Toymods » General Car Talk » replaceing ae86 suspension
chrisellis
replaceing ae86 suspension Wed, 14 July 2004 12:46 Go to next message
I just ordered myself a new set of shocks (KYB monotube)for my aus spec sprinter. Any tips or tricks from anyone thats done this b4 can provide would be usefull thanks.
ae86drift
sydney.au
Re: replaceing ae86 suspension Wed, 14 July 2004 12:55 Go to previous messageGo to next message
man this job is so easy its almost comical
fronts and backs?
chrisellis
Re: replaceing ae86 suspension Wed, 14 July 2004 13:00 Go to previous messageGo to next message
only backs. if i had a job id be doing all 4 and more.. lucky i get these at cost price otherwise i couldnt even afford these 2, lol. Well as long as its easy forget i asked. Thanks.
ae86drift
sydney.au
Re: replaceing ae86 suspension Wed, 14 July 2004 13:14 Go to previous messageGo to next message
haha so easy
1. crack wheel nuts
2. jack up car onto jackstands
3. take wheels off
4. undo bolts (14mm?) from bottom of shocks
5. undo bolts from top of shock
6. take shock out
7. put new shock in
8. reverse steps 5 - 1
done
SeptemberSquallIndustries
Re: replaceing ae86 suspension Fri, 16 July 2004 06:27 Go to previous messageGo to next message
ae86drift wrote on Wed, 14 July 2004 23:14
"Installation is the reverse of removal..."
koen
Re: replaceing ae86 suspension Fri, 16 July 2004 07:25 Go to previous messageGo to next message
Where can i get spring compressors? I'll be changing the springs in my 86 tomorrow and i'm gonna need to get some. Do supercheap et al stock them? Guess i'll find out in the morning...
Re: replaceing ae86 suspension Fri, 16 July 2004 08:10 Go to previous messageGo to next message
Um, East Coast auto spares, or Supercheap, or Repco (by that order of preference?)
koen
Re: replaceing ae86 suspension Fri, 16 July 2004 08:19 Go to previous messageGo to next message
Sweet, thanks man.
bathurst-91
Re: replaceing ae86 suspension Sat, 17 July 2004 07:48 Go to previous messageGo to next message
You basically dont need spring compressors (unless your running stock heights). Mine are 60mm lower than standard which is fairly low i suppose. I had the car jacked up in areas other than the rear end shaft (which is dangerous if not done right) but this basically means u can just push down the rear end with your hand and slip the spring in!
arena
brisbane queensland
Re: replaceing ae86 suspension Sat, 17 July 2004 09:51 Go to previous message
ok guys sorry and all but u are complicating the process.
1. jack car up.
2. put car on stands. (safety first)
3. undo bottom and top bolts on strut. (top bolt in boot area of car.)
4. bolt new strut in place.
5. let car down.
unless you have coilovers then you will not need to compress the spring as the hatchi runs seperate spring and strut combination.
Previous Topic:things to look for when buying a car
Next Topic:temperature guage problem
Current Time: Wed Oct 14 23:52:58 UTC 2026
Total time taken to generate the page: 0.015394926071167 seconds
