Toymods » Tech & Conversions » 2tg-18rg timing chain tensioner
Azrael
Crapberra
2tg-18rg timing chain tensioner Fri, 16 July 2004 04:25 Go to next message
Are the top timing chain tensioners from a 2tg and an 18rg interchangable?
Thanks in advance
Az
ChuckLandwehr
Re: 2tg-18rg timing chain tensioner Fri, 16 July 2004 07:35 Go to previous messageGo to next message
Az, one has a mushroom head on the shaft, the other is a simple shaft. As the ends only bear against the back of the chain guide plate, I cant see that it would make much difference if you used an 18RG tensioner in a 2TG.
regards Chuck.
wil8115
Seattle area, USA
Re: 2tg-18rg timing chain tensioner Fri, 16 July 2004 07:53 Go to previous message
both engines used both types.
the slipper is designed to use one or the other.
mix'n'matchin might yeild an undesirable result. to tight or to lose even with adjusting it..
then again it might work just fine.
i always used
mushroom tip for mushroom tip.
and straight plunger for straight.
Previous Topic:How to get more power from supercharger
Next Topic:Spark plug leads for 1G???
Current Time: Sat Nov 21 02:53:21 UTC 2026
Total time taken to generate the page: 0.0037229061126709 seconds
