Toymods » Tech & Conversions » 18RGEU parts
SIKRA40
icon5.gif  18RGEU parts Tue, 13 July 2004 06:40 Go to next message
Can anyone help me on spares for an 18RGEU. I am after pistons. i am told i cant get standard ones and i have to go forged custom. if anyone know otherwise plz let me know. are there any common problems with the twin cam head?
Re: 18RGEU parts Tue, 13 July 2004 08:01 Go to previous messageGo to next message
you CAN get the 88250 model pistons (8.7:1 pistons) from Toyota ex-japan. But they are almost the cost of a forged set (ie $600+)
Head - i dunno, chain guides?
Mr DOHC
Re: 18RGEU parts Tue, 13 July 2004 09:05 Go to previous messageGo to next message
u can get 2nd hand pistons from various ppl on this forum.
i beleive that CelicaRA45 has a set of 12.X:1 for sale Very Happy
chain guides are a bitch, they have other problems too, i'll see if i can gif up my old post about my problems i have
SIKRA40
Re: 18RGEU parts Tue, 13 July 2004 09:41 Go to previous messageGo to next message
Cheers. any info i can get is greatly appriecated. I am modifing the engine to suit a turbo, so i was thinking of forged pistons anyway. new chain guides etc were on the to do list while i still have it apart.
people100
Rocklea qld
Re: 18RGEU parts Tue, 13 July 2004 10:16 Go to previous messageGo to next message
if your on a bit of a budget id suggest using standard 18rc pistons. Thats what im doing and should lower to around 8.2:1 compression
Mr DOHC
Re: 18RGEU parts Tue, 13 July 2004 11:38 Go to previous messageGo to next message
just get forged {obviously oversized} 18RC pistons, its between 8.0 and 8.2
SIKRA40
Re: 18RGEU parts Tue, 13 July 2004 13:22 Go to previous messageGo to next message
Can standard 18rc pistons be used? i thought of that and looked into it, and the 18rg pistons have grooves machined in the top for the valves. the 18rc pistons do not. if i could that woud be a much eaiser way to go until i have the moeny for forged.
Re: 18RGEU parts Wed, 14 July 2004 00:49 Go to previous messageGo to next message
I'd be very surprised if 18R-C pistons will work in an 18R-G without problems. You're right, the 18R-G pistons are flycut to clear the valves, but 18R-C pistons probably aren't flycut, and even if they are the grooves will be in the wrong place!
munki
Gold Coast
Re: 18RGEU parts Wed, 14 July 2004 02:26 Go to previous messageGo to next message
i dont see why rc pistons wouldnt work they are flat top no dome and they wont hit when comparing them with rg pistons the flycuts end higher than the position of the block (which rc pistons are level with at TDC)
hope that made sense
Daniel
SIKRA40
Re: 18RGEU parts Wed, 14 July 2004 02:43 Go to previous messageGo to next message
the RG pistons are flat top as well and still have the flycuts on the piston. dome top pistons are aftermarket. well that is the case with the 18RG that i have anyway. i could be wrong. i am not really willing to use the 18RC pistons to test the theroy. i dont want to have to replace the head. also off topic, does altering the cam duration alter the compression ration of the engine? i know it alters the volumetric efficiency, and i have had mixed feed back about the compression ratio.
Re: 18RGEU parts Wed, 14 July 2004 04:10 Go to previous messageGo to next message
Static compression ratio is determined by the bore/stroke and combustion chamber volume only. Cam specs will have a significant effect on dynamic compression though, which is why high-compression pistons are necessary on engines with lots of duration and overlap.
munki
Gold Coast
Re: 18RGEU parts Wed, 14 July 2004 04:52 Go to previous messageGo to next message
ok let me say again the piston crown protrudes from the block then the piston is at tdc on an a rg piston drom the ones i have seen at a guess 19mm 13mm and 7mm .7, 9.2, 8.7. the 18rc piston does not protrude out of the block at all and is flush to the machined block surface. the recessions in the pistons for valve clearance begin further up on the piston on the rg motors so i see that with the standard cam profiles it would be impossable to hit the piston. The std rc is 8.5:1 and the rg looks to be a larger combustion chamber than the rc so i would presume the cr would drop slightly arround 8.2 sounds plausable presuming the rg rods are the same (which they are arent they?)
edit: it would run pretty crappy with the std cam profile though, i dunno about on boost cause i dont know turbos at all
[Updated on: Wed, 14 July 2004 04:55]
Mr DOHC
Re: 18RGEU parts Wed, 14 July 2004 10:30 Go to previous messageGo to next message
RA_28 has 18RC in his, and im pretty sure they are untouched,
as for comp, RA_28 {alex} said his is somewhere around 8.0-8.2
18RC and 18RG have the same botem end cept for piston tops.
that fella with the 9.2 sec 18RGT corolla over in alexandra hills said the best cams he has found for his turbo application is the std ones
Steve M
Re: 18RGEU parts Thu, 15 July 2004 03:13 Go to previous messageGo to next message
If you search around you can find pistons.
I found a set of brand new 9.7:1 , .5mm OS pistons and bought them for $365 through a toyota dealer, just had to find one who actually gave a shit and was willing to look for them.
I know that there were two sets of these left in Sydney last year.
Steve M
Re: 18RGEU parts Thu, 15 July 2004 03:18 Go to previous messageGo to next message
On the topic of domes, the RG pistons did have raised domes from the factory.
the 9.7:1 pistons have a raised part of approx. 6.7mm, the 8.7:1 pistons have a dome of approx. 4mm and the 8.3:1 pistons have less dome that that.
Note: all rg pistons must be flycut, the cutouts actually extend fractionally below the level of the block, ie. below ehere the flat top of an 18R-C piston is.
Re: 18RGEU parts Thu, 15 July 2004 06:07 Go to previous messageGo to next message
There has been talk of a group buy of forged RG pistons. Witzl, do you have any further info on this?
SIKRA40
Re: 18RGEU parts Thu, 15 July 2004 06:23 Go to previous message
You were right steve m. i phoned all the toyota dealerships in bris, and 1 of them found me a set of 1mm OS available from sydney. all of the others told me not available or no listing. just like u said. find someone who knows the system and cares. he wants 198.15 each retail. so i think i may end up getting forged made anyway unless i can get trade discount from one of my mates. thanx 4 ur help!
Previous Topic:Idle-in like a peice of sh*t
Next Topic:T18 axles into JDM rear end.
Current Time: Sat Nov 21 06:56:23 UTC 2026
Total time taken to generate the page: 0.0051751136779785 seconds
