Toymods » Tech & Conversions » 4age Carbie questions?
the dayo
4age Carbie questions? Tue, 13 July 2004 13:02 Go to next message
1st, will twin 40mm dellorto's fit onto a "redline" twin weber manifold?
2nd, could someone list all the parts i'll need to change a 4age to carbie, i've heard that i'll need some type of ignition computer? (not to good with electronics)
so any info would be great
Re: 4age Carbie questions? Wed, 14 July 2004 00:09 Go to previous messageGo to next message
Why do people insist on doing this??
The dellorto's should fit the redline manifold without any hassle, and as for the ignition, you'll either want something like an IG5 (no longer for sale) or get a dizzy made/adapted+regraphed to suit. By the time you buy the manifolds and carbs, pay someone to do a dizzy and get it tuned etc. you're not exactly going to be overly in pocket over using EFI, plus you'll still have carbs. Yuck. Evil or Very Mad
Super Jamie
On Probation
North East NSW
Re: 4age Carbie questions? Wed, 14 July 2004 02:35 Go to previous messageGo to next message
mrshin wrote on Wed, 14 July 2004 10:09
beacuse it just sounds so... fucking... GOOD! mmm anyone up the coast will know glenn's gold sprinter, easily one of the best sounding cars ever
the dayo
Re: 4age Carbie questions? Wed, 14 July 2004 02:43 Go to previous messageGo to next message
mrshin: thanks for the info, i asked for a list of parts not an opinion,
i've heard i could use a bosch ingnition module? i just don't know what type?
Super Jamie
On Probation
North East NSW
Re: 4age Carbie questions? Wed, 14 July 2004 02:51 Go to previous messageGo to next message
i have no idea what ignition 4ages run, but if you're replacing ecu-controlled spark with a distributor, you need to run the triggering system from that distributor. if you use a 4ac distributor it will likely have points, so you just need a coil. i once went out with a girl who had a 4afc ae92 and it had a distributor with reluctor pickup, which yes would need an ignition box. i have no idea what bolts onto what 4ags and what doesn't, those are just two examples
i dare say that *IF* the ecu has nothing to do with the spark, and it's all just controlled by a distributor and ignition box on your 4age, then you could leave it stock and just put your carburettors on
the dayo
Re: 4age Carbie questions? Wed, 14 July 2004 03:00 Go to previous messageGo to next message
i read a post from a while ago saying to use a hyper pak ingnition computer, but i'm un aware of where to get this unit
c2888
Re: 4age Carbie questions? Wed, 14 July 2004 05:00 Go to previous messageGo to next message
I had my dells on a redline manifold for two years now.
do a search, i've written about it before.
koen
Re: 4age Carbie questions? Wed, 14 July 2004 05:10 Go to previous messageGo to next message
Speed holes, eh? I think i've seen your car (parked on the street) around Dandenong-way, yeah? That spoiler's mad.
munki
Gold Coast
i have seen the computerised ignition for the 4age/3sge on ebay when i search for 'celica'
Daniel
IRA11Y
Club Member
Re: 4age Carbie questions? Wed, 14 July 2004 07:20 Go to previous messageGo to next message
Yes almost any sidedraft twin carb will fit on the redline manifold.
Low pressure fuel pump and associated surge tank if neccesary
A modified distributor that triggers an electronic ignition system or there is a site somewhere that tells you how to use the factory computer.
adaptor manifold, carbs that should be rebuilt and jetted to suit.
custom brace to the carbs to support them and stop them from snapping under hard vibration.
A good dyno tuner that knows how to tune your chosen carbs well.
A decent exhaust sytem to cope with the improved flow.
because it sounds like this .. and thats not even fully tuned Wink
Run of Hybrid
the dayo
Re: 4age Carbie questions? Wed, 14 July 2004 08:04 Go to previous message
thanks for the info, i've had a N/A 20V, a Turbo 20V and now i want something a bit different, so i'm looking for all the info i can get.
if any one knows the part number of an ingnition module i'd like to know
Previous Topic:Soarer Headlight moisture removal.
Next Topic:Cold Air Induction options
Current Time: Sat Nov 21 20:27:37 UTC 2026
Total time taken to generate the page: 0.0071818828582764 seconds
