Toymods » Tech & Conversions » How to get more power from supercharger
bennettaru
narooma
How to get more power from supercharger Tue, 13 July 2004 11:30 Go to next message
currently running 9psi with larger pulley added. got the larger zorst and pod (not that they would make a large difference)
on a 1g gze btw.
Re: How to get more power from supercharger Tue, 13 July 2004 11:59 Go to previous messageGo to next message
to get more power, turn the SC faster. or make the motor more efficient as you have done with intake and exhaust already...
bennettaru
narooma
Re: How to get more power from supercharger Tue, 13 July 2004 12:00 Go to previous messageGo to next message
thanks for all of that help you provided me with "stewart"
your the man!
Re: How to get more power from supercharger Tue, 13 July 2004 12:14 Go to previous messageGo to next message
sorry i can't be of more help with your specific motor tho..
the idea with all motors is the same.. make it 'efficient' as possible, in terms of reducing pumping losses, and intake and exhaust losses, and then stuff as much air in as possible Wink
you could look to porting, cam timing, more cam lift nearly always helps...
exhuast is a big help with SC motors, as you want to get the gas out as quickly as possible... (since it is basically an oversized NA motor, as opposed to turbo) also a more efficient IC would be of help...
bennettaru
narooma
Re: How to get more power from supercharger Wed, 14 July 2004 07:42 Go to previous messageGo to next message
the zorst on it atm is pretty scrappy so i might fix it up, if i blow a head gasket i might get it stroked or something if possible then like stage3 cams and what not, just work on the internals maybe, something different.
thanks stewie
SLY16V
camden
Re: How to get more power from supercharger Wed, 14 July 2004 15:06 Go to previous messageGo to next message
can you get a smaller s/c pulley to spin it faster i.e 12-15psi???
i know you can for sc-12 charger not sure on yours though cause that makes a big differences with my mates ae82 4agze.
also if you dont have aftermarket extractors get some cause they work a treat too with s/c motors.
M.W.P.
Rocky Mountains, Canada
Re: How to get more power from supercharger Wed, 14 July 2004 15:09 Go to previous messageGo to next message
Turn the SC too fast, itll overheat and bugger up the rotors.
10K RPM is max for the SC14.
Re: How to get more power from supercharger Wed, 14 July 2004 15:34 Go to previous messageGo to next message
bennettaru wrote on Wed, 14 July 2004 17:42
thanks stewie
what yu want are maybe near standard duration cams (at least for the overlap) or LESS overlap.... BUT higher ramp rates and greater valve lift..
you definitely do NOT want 'stage 3' cams...or "super special turbo grinds"... just mor elift, and higher ramp rates, and spin the charger to it's max rpm, at your motors imposed max rpm...
bennettaru
narooma
Re: How to get more power from supercharger Fri, 16 July 2004 08:01 Go to previous message
ok, thanks for all that.
i think ill leave it as is. its got extractors on it already
im pretty happy with it, just fix up the leaks and clean it then show it maybe
Previous Topic:2ZZ-GE development doc
Next Topic:2tg-18rg timing chain tensioner
Current Time: Sat Nov 21 02:41:38 UTC 2026
Total time taken to generate the page: 0.0051689147949219 seconds
