Toymods » Tech & Conversions » mx22 balanced engine conversion.
joecoolmk2
mx22 balanced engine conversion. Tue, 13 July 2004 05:32 Go to next message
i wanna get an idea of what would be a good engine to put in my mark 2 coupe. the 4M weighs 200kg roughly, and i want a good engine that would balance the car a bit better and make it handle a bit better. i just the v8 sprinter forum, they mentioned the 1uz weighing 165kg, is this right? let me know what you guy's think. by the way, i can't post pics, why?
Re: mx22 balanced engine conversion. Tue, 13 July 2004 05:41 Go to previous messageGo to next message
You might be able to sneak a 1UZ in the engine bay if you use the Crown 1UZFE exhaust manifolds and use the non power assisted steering box.
That is all. Very Happy
joecoolmk2
Re: mx22 balanced engine conversion. Tue, 13 July 2004 05:56 Go to previous messageGo to next message
does anybody know where i could get an old toyota v8, v series?
Re: mx22 balanced engine conversion. Tue, 13 July 2004 06:05 Go to previous messageGo to next message
I'd be going 1UZ for sure.
And yes, the weight is around 175kg, with all acc's.
Lighter since you won't be using the powersteer pump, or the aircon unit.
joecoolmk2
Re: mx22 balanced engine conversion. Tue, 13 July 2004 06:10 Go to previous messageGo to next message
how much would it cost though? i'm just gonna keep it standard except for a twin 2" exhaust system, can i get a deal on a half-cut minus parts that i don't need?
Re: mx22 balanced engine conversion. Tue, 13 July 2004 06:16 Go to previous messageGo to next message
I'm not sure what sump you will need, but you can always source one later.
If you plan to remain auto, just go out and get the first/cheapest cut you can get, or get a complete engine + trans package
Expect to spend $5000 as a guestimate, depending on how much maintanence you do on the motor.
Re: mx22 balanced engine conversion. Tue, 13 July 2004 06:17 Go to previous messageGo to next message
1UZ halfcuts are about $2-2.5K.
You need a Crown Royal Saloon sump (midsump).
[Updated on: Tue, 13 July 2004 06:17]
Re: mx22 balanced engine conversion. Tue, 13 July 2004 06:30 Go to previous messageGo to next message
gianttomato wrote on Tue, 13 July 2004 14:17
Midsump?
In that case you can buy the cheapest cut you can find, coz all the cheap ones are midsump.
And if you find a front/rear sump cut for a cheaper price, get it, and there are hundreds of unused midsumps rolling around the country.
And then just follows GTs Crown install guide.
It wont be a huge amount different (electronics wise that is)
joecoolmk2
Re: mx22 balanced engine conversion. Tue, 13 July 2004 08:03 Go to previous message
i wanted to go to the mainland and pick up a half-cut then go back to tassie and work on it, i also wanna come to a meet, so when will there be a meet? i got a while before i can afford a half-cut, but i'm just doing the planning now.
Previous Topic:TA23 with 2TGEU, what brake booster???
Next Topic:igniter problem
Current Time: Fri Nov 20 23:50:06 UTC 2026
Total time taken to generate the page: 0.0046350955963135 seconds
