Toymods » Tech & Conversions » common rust spots
christo
common rust spots Wed, 14 July 2004 08:26 Go to next message
hey i'm looking for a celica 1977 RA23 or TA22 or something like that and was wondering if anyone could give me infomation on the places i should look out for rust. thanx
fade-e
Re: common rust spots Wed, 14 July 2004 08:48 Go to previous messageGo to next message
- WINDSHEILDS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!! (not enough exclamation marks in the world for this) - down the bottome, mainly on the corners though
- passenger side, front (where the guard meets door down bottom (cause thats where the water runs to when it rains, when water goes in where windscreen washers are it runs to passenger side)
- boot (everywhere, if boot seal stuffed theres your answer)
- side railing, fuck forgot proper name for it (both sides, basically bottom side of car, very prone to rust HARD)
- passenger guard (passenger side front part)
- around the rear wheels (as being a rear wheel drive, mud gets stuck there unnoticed and after time.......)
- when you take out the whole interior where ever you can see metal and there is no tar to cover it (being the floor always water prone)
thats bout what i can remember... hope that helps BUT you know whats better than what i said????
SANDBLASTING Cool its the perfect way
christo
Re: common rust spots Wed, 14 July 2004 10:42 Go to previous messageGo to next message
thanks for that. ill have a look when i go look at this cars. cheers
dimmy77_03
Potts Point, Sydney
Re: common rust spots Wed, 14 July 2004 13:09 Go to previous messageGo to next message
Bottom of doors, EXHAUST and yes the windshield is a biatch Very Happy
fade-e
Re: common rust spots Wed, 14 July 2004 17:41 Go to previous messageGo to next message
if you read this before looking at the car then jere is a little trick that hardly anyone knows...
if you have a nice sized magnet (nothing huge), then while looking at the car run it over the car, use your hand to prevent it from hitting the actual car (you dont wnt to damage it)
what you are looking for is bog and rust!!! how can you tell?
- while you are running the magnet over the car you will notice that the magnet will want to stick to the car HARD and that means no bog or rust.
- if the power of the magnets attractio to the car decreases then there is either bog or rust DEFINATELY
if your thinking how will i know/how can i really tell... BELIEVE ME WHEN YOUR DOING IT YOU WILL NOTICE WHAT IM TALKING BOUT
i do this on all the cars i buy, the current TA22 i got has 5 bog spots (both side behind door badges, rear bottom passenger guard, behind door on seal panel, behind passenger rear wheel), other bad spots on the car are windsheilds (front and rear) and boot... but thats where the daily driver will come into play towards the end Very Happy
christo
Re: common rust spots Thu, 15 July 2004 01:49 Go to previous messageGo to next message
sweet mate. thats an awesome trick.
thanks for the help everyone Smile
geeza
Castle Hill (Sydney)
Re: common rust spots Thu, 15 July 2004 01:57 Go to previous messageGo to next message
ahhh yes the old magnet trick hehe Very Happy
i found a common spot to be underneath the crapet in the front footwells, there is a circle section there that doesn't appear to be well protected from the elements (except by carpet obviously)
and the rear hatch
hope this helps....and is in time =P
Re: common rust spots Thu, 15 July 2004 05:59 Go to previous messageGo to next message
When doing the magnet trick, use one of those pissweak little fridge magnets (you know the thin bendy ones) as it will only stick if it is very close to metal. A more powerful magnet will stick even if there is a fair layer of bog over the metal.
-NiCkeL-
Melbourne, Victoria
Re: common rust spots Thu, 15 July 2004 09:54 Go to previous messageGo to next message
Yeah, the best place to look is in the body... Smile
Make sure you give it a good once over, and then look at it again. Even come back the next day after the excitement wears off (don't get too anxious about buying a car) and look again.
The smaller the magnet the better...those small fridge magnets don't stick to metal very well, there's no chance they'll be sticking to bog!
fade-e
Re: common rust spots Thu, 15 July 2004 11:15 Go to previous messageGo to next message
i would agree with you guys to an extent! the extent is this, those magnets barely stick onto fridges with 1-2layers of paint so how would it be when there is etch primer, primer, colour and clear (and im talking from factory. but like my car where iv put 2layers etch, 3layers primer, 5layers colour and 3layers clear... you recon the magnet will stick anywhere? what if the car has been painted on top of old paint (colour change)
thats why i said to use a good magnet and be sure not the scratch the car
Re: common rust spots Thu, 15 July 2004 23:51 Go to previous messageGo to next message
Yes it will stick through the paint; I'm not just making this up, I've actually used this trick many times before when looking at second-hand cars!
Purple_Beasty
New Zealand
Re: common rust spots Fri, 16 July 2004 00:22 Go to previous message
You used to be able to buy a magnet in a plastic tube over here in NZ just for this purpose. The closer it pulled the magnet to the body the less bog in it, and the plastic protected the paintwork.
Then some bright bastard invented Newtech which is like bog with metal filings in it, not sure if you guys get that in Aussie or not. Magic stuff for hiding rust hehehe hehehe hehehe
Callum
Previous Topic:carbie questions for a 4ag
Next Topic:Fuel Pumps- 1G-GTE Conversion
Current Time: Sat Nov 21 04:07:45 UTC 2026
Total time taken to generate the page: 0.005403995513916 seconds
