never encountered a N/A 1g in a celica and would love mine to be like it.
I have heard the w50 will hold if you have the correct bellhousing/adaptor plate but i would really go the supra option in the long run for strength/safety, but i am no expert on gearboxes
BlackRA28
RA28midge
Re: Gear Box for 1G-GE in RA28 Tue, 10 September 2002 05:55 Go to previous messageGo to next message
The prices are
$1000 'cash' (important factor) for Engine, complete.
$500 for gear box.
I was hoping to avoid having to cut the car to fit the supra gear box/stick but I think it is going to have to be done.
I don't know as to install price as yet, need to call around, or find some competent friends quickly.
you can get 1G-GTEs in adelaide for $1500, or $2000 with big blitz turbos, but I am not really a turbo kind of guy. I also don't want to upgrade the diff and brakes quite yet.
Re: Gear Box for 1G-GE in RA28 Tue, 10 September 2002 06:01 Go to previous messageGo to next message
W50's aren't available with G series bellhousings, and you can't use a bellhousing from a later model W series box. I'm afraid your only practical option is to buy a W58 from a 1G.
rob_RA40
c'town, NSW
Re: Gear Box for 1G-GE in RA28 Tue, 10 September 2002 09:13 Go to previous messageGo to next message
1G-GE's came with W55's and the GTE's came with W58's
RA28
Re: Gear Box for 1G-GE in RA28 Tue, 10 September 2002 11:04 Go to previous messageGo to next message
W55-W58's will fit on a 1G engine with the right bellhousing. The bellhousing you got with the GE should fit any of these. W50 or T50's won't fit unless you get a housing made which is stupid. W58 gearboxes have 3 different stick positions. I have the one from a 1GGTE (not sure what car) and it has the back position, this is further back than the original w%) gearbox sits and you have make the hole a bit bigger, also, any of these boxes will need a slightly modified gearbox crossmember. The far back position is the best for the RA28 I think as it sits nicely next to the seat.
The W57 from RA60 celicas is a long way forward and is almost out of reach with the seat right back.
Maybe one of the other W58 stick positions would fit in the original hole?
Tim.
ddeane
PNG
Re: Gear Box for 1G-GE in RA28 Tue, 10 September 2002 22:11 Go to previous messageGo to next message
RA28midge
Where is Adelaide do u source 1ggte's with big turbos (for $2000)?
Craig
RA28midge
Re: Gear Box for 1G-GE in RA28 Tue, 10 September 2002 23:43 Go to previous messageGo to next message
Craig,
I threw out the piece of paper but I think the boys at Japanese motorsport (08) 8260 6919 were the ones with the GTE with Blitz turbos, that apparently was pretty much the complete setup to go into the car for $2000, but I haven't seen the engine so I don't know the condition.
And Tim, as for the W57 stick being unreachable with the seat back- not really going to be much of a problem, hence the name midge.
Any other hints for the conversion not already spoken about in the tech articles?
Thanks gentlemen
Andrew
RA28
Re: Gear Box for 1G-GE in RA28 Wed, 11 September 2002 10:48 Go to previous messageGo to next message
But don't forget you're arms will be short too!!
Do you have a gearbox that will bolt up to a g engine?? If no thten you don't really have much of a choice but to ring around and see what wreckers have got! You'll pay through the nose though.
The gearbox crossmember fit best when you have a stock auto transmission crossmember. then you just have to weld some tabs on with holes in them.
Be careful when choosing thermofan and intercooler plumbing, it gets damn tight!! I managed to get all the steel plates on the front bumper back on but the grill is about 1/2 an inch further forward. I believe Dylo got everything to fit perfect.
Also, the fuel system is a bitch, ended costing me about 600 bucks.
Good luck!!
Tim.
Nark
Cabramatta, NSW
icon3.gif  Re: Gear Box for 1G-GE in RA28 Wed, 11 September 2002 23:36 Go to previous messageGo to next message
The three stick positions are all interchangable AFAIK. So just pick whichever one you want and bolt it in.
Re: Gear Box for 1G-GE in RA28 Thu, 12 September 2002 02:48 Go to previous messageGo to next message
True, but it's not as easy as you might think. I'm in the middle of swapping shifters in a W58 right now. Mad
Re: Gear Box for 1G-GE in RA28 Thu, 12 September 2002 04:19 Go to previous messageGo to next message
i want my 1g-gte.... im drooling just thinking about it!!
dammit.. it might have to go into an RA23 cos finding a decent RA28 is just too damn expensive!! plus fixing mine will cost a pretty penny (over $3000 to fix rust and get re-spray) not to mention all the suspension worries i think im having?? Crying or Very Sad
RA28midge
Re: Gear Box for 1G-GE in RA28 Thu, 12 September 2002 06:11 Go to previous message
good luck,
I just got quoted $3000 to fit a 1G-GE, let alone a 1G-GTE.
The RA28 is worth it though, for the style, the class, the individuality and the bootspace to sleep in when you've had too much to drink to drive home Razz .
Previous Topic:Breather Tank Q
Next Topic:Covers over RA23 brakes
Current Time: Sun Oct 25 02:05:59 UTC 2026
Total time taken to generate the page: 0.012696981430054 seconds
