Toymods » Tech & Conversions » recommended BOV for 3SGTE (pretty stock)
benmeyer
recommended BOV for 3SGTE (pretty stock) Wed, 14 July 2004 07:19 Go to next message
Hey guys, my parents are gonna get me a BOV for my b'day which is coming up and i was looking for some help as to which type or brand. i much prefer that "chicka chicka chika" sounding type than the sneazers. are tehy actually different types or does it just depend on rpm and boost? will it stuff around with my oxygen sensors or afm or anything else? what kind of prices am i looking at?
I'm not looking for anything conspicously loud, nor inconspicuously quiet, just somewhere in the middle.
cheers guys.
rb20det
Re: recommended BOV for 3SGTE (pretty stock) Wed, 14 July 2004 07:43 Go to previous messageGo to next message
that chicka chicka chika sound is actually intake noises cause from a large fmic. try a gfb sealth bov as they are both external and plumb back
benmeyer
Re: recommended BOV for 3SGTE (pretty stock) Wed, 14 July 2004 09:42 Go to previous messageGo to next message
Really? i didnt know a front mount had that kind of effect?
Obviously stealth is kinda quiet, correct?
SillyCar88
Elwood, Melb
Re: recommended BOV for 3SGTE (pretty stock) Wed, 14 July 2004 10:49 Go to previous messageGo to next message
ummmm that noise is actually the wastegate, and yes definately get the plumb-back, it makes no noise as its not atmosperic (excuse spelling)
Rex_Kelway
Re: recommended BOV for 3SGTE (pretty stock) Wed, 14 July 2004 12:45 Go to previous messageGo to next message
Instead of a BOV for your birthday, how about getting your parents to organise a McDonalds b'day party with ice cream cake...
monkeymajik
Re: recommended BOV for 3SGTE (pretty stock) Wed, 14 July 2004 13:00 Go to previous messageGo to next message
oh snap
RWDboy
Re: recommended BOV for 3SGTE (pretty stock) Thu, 15 July 2004 00:11 Go to previous messageGo to next message
Get a plumb back otherwise you will start to confuddle your ECU Razz (not in any dramatic way mind you, just results in the occasional bit of unburned petrol hitting your turbo and igniting)
Chris Davey
sunny coast, qld
Re: recommended BOV for 3SGTE (pretty stock) Thu, 15 July 2004 00:15 Go to previous messageGo to next message
how can a turbo ignite petrol?
from what I have seen the unburnt petrol passes through the turbo and out the exhaust in a cloud of black smoke
indian
south east - melbourne
Re: recommended BOV for 3SGTE (pretty stock) Thu, 15 July 2004 00:29 Go to previous messageGo to next message
CHIKA CGIKA CHIKA ====== COMPRESSOR SURGE
http://forums.toymods.org.au/index.php?t=msg&t h=40067&start=0&rid=4971&S=94ad56adb00 c65a892a947c559ea3bfa
RWDboy
Re: recommended BOV for 3SGTE (pretty stock) Thu, 15 July 2004 00:32 Go to previous messageGo to next message
It's actually not that common, usually there isn't enough (or any) oxygen left to ignite the fuel straight away in the turbo, however it will vapourise VERY quickly and as soon as it gets towards the exit of the exhaust it will probably ignite/combust if/when it gets access to oxygen if the temperature of the exhaust is high enough.
Sorry - my bad!
That cloud of black smoke you see is actually carbon, not unburnt petrol - carbon is a result of the engine running rich and achieving imperfect (yet complete) combustion. Unburnt petrol (vapour) will result from imcomplete combustion, and will occur with either rich or lean mixtures.
If you are getting incomplete combustion in a turbo engine then you may notice pops and bangs. Such 'dramatic' levels of incomplete combustion are fairly rare (from my understanding) and only occurs in very poorly tuned engines.
A BOV usually operates when you lift off the throttle - meaning that your engine will usually retard the timing (there are other factors regarding modern ECUs timing I know). The pressure level in the intake manifold will drop - but the MAP or AFM will tell the ECU that there is still tonnes (in the case of a MAP, many metres cubed in the case of AFM) of air flowing through the intake manifold. The ECU delivers 'x' amount of fuel given the amount of air it thinks is going through the engine.
Due to the (likely) change in timing and the excess fuel (rich mixture) chances are incomplete and imperfect combustion will occur resulting in oxygen and fuel heading off merrily towards the turbo. Chances are also that this mixture heading towards the turbo is also 'rich' (lower than 16:1 air/fuel ratio) meaning there will likely be a puff of black smoke as well out the back of the exhaust.
To all those who know more about this kind of stuff than me, feel free to 'fine tune' my statement Very Happy (ie - I've got my flamesuit on, so fire away guys)
d-shiznit
W.A
Re: recommended BOV for 3SGTE (pretty stock) Thu, 15 July 2004 01:02 Go to previous messageGo to next message
HEy!
I think that "chika chika chika" sound you want is not a BOV.
This sound comes from engines without a bov and without an air flow meter (ie MAP sensored).
The sound comes from air rushing back through the turbo the opposite way when the throttle body is closed.. You wont be able to hear it with an afm installed (as it will simply close and block the airflow in the opposite direction when the throttle is closed).
I dont know about the 3sgte, but i know this is the case on MAP sensored ET Pulsars and 4agtes...
So if ur 3sgte has an afm, convert it to MAP sensored and you should get this sound.
Smile I THINK this is right, can anybody confirm this?
Jag7799
Re: recommended BOV for 3SGTE (pretty stock) Thu, 15 July 2004 01:05 Go to previous messageGo to next message
d-shiznit wrote on Thu, 15 July 2004 11:02
HEy!
he is right!
but who gives a fuck what sound ur car makes, really!.. just get something that performs well an be happy with it
as for not hearing plumb back BOV's.. mine are plumb back and you can still hear them..
RWDboy
Re: recommended BOV for 3SGTE (pretty stock) Thu, 15 July 2004 01:17 Go to previous messageGo to next message
Yeah - you can hear a plumb back - and furthermore the ENTIRE point of BOV is to reduce the 'chika chika' sound to increase the life of the turbo (compressor surge is bad). As stated in that thread that was referenced earlier, grab a hks (or other brand) sequential bov if you are after that particular 'sound'.
Classique71
Colac, Victoria
Re: recommended BOV for 3SGTE (pretty stock) Thu, 15 July 2004 02:30 Go to previous messageGo to next message
GFB Hybrid
GFB plumb back
GFB Stealth
Turbosmart plumback
Stealth is the most costly ..
Im thinking of going the GFB hybrid or Plumb back on my Gt4 ..
Re: recommended BOV for 3SGTE (pretty stock) Thu, 15 July 2004 06:05 Go to previous messageGo to next message
If you want a large plumb-back BOV which performs well, doesn't leak, flows enough for nearly any engine, and doesn't make annoying noises, I can provide contact details for the bloke who built mine. Less than $200 brand new with any flange type you require.
On the other hand if you just want to make annoying noises, you are ghey.
optionUP
Perth, WA
Re: recommended BOV for 3SGTE (pretty stock) Thu, 15 July 2004 06:06 Go to previous messageGo to next message
If you don't care about looks at all, then you can get one of these:
http://wwwrsphysse.anu.edu.au/~amh110/all_gifs/Turbo%20page%20gifs/BOV_CBV_pics/CBV.jpg
...costs about $60 from Coventrys or similar. It's called a Bosch "Compressor Bypass Valve", and it's a plumb-back type.
Get more details here:
http://wwwrsphysse.anu.edu.au/~amh110/Technical_pa ges/blow_off_valve.htm
or Google to get serial number.
Maybe your parents can then spend the money they save on the McDonald's party and cake!
[Updated on: Thu, 15 July 2004 06:07]
SillyCar88
Elwood, Melb
Re: recommended BOV for 3SGTE (pretty stock) Thu, 15 July 2004 09:49 Go to previous messageGo to next message
hehe the good ol' bosch BOVs, you cant go wrong especially for a stock 3sgte, thats no doubt a good option and a money saver.
As for the what d-shiznit wrote about the compressor wheel slowing down and makin the so called "chika chika" noise when the throttle is closed, isn't this due to the wastegate, BOVs and wastegates work differently, BOVs release pressure in a sudden rush where as wastegates release pressure via slowing the compressor wheel down, thats why investing in a BOV can usually maximise the lifespan of a turbo, most if not all turboed engines come with a stock WG. Someone please discribe this in better detail or correct me so I might get a better understanding.
NO NOISE IS GOOD NOISE!!
rb20det
Re: recommended BOV for 3SGTE (pretty stock) Thu, 15 July 2004 11:53 Go to previous messageGo to next message
if ur in sydney ill sell u the one which came with my car as i hate the bov sound. its an external one and makes big sound even at low boost.
benmeyer
Re: recommended BOV for 3SGTE (pretty stock) Fri, 16 July 2004 02:52 Go to previous messageGo to next message
where in sydney?
ke382TG
Re: recommended BOV for 3SGTE (pretty stock) Fri, 16 July 2004 03:48 Go to previous messageGo to next message
As said above, go the bosch plumb-back BOV, flows well and is killer value! I have used one plumbed to recirculate and later to vent and it worked well. I know of a particular 8 second car in Canberra that uses more than one on his car (more than one to achieve greater flow, my turbo could just about sit in the bell mouth of the turbo this thing uses!!). So apart from not looking trick ie polished/anodised aluminium they are quite good.
I am not getting into the whole noise thing again as this was discussed a couple of days ago in another post at length.
But just to clarify that the wastegate allows exhaust gas to BY-PASS the turbo exhaust wheel when the wastegate is partially-open to fully-open, thus less gas is passing through the exhaust wheel and it's rpm is limited, and because it is solidly attached to the compressor wheel boost is limited.
The only noise a wastegate makes is a slight increase in exhaust noise when open (very very very little in most cases, usually just noticeable inside the car to a keen ear) or if a "screamer pipe" arrangement is in place on an external wastegate a large amount of extra un-muffled exhaust noise is created.
I have only ever seen one car with no wastegate, the owner had simply welded the wastegate shut and let the car do it's thing Rolling Eyes Not a great idea I don't think, it sounded rather unhealthy on the dyno.
Chris Davey
sunny coast, qld
Re: recommended BOV for 3SGTE (pretty stock) Fri, 16 July 2004 04:14 Go to previous messageGo to next message
ke382TG wrote on Fri, 16 July 2004 13:48
also, The Rajab's I think it was use BOV's for boost control instead of wastegates. Whole other topic though Smile
rb20det
Re: recommended BOV for 3SGTE (pretty stock) Fri, 16 July 2004 09:00 Go to previous message
im in ashfield (inner west). u can even drive the car to c if u like the sound.
Previous Topic:Benefit of dual coil system?
Next Topic:2ZZ-GE development doc
Current Time: Sat Oct 24 19:58:33 UTC 2026
Total time taken to generate the page: 0.0069890022277832 seconds
