Toymods » General Car Talk » Torque & Horsepower & Acceleration
river
Land of Oz
Torque & Horsepower & Acceleration Thu, 15 July 2004 07:46 Go to next message
I've been watching an argument going on regarding torque and horsepower, in relation to acceleration.
One dude says its the torque that provides the acceleration and the turning power to the wheels and that's what does the work. The other dude says it's the horsepower that does the work and it's horsepower that gives the acceleration.
I've asked it before, and I'll ask it again... someone illuminate me on this?
seeyuzz
river
V8_MA61
Re: Torque & Horsepower & Acceleration Thu, 15 July 2004 07:50 Go to previous messageGo to next message
torque = greater launching speed/ power. its the factor that makes it jerk off the line.
[Updated on: Thu, 15 July 2004 07:50]
Fro-Daddy
Re: Torque & Horsepower & Acceleration Thu, 15 July 2004 08:13 Go to previous messageGo to next message
i thought that torque controlls the hp...like if u have hardly any torque and 1000hp, you wont get to use the 1000hp...but if u have 1000nm torque n hardly any hp then you would use all that really quickly...
so its combination of both, but if 2 cars weigh the same, have the same hp but different torque, the one with higher torque will win...
if the hp is the only difference, i think the one with more hp will have greater top-end power..
nb - I THINK!
river
Land of Oz
Re: Torque & Horsepower & Acceleration Thu, 15 July 2004 08:18 Go to previous messageGo to next message
Okay. But a small tractor has massive torque and little horsepower, yet it couldn't out accelerate a normal car, even though it has more torque.
I'm trying to get my head around this one. Trying to figure the relationship.
seeyuzz
river
Skip
Re: Torque & Horsepower & Acceleration Thu, 15 July 2004 08:57 Go to previous messageGo to next message
Once again:
Torque = (Power x 60)/(2Pi x RPM)
Basically your car will accelerate faster the more power it has over a larger rev range.
What fro-daddy says is not really correct either. Youll probably find the car with the most area under it's power graph will win the acceleration race, even if it has slightly less torque.
A small tractor will not out accelerate a car cause it's only geared to do say 30-40km/h, not 180km/h, simple really.
ed_ma61
Lost in the K hole
Re: Torque & Horsepower & Acceleration Thu, 15 July 2004 09:05 Go to previous messageGo to next message
in simple terms:
torque is required to accelerate a rotating object (ie wheel)
the more torque you have, the faster it will accelerate.
horsepower is a term used to describe the ability of torque to continue accelerating a rotating object at higher and higher rpms.
ie - a powerful engine wih massif horsepower is due to its engine continuing to produce large torque even at high rpms.
so, in answer, torque accelerates a car - whether that be from standstill, or whilst roling. the more torque, the faster it will accelerate. the ability for a car to continue accelerating when already going fast requires yet more torque, and this is generally referred to as horsepower.
Cyber-punk
Brisbane, QLD
Re: Torque & Horsepower & Acceleration Thu, 15 July 2004 09:12 Go to previous messageGo to next message
ed_ma61 wrote on Thu, 15 July 2004 19:05
in simple terms:
i like that answer the best
and as i try interpret it
with the tractor, lots of torque...feck all hp
soooo it has the ability to accelerate fast...but not for long because of crap gearing?
or have i gotten myself confused?
ed_ma61
Lost in the K hole
Re: Torque & Horsepower & Acceleration Thu, 15 July 2004 09:15 Go to previous messageGo to next message
forget gearing - think of only the engine
st184 sillycar
Re: Torque & Horsepower & Acceleration Thu, 15 July 2004 11:17 Go to previous messageGo to next message
Power = Torque x R.P.M.
The governing factor in acceleration is the torque available AT THE WHEELS. A torquey engine that won't rev needs tall gears, and as gearing gets taller (to give more speed) the torque at the wheels is reduced linearly. Conversley, a rev-happy motor that makes little torque can drive quite short gears, which don't reduce the torque available at the wheels as much.
So there ya go - a torque-monster that won't rev loses it's legs once the speed builds and it's gotta push a tall gear.
Also, a short-stroke screamer relies on short, close gearing to keep it revving, and multiply it's meagre torque.
dimmy77_03
Potts Point, Sydney
Re: Torque & Horsepower & Acceleration Thu, 15 July 2004 13:30 Go to previous messageGo to next message
in simple terms:
Thanx ed, thats a pretty sweet ass answer Very Happy
[Updated on: Thu, 15 July 2004 13:30]
YelloRolla
On your mum!
Re: Torque & Horsepower & Acceleration Thu, 15 July 2004 14:06 Go to previous messageGo to next message
Ed's answer is good.
Skip's answer is technically correct.
YelloRolla's answer is something like this. Torque is the force required to turn something (crank, gears wheels etc) - horespower is derived from the torque at a specific RPM.
So following the formula Torque x RPM/5251 = HP.
A motor that makes lot's of torque at low RPM (IE Cummins diesel with 420HP at 2600rpm) is also making a shitload of power at the same RPM. Transposing that formula we can work out that it is making about 850ft/lbs of torque (at 2600RPM and it would have made more at a lower RPM).
A 1600cc 4A GTE making the same 420HP @ 8500rpm will need 260ft/lbs (at 8500RPM).
HP refers to rate of work and trying to separate it from torque in the context of engine output is just not possible (Like trying to talk about the speed of a vehicle and then trying to separate the kilometers from the hours - it is futile).
Shraka
Re: Torque & Horsepower & Acceleration Thu, 15 July 2004 14:42 Go to previous messageGo to next message
As has been stated, torque * RPM = Power.
Torque at the wheels can be changed by different gear ratios. Power at the wheels cannot be changed by different gear ratios.
So technically, you want as much power as you can get, and just fit the right gears and diff to it to make up for torque.
Generally, when talking about drag races, V8s big strokers do a pretty good job 'cuz they hit torque very low in the rev range so it's easy to launch them. Though once it hits it's Torque peak, the torque curve drops off. This means that even though the power is going up through the rev range, it's not gaining as well as it could. So once a V8 (and I'm talking the big strokers here, not 4.0 or less ltr V8s) has launched it just gets all kinds of wrong and you are wasting a lot of displacement to make not so great power.
On the flip side a Honda VTEC engine hits max torque way up in the heady regions of RPM. This means it can't get off the line as quickly without a really clever launch. It does however mean that as the RPMS get higher, so does the torque so the power gains get quicker and quicker the higher you go. By keeping the torque up higher in the rev range, short stroker engines can get much better power / displacement ratios. Short strokers also make for better track race engines IMHO as their power up high is better (even if there is less of it than a big stroker V8).
Or so I have been told. Correct me if I'm wrong those of you who are more knowledgeable than I.
Skip
Re: Torque & Horsepower & Acceleration Thu, 15 July 2004 23:30 Go to previous messageGo to next message
That wouldnt be a 6CTA8.3 by any chance would it?
MS-75
Re: Torque & Horsepower & Acceleration Fri, 16 July 2004 03:58 Go to previous messageGo to next message
The only way you'll truly come to grasp the relationship between torque and horsepower is to get a physics book and start reading. Any mention of gearing, engine size, no. of cyls is putting the cart before the horse and will merely confuse the issue. You should be able to find it on the net-and until you have grasped the underlying concept AVOID any automotive type sites as they are generally incorrect or terribly explained. Also, when you search, use 'power', not 'horsepower' as you want to find a site explaining it all in proper metric units-ie kW and NM. Once you've had a look at that stuff, then begin applying it to engines (otherwise trying to comprehend it all in one go is near impossible)
Going straight to the source and learn from first principles is your best bet.
Be aware that if you ever hear and 'argument' or 'debate' regarding torque and power that what you are in fact hearing is a pointless discussion between two people, neither of whom fully understand the basic principles Laughing Laughing Laughing Laughing Laughing
Sean
President of Engineers Against the Misunderstanding of Torque and Power society................(and vice president of the Engineers for Surfing the Web During Work Time society.....)
[Updated on: Fri, 16 July 2004 04:00]
lumpy
Adelaide, SA
Re: Torque & Horsepower & Acceleration Fri, 16 July 2004 04:13 Go to previous messageGo to next message
You enginneers are all torque and no traction! Laughing
[Updated on: Fri, 16 July 2004 04:22]
Skip
Re: Torque & Horsepower & Acceleration Fri, 16 July 2004 04:49 Go to previous messageGo to next message
Proper engineers shouldnt have enough time to be surfing the web during work hours Smile
wil8115
Seattle area, USA
Re: Torque & Horsepower & Acceleration Fri, 16 July 2004 08:10 Go to previous messageGo to next message
heres one for ya...
drive along in 2nd gear at the peak HP@rpm for your engine and floor it..
take note of what happens..
then drive along in 2nd gear at or just below your peak torque @rpm..
i'm sure you'll figure it out..
Skip
Re: Torque & Horsepower & Acceleration Fri, 16 July 2004 08:41 Go to previous messageGo to next message
The neighbours start throwing rocks at your car? Smile
mick
toowoomba qld
Re: Torque & Horsepower & Acceleration Fri, 16 July 2004 08:53 Go to previous messageGo to next message
Skip wrote on Fri, 16 July 2004 18:41
Laughing
mick
toowoomba qld
Re: Torque & Horsepower & Acceleration Fri, 16 July 2004 08:57 Go to previous messageGo to next message
wil8115 wrote on Fri, 16 July 2004 18:10
heres one for ya...
very true. Smile
wil8115
Seattle area, USA
Re: Torque & Horsepower & Acceleration Fri, 16 July 2004 09:15 Go to previous messageGo to next message
LOL.. well maybe, tough 'hood? Laughing
but you understand the point i was trying to make. Smile
Skip wrote on Fri, 16 July 2004 01:41
st184 sillycar
Re: Torque & Horsepower & Acceleration Sat, 17 July 2004 05:24 Go to previous message
At their peak h.p, an F1 engine puts out around 870hp, at 18700rpm
right? Right.
power / rpm = torque
that gives 465Nm of torque at peak rpm. which is 155Nm/Litre
This compares to a M3's 114Nm/Litre.
Then again the M3's super-six should go for about 450,000km without a rebuild, whereas the F1 engine struggles to get past 450km. hmmmm..
no point. That's just the torque/h.p. thing in action. There's plenty-more torquey engines around (Porsche GT2 makes 172Nm/L) but none that Rev like that.
The Porsche makes 460hp from it's 3.6L Turbo at 6800rpm, btw. Very Happy Very Happy
Previous Topic:$205 per 17x7" wheel: Same weight as $300 Buddy-clubs. (look better too, imho)
Next Topic:17inch Speedy Wheels (What do ya think?)
Current Time: Sat Oct 17 23:01:53 UTC 2026
Total time taken to generate the page: 0.0068299770355225 seconds
