Toymods » Tech & Conversions » I don't like the way this looks -- Simple issue though
Neal Pallotta
Bendigo
I don't like the way this looks -- Simple issue though Mon, 12 July 2004 15:37 Go to next message
Okay, someone please tell me that I din't just spend $200 on new tyres that were the wrong size!
Is 165/60/R14 standard for a '79 Celica? The square-headlight model with a W50 transmission?
Because my car's wearing 185/75 R13's...
[Updated on: Mon, 12 July 2004 15:43]
M.W.P.
Rocky Mountains, Canada
Re: I don't like the way this looks -- Simple issue though Mon, 12 July 2004 17:13 Go to previous messageGo to next message
Hmmm.
My friends very stock RA40 has 165/75/14's on it (well i think they are 165s, might be a tad wider, but they dont look like it).
Handles like crap because of them.
Hard to know if thats the original size though since the car is ~25yrs old Rolling Eyes
[Updated on: Mon, 12 July 2004 17:29]
TA40ST
Cardiff, South Wales, UK
Re: I don't like the way this looks -- Simple issue though Mon, 12 July 2004 18:53 Go to previous messageGo to next message
A UK spec' 1979 TA40 was fitted with 165-13 tyres.
They do not have a profile figure in the tyre size.
Found this on the subject though....
" The profile of a "standard" tyre is 80, (i.e. 80% of the width of the tread). Some tyres, especially those fitted on older vehicles, don't display the profile number. So you might have a tyre showing "165x14". If the tyre profile number is not printed on the tyre sidewall, you can assume it is a standard tyre, with the profile number 80. "
Pumping these figures into a tyre comparator such as:
http://www.tyresave.co.uk/tyresize.html
and you end up with a difference of +2.36%
This will have an effect on your overall gearing and speedo calibration - probabably not enough to worry about though.
The extra width may effect other factors of the suspension dynamics though
If you want to work out the tyre size/rear axle ratio/speed calculations etc have a look here:
http://www.britishv8.org/swaps/design.htm
Quite a useful xl spreadsheet
GT
TA40ST
Re: I don't like the way this looks -- Simple issue though Mon, 12 July 2004 19:00 Go to previous messageGo to next message
I should say that base models were fitted with this size tyre, but am sure some of 2 liter models were fitted with 14" wheels.
Arch
Re: I don't like the way this looks -- Simple issue though Mon, 12 July 2004 22:30 Go to previous messageGo to next message
look for the tyre size and pressure stamp?
Super Jamie
On Probation
North East NSW
Re: I don't like the way this looks -- Simple issue though Mon, 12 July 2004 23:48 Go to previous messageGo to next message
a 165SR13 tyre, is a 165/82/13 in modern terms. older toyotas usually had a tyre placard in the glovebox, does yours?
there is a decent tyre calculator on my garage page http://www.superjamie.net/garage/
if that is the correct size for your car, and i suspect it would be, then a 165/60/14 is a drive reduction of 8%. when you're doing 100km/h on your speedo, you're really doing 92km/h. when you're doing 108km/h on the speedo, you're really doing 100km/h. this also makes your rolling diameter less, so your car will launch quicker Very Happy but have a lower top speed
185/75/13s are a 1.1% increase, i would think that 185/70/13s would be better, at 1.9% reduction
you can also work out the height of your wheel from these numbers (sidewall is a percentage of width, eg: a 200/50/13 tyre has a 100mm sidewall). obviously, two sidewalls plus the diameter of the wheel - and note that if you reduce your wheel height by more than 15mm from stock, then you can be defected (wheel and tyre changes outside this can be engineered, sometimes)
CLG
Perth, Western Australia
Re: I don't like the way this looks -- Simple issue though Tue, 13 July 2004 00:48 Go to previous messageGo to next message
Yep your original tyre size would have been 165R14 which as Super Jamie points out equates to a 165/82/14 tyre. This figure gives a diamter of 626.2mm, and as such your cureent tyres are too small. Ideally you want to find some 195/70/14's or 205/65/14's for your car to keep your speedo accurate.
your current tyres being 185/75/13 are more suited to cars that originally had 165R13 tyres, like TA22's.
Re: I don't like the way this looks -- Simple issue though Tue, 13 July 2004 02:37 Go to previous messageGo to next message
this also applied to RA28's yes?
joecoolmk2
Re: I don't like the way this looks -- Simple issue though Tue, 13 July 2004 03:32 Go to previous messageGo to next message
look in the door jam, driver's side and there should be a sticker with info on tire pressures and tire size for the car.
Neal Pallotta
Bendigo
Re: I don't like the way this looks -- Simple issue though Tue, 13 July 2004 08:18 Go to previous messageGo to next message
Only thing in the doorjamb was the 'compliance' tyreplate which was made with one of those pressure-labellers and referred to exactly what was on the car, but the wheels are corolla wheels not celica wheels and as a result I sincerely doubt that the information is accurate.
Also whilst driving on the road I felt a little odd at the speedlimit though my experience is a touch limited and it may just be driving position.
Thanks for all your help guys.
On a sidenote, anyone interested in a set of 13" steels and tyres? Very Happy I'll include wheelcovers! lol
supra1978
Re: I don't like the way this looks -- Simple issue though Wed, 14 July 2004 03:25 Go to previous message
I know TA40s and TA45s had 13 inch wheels standard, so I'd suspect that a TA46 also came with 13 inch wheels.
Previous Topic:5mge questions
Next Topic:Possible RT40 Brake & Suspension Upgrades
Current Time: Wed Oct 21 02:56:46 UTC 2026
Total time taken to generate the page: 0.0054240226745605 seconds
