Toymods » Tech & Conversions » JZZ30 Soarer - Axle Tramp
Soarer
Wollongong
JZZ30 Soarer - Axle Tramp Fri, 16 July 2004 06:56 Go to next message
Howdy all,
Time for my once a year question Razz
Since converting my car to R154 manual and A02B Torsen LSD, I now experience quite a bit of axle tramp on harder launches.
Two basic questions:
1. What can cause axle tramp ?
2. How can I attempt to fix it ?
I've got shocks that are approx. 12 months old installed (KYB) and running A'PEXi lowered springs (about 1.5" lower than stock) just as some background info.
E30-323ti
Re: JZZ30 Soarer - Axle Tramp Fri, 16 July 2004 09:13 Go to previous messageGo to next message
A friend of mine has a VVTi 1JZ in his Tourer V with a R154 & A02B and it has no axle tramp issues, I presume the rear suspension geometry is very similar.
His diff mounts are very soft and you can hear the diff going thud thud when it is bouncing on the limiter or hard gear changes.
What tyres are you running??
[Updated on: Fri, 16 July 2004 09:15]
Soarer
Wollongong
Re: JZZ30 Soarer - Axle Tramp Fri, 16 July 2004 09:17 Go to previous messageGo to next message
I'm running Falken 235/40-18 tyres at 38psi.
Re: JZZ30 Soarer - Axle Tramp Fri, 16 July 2004 10:59 Go to previous messageGo to next message
Either your shocks are too soft or one or more bushes are shagged.
V8_MA61
Re: JZZ30 Soarer - Axle Tramp Sat, 17 July 2004 03:20 Go to previous messageGo to next message
yeah, you really shouldnt be getting tramp with one of those diffs unless u had mega hp!
Soarer
Wollongong
Re: JZZ30 Soarer - Axle Tramp Sat, 17 July 2004 05:05 Go to previous messageGo to next message
Don't really know about the shocks being too soft. They are apparently Street/Sport series, so they shouldn't be either too hard or too soft. Will have to check out any bushes in the vicinity.
Hmm... I'm running a fair whack more power than factory. 2 new turbos plus a whole load of other goodies now. After a tune it'll be putting over 200kW easily at the rears.
Re: JZZ30 Soarer - Axle Tramp Sat, 17 July 2004 07:25 Go to previous messageGo to next message
I have 228rwkw in a much lighter car. It used to tramp like a champion with the old shocks, but with new (firmer) shocks it's completely gone now.
mx83toy
Re: JZZ30 Soarer - Axle Tramp Sat, 17 July 2004 07:51 Go to previous messageGo to next message
man these cars arse ends are pretty much imune to axle tramp...i have a torsen in the cressi and some times they get visious wen trying to grab at traction (to the point of twisting the diff off the crossmember Very Happy) get some one to film the car launching from the back and on each side and you'll find the (tramp is the diff trying to stop wheel spin and grab traction "it feels terrible though")
cambelt
melb
Re: JZZ30 Soarer - Axle Tramp Sat, 17 July 2004 13:55 Go to previous messageGo to next message
dont you u use jza 80 rear suspension bits to help solve the tramp problem in a soarer , just somthing i read somwhere.
Jag7799
Re: JZZ30 Soarer - Axle Tramp Sun, 18 July 2004 01:06 Go to previous messageGo to next message
i find mine does this aswell... but i find its cause of the fucked shocks .. need to swap suspension over from other car
acmtt
Re: JZZ30 Soarer - Axle Tramp Sun, 18 July 2004 13:39 Go to previous messageGo to next message
You are right Cambelt. The rear cradle mounts are perforated rubber standard and need to be replaced with the Supra solid ones. The trick is getting some!! They swapped over in 96 and its a lucky dip even when you order new ones as to what you will actually recieve.
cambelt
melb
Re: JZZ30 Soarer - Axle Tramp Sun, 18 July 2004 13:44 Go to previous messageGo to next message
but if you order new supra ones wouldnt you get the solid mounts
or does toyota just give u what comes from japan.
acmtt
Re: JZZ30 Soarer - Axle Tramp Sun, 18 July 2004 13:50 Go to previous message
At $176 each with discount i wasn't going to try my lack of luck.
I have heard of others that ordered them and got the soft standard Soarer mounts.
I am now after a set of rooted mounts to get a friend to pour some solids for me to test.
I suffer the axle tramp affliction.
Previous Topic:Carb to EFI Conversions
Next Topic:4 speed autos for corona st141 ????
Current Time: Mon Oct 26 08:43:28 UTC 2026
Total time taken to generate the page: 0.0045900344848633 seconds
