Toymods » Tech & Conversions » KE15 Brake Upgrade for TRACK CAR
BKC01
KE15 Brake Upgrade for TRACK CAR Wed, 14 July 2004 00:17 Go to next message
Hi everyone,
i am new on the forum and have just started building a track car. It is a KE15 sprinter.
I have a ca18det and supra 5 speed, hydralic clutch and suspension mods done but need some help with what i can do about brake upgrades.
Can anyone hwlp with there experiences?
[Updated on: Wed, 14 July 2004 01:30]
Super Jamie
On Probation
North East NSW
Re: KE15 Brake Upgrade for TRACK CAR Wed, 14 July 2004 02:40 Go to previous messageGo to next message
if you check the oldcorollas yahoo group, mal mckiggan made a post about using vented camira brakes on ke corolla disc hubs, this may be helpful to you
Re: KE15 Brake Upgrade for TRACK CAR Wed, 14 July 2004 02:42 Go to previous messageGo to next message
so what mods have you done to the front suspension?
i dare say the KE15 struts and stub axles are not the best place the start.
on KE20 hub, camira vented disc, KE870 disc (both fit under 13" rims)
on KE20 steering arms, perhaps RX7 struts....
you are kind of in 'little charted' territory. most ppl seem to ditch the whole transverse leaf/A-lower arms for somethjing a bit better, and choose brakes based on the new struts (or vice-versa)
[Updated on: Wed, 14 July 2004 02:43]
Super Jamie
On Probation
North East NSW
Re: KE15 Brake Upgrade for TRACK CAR Wed, 14 July 2004 02:48 Go to previous messageGo to next message
yes rob dixon's REDWRF ke25 rally car runs heavily reinforced stock struts (due to regulations) converted to coilovers, and he's lunched several sets of stub axles in the last 12-18 months
if you google "arfabuck" you will find mark from new zealand's webpage, and he has on there a big table with all sorts of different struts in toyotas. there are also guides on toymods tech section and jonny rochester's webpage about brake upgrades for later model corollas by changing the whole strut, which you may or may not find helpful
Steve_Reynolds
Gold Coast
Re: KE15 Brake Upgrade for TRACK CAR Wed, 14 July 2004 03:16 Go to previous messageGo to next message
I assume you are building either a sports sedan to race cams events or a car just for sprint days???
All depends on a lot of things, particularly your budget.
Some classes have specific rules/formula's on what you can do.
What will you use it for exactly??
[Updated on: Wed, 14 July 2004 03:17]
sv_i
Re: KE15 Brake Upgrade for TRACK CAR Wed, 14 July 2004 11:31 Go to previous message
heya
in my Mazda 1300 I use RX-2 struts that have been coverted to height adjustable/coilovers using whiteline (I think) springs and the adjustable weld on collars.
I have been told that even these struts can flex under heavy braking and they are pretty solid.
To these struts I have Tarago vented discs and Camira calipers with stock drums on the back.
Its a good package, and with QFM pads I havent experienced any fade in multiple 180+ K stops. Its unboosted too.
hope that helps
Previous Topic:15psi hobbs switch or 2psi?
Next Topic:ae86 diff (gtapex/gtv)
Current Time: Tue Nov 24 19:07:30 UTC 2026
Total time taken to generate the page: 0.058243989944458 seconds
