Classifieds » Miscellaneous » 1/2JZ Engine, Turbo's, Booster Parts
Bentt
1/2JZ Engine, Turbo's, Booster Parts Tue, 13 July 2004 05:30 Go to next message
Hi Guys...
Still have some 1JZGTE parts lying around I need to get rid of...
Complete engine... minus, starter, A/c, Alt, Fan(can include), with new timing belt, almost new waterpump, polished cam covers, c/w Inlet manifold, throttle body, injectors stub, fuel rail, Idle air, painted coil cover and front covers, suit single turbo, mid mount sump... Spoken For
Bare engine, sold for parts, cams removed, no cam covers, water pump, covers etc c/w head, etc Mid mount sump(soarer).. $400 ONO
Crank, 5-rods+ pistons, scored bore block... Good for sizing up... $150 ONO
Clutch fan... $75
Idle air valve... $30
Sensors... MAT, TPS, CamAS, CrankAS.. offers
Loom plugs.. Various (no coil plugs)
Cam wheels... OFFER
Soarer Mid sump, with windage, oil pick up etc... $150
Power Steer pump.. $100 ONO
Soarer TT diff (damaged centre, suit ratio swap) $50
Various soarer TT undertray, raditor scoop etc plastics... $25
Lots of other bits jsut ask...
All needs to go...
Make me an offer for the lot???
*Edit* Added...
Aristo Parts Added...
ECU's :-
Power Steer.. $50
Central Locking.. $50
ABS/ TRC... $75
Airbag... $75
Steering Column...(with column)
Cruise Control... $75
Vibrating Mirror... $25
Electric Windows... $50
Buzzer.. $5
I think there is also a stand alone ABS
And a few more that don't come to mind.
Aristo Analogue Dash... $200
Cruise control motor.. $70
Electric Steering Column, with auto memory, etc... $300
Electric booster... $450
Steering Rack from Aristo... $125
Calipers and rotors from Aristo... $200
5speed auto gearbox... Not: different output shaft to soarer... $450
I also have available a set of CT20 twin turbo's from the 2jzgte... $650
Note:- all these parts are from an aristo, but look the same as the soarer ones, I can get part numbers etc to anyone before buying to comfirm compatibilty. Plugs are also available with most ECU's.
BAW@HVACQLD_dot_com
[Updated on: Mon, 26 July 2004 04:47]
V8_MA61
Re: 1JZ Engine + Parts Tue, 13 July 2004 07:18 Go to previous messageGo to next message
pics of the soarer diff please. and what kind of "damage" - is the crownwheel and pinion useable or broken? i need the model code or a descripition also so i can work out the ratio.
rneil@bigpond.net.au
[Updated on: Tue, 13 July 2004 07:19]
Bentt
Re: 1JZ Engine + Parts Tue, 13 July 2004 09:42 Go to previous messageGo to next message
Pretty sure it's a 3.98 as per most Soarer Diff's... I'll drag it out this weekend for you and knock the backing plate off to take a pic for you...
I managed to kill the planetaries in it...
V8_MA61
Re: 1JZ Engine + Parts Tue, 13 July 2004 10:00 Go to previous messageGo to next message
Where in brissy are you?
Itd be either a 3.7, a 3.9 or a 4.1 id guess...i just need you to find out the ratio for me...Any chance before the weekend you can do that? Ill come and pick it up upon knowing its ratio.
Blake
ed_ma61
Lost in the K hole
Re: 1JZ Engine + Parts Tue, 13 July 2004 11:17 Go to previous messageGo to next message
any word on the other sump we spoke about?
Smile
ed
7M-Brisbane
Re: 1JZ Engine + Parts Tue, 13 July 2004 13:47 Go to previous messageGo to next message
Blake - you'll find that the Soarer ratios aren't the same as the traditional G series ones.
Ben - hope the Soarer/Bimmer are treating you well Smile Can you measure the depth of the clutch fan for me? Just sit it on the circular mounting bit, and measure from the ground up to the highest point.
E-mail me lmdwyer@turbosupras.com
Cheers mate
Leigh
Bentt
Re: 1JZ Engine + Parts Wed, 14 July 2004 10:33 Go to previous messageGo to next message
V8_MA61
I'll have a look at it tomorrow night for you mate... I'm in Brookfield...
Ed_MA61
Still trying to find a decent 2JZGTE at a decent price... Once I find the 2jz I'll let you know if I need to keep the sump or not...
Leigh
I'll have a measure for you tomorrow night also mate Smile It doesn't seem to fit in the 15mm clearance to my Alloy radiator Razz
V8_MA61
Re: 1JZ Engine + Parts Wed, 14 July 2004 12:56 Go to previous messageGo to next message
ta mate.
mx83toy
Re: 1JZ Engine + Parts Wed, 14 July 2004 16:29 Go to previous messageGo to next message
what colour is the front-cam/coil covers painted? how much you want for them and the polishied cam covers???
Bentt
Re: 1JZ Engine + Parts Wed, 14 July 2004 21:45 Go to previous messageGo to next message
mx83toy
Seems everyone wants these... they are all fitted to the engine. painted Lobelia Purple... Buy the whole engine and change them over, and still have a spare engine after it Smile
I wasn't keen to seperate... but make a me an offer I can't refuse Smile Bare in mine that without plastics and cam covers the 1JZ won't be worth much to me... No-one wants an engine minus these...
Chris Davey
sunny coast, qld
Re: 1JZ Engine + Parts Thu, 15 July 2004 00:27 Go to previous messageGo to next message
what parts of the head do you have? I still don't know exactly what is wrong with mine but when I find out I may be needing some replacement parts.
chris
Bentt
Re: 1JZ Engine + Parts Thu, 15 July 2004 00:36 Go to previous messageGo to next message
Chris,
Have a whole head compelte, just with cams removed....
Chris Davey
sunny coast, qld
Re: 1JZ Engine + Parts Thu, 15 July 2004 05:26 Go to previous messageGo to next message
thanks.
where abouts in brissy are you?
Have to get cracking with finding out what is wrong with my engine! Smile
Bentt
Re: 1JZ Engine + Parts Thu, 15 July 2004 06:18 Go to previous messageGo to next message
Brookfield...
I've got a complete sexy looking engine there mate... Could be a bit flexible on price depending on what you need Smile Might be the smarter fix, if there is something wrong with your head... I think Head gaskets are a $100's each!!!
V8_MA61
Re: 1JZ Engine + Parts Thu, 15 July 2004 08:03 Go to previous messageGo to next message
find out that ratio for me mate? Very Happy
Bentt
Re: 1JZ Engine + Parts Thu, 15 July 2004 23:11 Go to previous messageGo to next message
V8_MA61
I'm pretty sure it's a 3.98 ratio... seemed to not quiet make 4 turns on the nose for a turn of the output.. and I know that TT soares have 3.98 ratio...
Chris Davey
sunny coast, qld
Re: 1JZ Engine + Parts Fri, 16 July 2004 02:36 Go to previous messageGo to next message
Do you have 2 engines?
1. Complete engine... minus, starter, A/c, Alt, Fan(can include), with new timing belt, almost new waterpump, polished cam covers, c/w Inlet manifold, throttle body, injectors stub, fuel rail, Idle air, painted coil cover and front covers, suit single turbo, mid mount sump... $750 ONO...
and 2. Bare engine, sold for parts, cams removed, no cam covers, water pump, covers etc c/w head, etc Mid mount sump(soarer).. $400 ONO
So what is the story? Did you blow the second one with the scored bore and the first one runs fine? or what? how many k's on the first one? was this your old single turbo engine?
Also, it is possible to swap my front sump onto your mid sump? would the sensors be the same considering mine is from a jzx90 chaser and yours is soarer?
[Updated on: Fri, 16 July 2004 02:38]
Bentt
Re: 1JZ Engine + Parts Fri, 16 July 2004 02:49 Go to previous messageGo to next message
Chris... 3 engines in various states...
1: complete engine ready to roll, minus starter etc etc...
2: block, crank, rods, scored bore.. I melted number 6 piston...
3: engine, block, sump, crank rods, head etc.. still bolted together, but sold for parts as I don't know it's origin.
First(1) engine that is complete, I'm unsure of KLMs, but was bought from an importers and was the cleanest 1jz I've seen. Compression tested fine, and is ready to roll...
Front sump goes straight on... no sensors to speak of mate mounted on the sump bar your oil level sensor. I'm pretty certain that the CAS mounts on the front of the engine not the sump and that it's all interchangeable.
I was going to bolt my front sump onto this engine, but decided to go the 2JZGTE route Smile hence the sale, otherwise this engine would be in my car now Smile
Chris Davey
sunny coast, qld
Re: 1JZ Engine + Parts Fri, 16 July 2004 03:14 Go to previous messageGo to next message
Bentt wrote on Fri, 16 July 2004 12:49
I was actually talking about the sensors on the top of the engine. My wiring should hook up to the sensors on that engine right?
stupid question: what does CAS stand for? Smile
I am getting quite interested Smile
Bentt
Re: 1JZ Engine + Parts Fri, 16 July 2004 03:40 Go to previous messageGo to next message
Yeah mate all your plugs will go straight on Smile
I found when removing my engine, it was easier to remove the inlet manifold from the head leaving the wiring loom still feeding through it all etc, just leave it in the bay wire attached, then lift the old one out and drop the new engine in retaining your inlet manifold and loom...
The loom is a bit of a pain to try and remove from the inlet manifold whilst it's still on the engine. I did it the hard way first, then decided to do it the easy way second Smile
Another thing you can do is just pull the whole loom back through the firewall and lift it out still attached to the engine Smile On second thoughts I'd suggest this. Then it's just a matter of transferring it all over on the ground and dropping the new one back in Smile
CAS - Crank Angle sensor little plug on a bracket down near the alternator Smile
[Updated on: Fri, 16 July 2004 03:40]
V8_MA61
Re: 1JZ Engine + Parts Fri, 16 July 2004 07:49 Go to previous messageGo to next message
sweet, ill see what my engine shop says and ill get back to you.
kalium
Re: 1JZ Engine + Parts Wed, 21 July 2004 23:24 Go to previous messageGo to next message
The block might be useful to me, dont really need the pistons or rods with it though..would you seperate it ?
Bentt
Re: 1JZ Engine + Parts Wed, 21 July 2004 23:34 Go to previous messageGo to next message
Just want a block to dummy mount the engine etc???
The sperated block does have scores on number 6 pot though...
$50 pick up Smile
V8_MA61
Re: 1JZ Engine + Parts Thu, 22 July 2004 08:20 Go to previous messageGo to next message
so 3.9 was the ratio yeah? Perhaps read the diff code on the car/ a car exactly the same..and i can then work it out..
Blake
Bentt
Re: 1JZ Engine + Parts Thu, 22 July 2004 09:43 Go to previous messageGo to next message
V8_MA61
Yup as best I can tell... I"ll duck out and have another check after this for you, and let you know tomorrow Smile
ED_MA61
I'll be getting my cut tomorrow, as so long as it's front sump, the front sump I have is available to you Smile
Ben
ed_ma61
Lost in the K hole
Re: 1JZ Engine + Parts Thu, 22 July 2004 11:42 Go to previous messageGo to next message
PM'd Very Happy
BlackSupra
Re: 1JZ Engine + Parts Thu, 22 July 2004 11:44 Go to previous messageGo to next message
i will laugh if its mid/rear Cool
7M-Brisbane
Re: 1JZ Engine + Parts Thu, 22 July 2004 12:30 Go to previous messageGo to next message
Norbie's Aristo was a front sump, but apparently that's the only model of Aristo (I think was jzs141 or jzs147? just guessing) that had a front one.
ed_ma61
Lost in the K hole
Re: 1JZ Engine + Parts Thu, 22 July 2004 12:33 Go to previous messageGo to next message
BlackSupra wrote on Thu, 22 July 2004 21:44
Twisted Evil Twisted Evil Twisted Evil Twisted Evil
V8_MA61
i thought that was the only one with a front sump also Confused Or maybe there was one more..
ed_ma61
Lost in the K hole
Re: 1JZ Engine + Parts Thu, 22 July 2004 12:39 Go to previous messageGo to next message
and, err, leigh, are you sure that 145mph isnt in the metric system of measurement?
Bentt
Re: 1JZ Engine + Parts Mon, 26 July 2004 04:49 Go to previous messageGo to next message
Items Added.... Shocked
Darkstar
Ebbw Vale, Qld
Re: 1/2JZ Engine, Turbo's, Booster Parts Mon, 26 July 2004 06:17 Go to previous messageGo to next message
So, Bentt, you got that Aristo cut Ok anyway??
Sorry I didn't reply i've been away 4 a few days..
How much did u have to pay, and where'd u get it from if u don't mind me asking??
Bentt
Re: 1/2JZ Engine, Turbo's, Booster Parts Mon, 26 July 2004 06:31 Go to previous messageGo to next message
PM sent...
7M-Brisbane
Re: 1/2JZ Engine, Turbo's, Booster Parts Mon, 26 July 2004 07:34 Go to previous messageGo to next message
LOL that signature's already long gone, but it was a bit of a joke - 15.something at 145mph... ie. mph to run a 9 with Smile
I had a signature once saying I had a Daewoo Lanos with a turbo'd hemi that ran 11.2@190mph or something ghey and the number of PM's I got telling me how tough it must have been was incredible Very Happy
Chris Davey
sunny coast, qld
Re: 1/2JZ Engine, Turbo's, Booster Parts Mon, 26 July 2004 08:20 Go to previous messageGo to next message
I am buying the complete 1jz-gte engine.
just thought I would add that Smile
Southo
Re: 1/2JZ Engine, Turbo's, Booster Parts Mon, 26 July 2004 13:05 Go to previous messageGo to next message
Please tell me more about this 5spd Auto Gearbox...
What year model and series Aristo ??
How Many Kilometres travelled ??
Does it come with complete harness and ECU ??
Model number ??
Can you get me pics so I can how different it is...
ed_ma61
Lost in the K hole
Re: 1JZ Engine + Parts Mon, 26 July 2004 13:38 Go to previous messageGo to next message
and the last laugh is mine!!!
muuhahahahahaha..... *ahem*
Twisted Evil
MR 1JZ
Re: 1/2JZ Engine, Turbo's, Booster Parts Mon, 26 July 2004 23:09 Go to previous messageGo to next message
will those 2JZ turbos bolt onto a 1GGTE or will I need a custom manifold???
7M-Brisbane
Re: 1/2JZ Engine, Turbo's, Booster Parts Tue, 27 July 2004 00:43 Go to previous messageGo to next message
You will need a custom manifold.
Ben, ever measure that fan for me mate?
Bentt
Re: 1/2JZ Engine, Turbo's, Booster Parts Tue, 27 July 2004 22:41 Go to previous messageGo to next message
PM sent Southo...
Leigh, I did. but have forgotten the measurement Razz I'll try and check again for ya tonight mate...
MR 1GGTE.. I haven't seen a 1ggte but no doubt you will need a custom manifold... Turbo's are in great nick though Smile
Bentt
. Tue, 27 July 2004 22:47 Go to previous messageGo to next message
[Updated on: Tue, 27 July 2004 22:47]
Re: 1/2JZ Engine, Turbo's, Booster Parts Wed, 28 July 2004 04:09 Go to previous messageGo to next message
Do you still have the Aristo turbos? Are you willing to sell them separately? I'm looking for just one...
Bentt
. Wed, 28 July 2004 04:38 Go to previous messageGo to next message
[Updated on: Wed, 28 July 2004 04:40]
Bentt
Re: 1/2JZ Engine, Turbo's, Booster Parts Wed, 28 July 2004 04:39 Go to previous messageGo to next message
Hi Norbie... Yup I still have them mate... Not willing to separate them.. it's a REALLY good pair.. both still have the white marking's on them... no play.. no smoke...
Let me guess.. looking for a front one Razz
Bentt
. Wed, 28 July 2004 04:44 Go to previous messageGo to next message
Grrrrr computer keeps stalling...
[Updated on: Wed, 28 July 2004 04:50]
Re: 1/2JZ Engine, Turbo's, Booster Parts Wed, 28 July 2004 05:02 Go to previous messageGo to next message
I want the one with the wastegate, and I can't for the life of me remember if it's the front or the rear! Anyway I'm sure what you're asking is a very fair price but I'm not willing to pay that much when I only need one. Thanks anyway. Smile
indian
south east - melbourne
icon10.gif  Re: 1/2JZ Engine, Turbo's, Booster Parts Wed, 28 July 2004 05:42 Go to previous message
Laughing Laughing Laughing
[Updated on: Wed, 28 July 2004 05:45]
Previous Topic:FS: toms 15" wheels
Next Topic:WRX seats FS
Current Time: Fri Nov 20 07:32:51 UTC 2026
Total time taken to generate the page: 0.0096468925476074 seconds
