Toymods » Tech & Conversions » Fuel Pumps- 1G-GTE Conversion
thomasbl
Melb
Fuel Pumps- 1G-GTE Conversion Wed, 14 July 2004 07:56 Go to next message
Hi Guys.
I am planning a 1G-GTE conversion for a RA28. I was wondering if i NEED to pump up to a surge tank and have a primary and secondary pump or whether i can just have one pump? Have never worked on injected engines, only V8's and rotors. Have heard that pumping up to a surge tank stops an engine from leaning out through heavy cornering- would this be essential then for a non-race or high performance car? Have worked on a RX3 coupe with a 13b and a holley blue pump, was track raced and didn't have problems (except for the noise). Any comments appreciated. Thanks. Tom
Bugman
Re: Fuel Pumps- 1G-GTE Conversion Wed, 14 July 2004 09:05 Go to previous messageGo to next message
I ran my ra28 just with a vl turbo pump without a surge tank and it would 'surge' on corners when below/around 1/4 tank
thomasbl
Melb
Re: Fuel Pumps- 1G-GTE Conversion Wed, 14 July 2004 12:30 Go to previous messageGo to next message
Thanks. Given that, it might be a good idea to go down the surge tank option. Any thoughts on where to place and mount an external tank?
ra23celica
Re: Fuel Pumps- 1G-GTE Conversion Wed, 14 July 2004 13:35 Go to previous messageGo to next message
I agree you will get 'surge' when you get down to 1/4 to 1/8 of a tank left, and I believe you get this when you use the standard 23/28 tank pick-up. Have you thought about grafting the pick-up from an EFI tank into your car and fitting a baffle / circular 'well' around the pick-up ?
I have the 12mm pick-up from a MX62 (complete with sock) welded into the top of my RA23 tank, and a 'well' welded around where the sock sits, in the bottom of the tank. This keeps some fuel always near the sock as the level drops.
Mitch.
Re: Fuel Pumps- 1G-GTE Conversion Wed, 14 July 2004 23:20 Go to previous messageGo to next message
What he said. A surge tank works but a baffled in-tank setup is much neater and may even be cheaper since you only need one pump.
EvilJack
Sutho/Hills NSW
Re: Fuel Pumps- 1G-GTE Conversion Wed, 14 July 2004 23:40 Go to previous messageGo to next message
ra23celica: are you running your setup with or without a surge tank?
ra23celica
Re: Fuel Pumps- 1G-GTE Conversion Thu, 15 July 2004 01:26 Go to previous messageGo to next message
Thanks Norbie.
No surge tank for me.
I can always go that way later on if I need to.
I have a half inch hose from the MX62 pick-up down
through a hole in the boot floor to a Camira fuel
pump attached via 2 captive nuts welded onto the
drivers side chassis rail, foward of the rear bumper.
Pump is mounted using a SV11 fuel pump 'cradle'.
8mm line runs forward to the 1G-GZE motor.
This all works fine.
Mitch.
EvilJack
Sutho/Hills NSW
Re: Fuel Pumps- 1G-GTE Conversion Thu, 15 July 2004 02:19 Go to previous messageGo to next message
hmm interesting, looking for a setup to get rid of the surge tank as are some others on the forums Razz
Siktoy ra23
Plumpton/sydney
Re: Fuel Pumps- 1G-GTE Conversion Thu, 15 July 2004 09:48 Go to previous messageGo to next message
The best thing about not having a surge tank is the vl fuel pumps fuck up very quickly im on my 2nd one in 6 months, don't be a tight arse like me and get one caus it is cheeper than buying another vl pump
That's my 2c
BEN
Bugman
Re: Fuel Pumps- 1G-GTE Conversion Thu, 15 July 2004 13:48 Go to previous messageGo to next message
I went through a few 2nd hand ones one testing a halfcut and a 2nd on my way to byron, bought a new one brand spanking new and never failed me again
ra23celica
Re: Fuel Pumps- 1G-GTE Conversion Thu, 15 July 2004 13:55 Go to previous messageGo to next message
Fair enough Ben. How come you have killed a VL pump ? It uses the fuel flowing through it to keep it lubricated and cool.
Do you know what failed ? The electric motor I assume.....
I have fitted a 'pre'-fuel filter in the line from the tank to the pump to give it some protection, downstream from the pump I still have the *main* filter attached to the engine.
Mitch.
Bugman
Re: Fuel Pumps- 1G-GTE Conversion Fri, 16 July 2004 00:07 Go to previous message
they kill em selves from running dry.
Previous Topic:common rust spots
Next Topic:how much can i port a 5m-ge head?
Current Time: Sat Nov 21 04:22:50 UTC 2026
Total time taken to generate the page: 0.0059139728546143 seconds
