Toymods » Tech & Conversions » 4agte manifold
serge
western suburbs,sydney
4agte manifold Tue, 13 July 2004 11:54 Go to next message
http://www.geocities.com/feral4mr2/turbo.html
This is feral4mr2's original ZE exhaust mnifold modified for a T25 on his mr2 i want to do the same thing but for my ae82 except im using a T28 do you think the manifold is too long therefor the turbo will sit to close to the ground? Or do you think the clearence will be the the same between the two cars?
[Updated on: Tue, 13 July 2004 11:56]
serge
Re: 4agte manifold Tue, 13 July 2004 12:52 Go to previous messageGo to next message
BUMP Smile
feral4mr2
Bundaberg, Qld.
Re: 4agte manifold Tue, 13 July 2004 12:54 Go to previous messageGo to next message
the car has nothing to do with it. Wink
same engine, same too low turbo mounting. and most probably same embarrasing oil smoke on idle.. Mad
if you cut it just above/on top of the heat sheild bolt hole you see in the pic, you might be lucky enough to have the 2 lower runners still inline. i cut it a litte bit too much higher than the heat sheild bolt hole when i went to modify it again and the 2 lower runners where moving away from each other making it hard to put a flange on.
to give you an idea of my turbo placement/height, the turbo flange is now inline with the top of the oil filter boss on the block.
whereas before it was about 1/2 way down the oil filter boss.
HighRolla
Re: 4agte manifold Tue, 13 July 2004 12:58 Go to previous messageGo to next message
feral - did you cut and reweld a Cast iron manifold? I know it's not recommended (unless you get correct welding rods etc) doing this but was wondering if you had shonked something up successfully
feral4mr2
Bundaberg, Qld.
Re: 4agte manifold Tue, 13 July 2004 13:11 Go to previous messageGo to next message
i cut it and got a steel flange i cut out brazed on.
it would of been sucsessful had i cut it high enough in the first place.
serge
Re: 4agte manifold Thu, 15 July 2004 12:10 Go to previous messageGo to next message
Im starting a welding course in a couple of days so i'll learn how to make a manifold myself Confused How hard can it be? Very Happy
feral4mr2
Bundaberg, Qld.
Re: 4agte manifold Thu, 15 July 2004 13:17 Go to previous messageGo to next message
not as hard as the workshops try to make out it is... Smile
serge
Re: 4agte manifold Thu, 15 July 2004 13:38 Go to previous messageGo to next message
Wouldn't you have more space to work with in your mr2 compared with the limited space i have in my FWD ie. between radiator and block or is it practicaly the same?
Joshstix
Toymods Vice President
Re: 4agte manifold Thu, 15 July 2004 21:11 Go to previous messageGo to next message
serge wrote on Thu, 15 July 2004 23:38
HAHAHA
The MR2 isn't exactly the most spacious engine bay. Just think of the MR2 bay as the same as a corolla bay with a firewall instead of a radiator.
feral4mr2
Bundaberg, Qld.
Re: 4agte manifold Thu, 15 July 2004 21:35 Go to previous message
mmmm... with-out getting measurements to compare the pair. Confused
the AW11 has the firewall going away from the engine at the bottom (eg. \). the rolla's radiator is vertical infront of the engine. so i would think we would have more room to play with, but then again with-out measurements to be sure...
[Updated on: Thu, 15 July 2004 21:36]
Previous Topic:how much can i port a 5m-ge head?
Next Topic:I REALLY need help with a 5ME please!
Current Time: Sat Nov 21 05:18:58 UTC 2026
Total time taken to generate the page: 0.0052390098571777 seconds
