Toymods » Tech & Conversions » Benefit of dual coil system?
Maurice c
Benefit of dual coil system? Fri, 16 July 2004 00:47 Go to next message
HI guys,
I've seen a couple of dual coil systems around in highly tuned cars. Some sports bikes that I have had over the years have had them too. I was just wondering what advantages this set up had over a regular single coil set-up. Thanks
Re: Benefit of dual coil system? Fri, 16 July 2004 01:36 Go to previous messageGo to next message
Twice as many coils means the coil has twice as long to "charge up" before discharging. Basically it gives you a stronger spark. This is frequently necessary for 8 cylinder engines with high rev limits.
Hunty
Re: Benefit of dual coil system? Fri, 16 July 2004 06:29 Go to previous messageGo to next message
so total overkill on 4 cyl??
M.W.P.
Rocky Mountains, Canada
Re: Benefit of dual coil system? Fri, 16 July 2004 09:49 Go to previous messageGo to next message
Unless your frequently reving to > 10K RPM, yes.
Re: Benefit of dual coil system? Fri, 16 July 2004 10:58 Go to previous message
It would be good if you're converting to distributorless ignition (you only need two coils in a wasted-spark config), but otherwise no don't bother.
Previous Topic:3sge - removal *HELP*
Next Topic:recommended BOV for 3SGTE (pretty stock)
Current Time: Sun Oct 25 05:45:26 UTC 2026
Total time taken to generate the page: 0.036020040512085 seconds
