Toymods » Tech & Conversions » Better motor to hot-rod?
V8_MA61
Better motor to hot-rod? Wed, 14 July 2004 07:59 Go to next message
A question regarding Cams and the appropriate engine design for me wanting to blow one of my 7mge's. Heres the two options:
A 7mge out of cressida, with the lower rpm orientated cams and intake ports, or ;
A 7mge out of a supra, with the split intake ports and its rpm/ sporty spec cams?
One would think for a blower, the more bottom end grunty cams in the cressida motor would be better for playing around with? Seeing as blower isnt so reliant on rpm to work.
Just an idea, as i have a mx83 motor in my garage that cost me very little, and seems to be in fine nic. I wouldnt mind stripping it down and making a ma70 "coupla year" project.
Computer for running this, would i need a Motec or is there something a little less expensive i could use?
Note: NO, I dont want a turbo.
For Hp figures, id like around 300-320hp at the flywheel.
[Updated on: Wed, 14 July 2004 08:01]
wilbo666
Re: Better motor to hot-rod? Wed, 14 July 2004 08:18 Go to previous messageGo to next message
It would be interesting to find out the lift and duration (such as Ed did) on both cams (did Ed do the MA70 or MX83 cams?) and see how large the difference in fact is Smile
(I guess you could always swap the cams and dyno as well, but setting up the shims would be painful, for what I suspect would be little gain...)
Also where do you plan to mount the SC? What type of SC? Plan to run 7M-GTE injectors? Intercooler? By the time you come to sorting out the ECU side of things, Ultra Mega Squirt should be out, which looks like it will be fantastic (start sucking up to charles!).
V8_MA61
Re: Better motor to hot-rod? Wed, 14 July 2004 08:26 Go to previous messageGo to next message
no intercooler. Not a neccessity really.
Mount the Sc at the front of the motor, a Vortech style one.
That is "if" when i do more research and measuring, an eaton one sitting on the side of the motor cant fit. As these are a lot cheaper.
Injectors would be the 1uzfe job id imagine. 400cc should do Wink
V8_MA61
Re: Better motor to hot-rod? Wed, 14 July 2004 08:33 Go to previous messageGo to next message
out of interest, if youre reading..how many hp did you achieve ed?
Re: Better motor to hot-rod? Wed, 14 July 2004 08:53 Go to previous messageGo to next message
V8_MA61 wrote on Wed, 14 July 2004 16:26
1uz injectors are 251cc
Re: Better motor to hot-rod? Wed, 14 July 2004 08:56 Go to previous messageGo to next message
V8_MA61 wrote on Wed, 14 July 2004 18:26
me thinks them injectors not big enuf for 6cyl S/C engine (even a low boost item) - i'm using 4agze on the turbo 18rc and they're 365cc - i'd aim for 7mgte (430cc) as a minimum otherwise you'll end up with the injectors at max duty before the power curve peaks and leanout (a precursor to rapid engine failure) will follow shortly after.
..are you sure it's safe to use the words "cheaper' and 'eaton' or even 'vortech' in the same paragraph? go to <www.capa.com.au> - after taking deep breath.
If you're not going to reduce compression then you really should consider some form of intercooling to reduce intake temps - a W/A unit perhaps?
you'll have to mount it high on the exh side or way low on the intake (like 1G-gze) so you'll have serious pipework to fabricate - so while you're doing that, you may as well plumb in a cooler?
oh... you'll need some kind of aftermarket computer - either commercial (haltech, motec, ...) of diy (megasquirt, UMS) - i think that's a given.
[Updated on: Wed, 14 July 2004 08:57]
V8_MA61
Re: Better motor to hot-rod? Wed, 14 July 2004 12:52 Go to previous messageGo to next message
Eaton m90's go for $700 everyday..and they're a substantial blower. More than enough for what id be looking at.
Id have to look more into the intercooler thing...But i cant really see it worth the $1000 the cooler itself costs! Its not Hot exhaust driven air like a turbo creates Confused
Re: Better motor to hot-rod? Wed, 14 July 2004 23:14 Go to previous messageGo to next message
It's a common misconception that superchargers don't "need" intercooling. The heat generated by turbos has almost nothing to do with the exhaust; the inlet charge gets hot because it's compressed. This is high-school physics stuff; have a look at the Ideal Gas Law for starters. This it applies to superchargers as well as turbochargers!
As mentioned above, if you're using a supercharger without lowering the compression, you'd be crazy not to use intercooling. The only way to stop it from pinging would be to run it on rocket fuel, or use fuck-all boost, or retard the timing to buggery. None of these are good options.
Get an intercooler, and it doesn't have to cost you a grand, that's just for the bling brand-name ones. Hell my uber-cooler only cost me $700 and you won't need anything half as big as that! Something like the Aristo cooler I have in my garage would work nicely, and you can pick them up for $200 tops.
Joshstix
Toymods Vice President
Re: Better motor to hot-rod? Thu, 15 July 2004 01:02 Go to previous messageGo to next message
You might want to take a look at how centrifugal superchargers work as well, if you think they will ba making boost without needing big revs. If you run something like a Vortec it will continue to build boost for as long as the engine increases revs. Maximum boost is reached at the redline so getting smaller cams for this kind of situation is a bad plan.
I also have to agree with Norbies reply to you, there is not really a lot of heat being transferred from the exhaust turbine to the intake air. A lot of situations will have far lower temperatures from a turbo than from a rootes blower at the same boost level simply due to the increased efficiency of the turbo.
[Updated on: Thu, 15 July 2004 01:03]
V8_MA61
Re: Better motor to hot-rod? Thu, 15 July 2004 07:59 Go to previous messageGo to next message
fair enough. thanks for telling me that.
Jeez, i thought your ice cube wouldve cost over 1200 norbie!!
What kind of psi could i run without it going nuts? This is with the mentioned intercooler...And what sort of power would i be expecting.
Re: Better motor to hot-rod? Thu, 15 July 2004 23:56 Go to previous messageGo to next message
With intercooling and good tuning (ie NOT stock ECU) I reckon you could safely manage 10psi. Not sure what power you'd end up with (supercharged 7M's aren't exactly common Razz ) but you'd probably fall somewhere between 250 and 300hp.
V8_MA61
Re: Better motor to hot-rod? Fri, 16 July 2004 15:04 Go to previous messageGo to next message
oh, i thought itd be more than 250hp...a whole 50hp isnt really worth the expense...so i might just do similar work to eds. Thanks for all info anyway guys. If i decide to go serious with it (wont be a looong time) then ill probbaly fully do it again to get 320+hp.
Thanks Again
Blake
chrisss
melb
Re: Better motor to hot-rod? Fri, 16 July 2004 16:49 Go to previous messageGo to next message
you mention getting an eaton m90 for $700.....I would like to know where?
I checked the capa site and its closer to $3000!!!!
ed_ma61
Lost in the K hole
Re: Better motor to hot-rod? Fri, 16 July 2004 18:34 Go to previous messageGo to next message
the difference between supra cams (acis manifold) and the cressida cams really is 4/5ths of fuck all. infact i suspect the lift and duration are identical, just the lobe separation angle is different (by somthing in the realm of 3-4deg)...
...to describe them as a 'low rpm' vs 'sportier' cam is completely crap. youd best consider them the same cam for practical purposes. theyre just tuned to the intake slightly differently.
as for the 'split' ports - these are acttually better for lower rpm use, the cressida ports with the blunt divider offer better total flow, and add turbulence for emissions and economy. this blunt divider is the better modified head for big output numbers... (these conclusions btw - came from an extensive design and flow discussion on PF's (GTS_Boy) and is not supported by actual flowbench data in modified and unmodified state)
and my engine, in current state of crapped out ring and dodgy tune: id be banking on about 250hp @ flywheel. gtech gives me 198hp at wheels. dyno showed ~101kw @ 38-4000rpm before shutting down due to pinging. i dont really care any more to be honest. the war is over...time to move on to bigger and better things Very Happy
Jag7799
Re: Better motor to hot-rod? Sat, 17 July 2004 00:42 Go to previous messageGo to next message
just help yourself and throw a 7m gte in there
just had a ride in my mates supercharged vl..
he's using a 1g gte blower before the throttle body and has a wastegate on the piping in between.
gives it a little wack of more power and torque through complete rev range(we thought it might hamper top rev range breathing being 3 litre with a 2 litre supercharger) but didnt..
sounds like a pig though.. sounds fine on boost.. but when off throttle.. wastegate sounds like a fucking chainsaw..
off topic.. but a mention Smile
V8_MA61
Re: Better motor to hot-rod? Sat, 17 July 2004 02:09 Go to previous messageGo to next message
chrisss wrote on Sat, 17 July 2004 02:49
I just saw that in the parts peddler magazine..they are used id guess.
Re: Better motor to hot-rod? Sat, 17 July 2004 07:53 Go to previous messageGo to next message
Why not supercharge a 7MGTE? Could work better/cheaper/simpler...
V8_MA61
Re: Better motor to hot-rod? Sat, 17 July 2004 09:38 Go to previous messageGo to next message
i dont think thered be enough room unless you bought a hella-expensive vortech one!
wilbo666
Re: Better motor to hot-rod? Sun, 18 July 2004 04:07 Go to previous messageGo to next message
V8_MA61 wrote on Sat, 17 July 2004 19:38
I think he was referring to using a 7mgte as the start point for the build up, lower compression, bigger injectors standard, oil squirter's, designed for forced induction etc Smile
Twin charged would be nice tho Very Happy
V8_MA61
Re: Better motor to hot-rod? Sun, 18 July 2004 13:25 Go to previous message
hmmm we shall see...i wish i was a millionaire or won lotto! Rolling Eyes
Previous Topic:Clutch Kit
Next Topic:4A-GE 100kw owners - power DROPS at 4.5-6Krpm (dyno pics)
Current Time: Mon Oct 26 19:25:16 UTC 2026
Total time taken to generate the page: 0.054325103759766 seconds
