Toymods » Tech & Conversions » dodgey idle
DunkyMonkey
Brissy QLD
dodgey idle Sat, 17 July 2004 08:11 Go to next message
hey ppls
heres the problem, my car has a lumpy idle(its a celica 1990 ST184), you can quite literally watch the tacho bounce up and down, it pretty dodgey, i looked it up in the hanes teardown and rebuild manual, give the usual possible problems for this:
+ vacume sensor leaking,
+ insignificat fuel
+ EGR valve leaking
+ head gastket
+ timming belt worn/cam pullys worn
the car with out throattle feels like the map sensor is goin, however i had this replaced a couple of months ago, i don't belive that its anything to do with the fuel as it seems to be running very rich when cold, once warm it doesn't run rich that i can tell.
i checked all the little pipes that were comming off the throttle body, none of them seem to be leaking how ever some of them look like they are starting to crack from heat.
the timming belt was changed about a month b4 the map sensor.
toynado
Re: dodgey idle Sat, 17 July 2004 13:32 Go to previous messageGo to next message
air leak
intake air leak
injector rubber?
DunkyMonkey
Brissy QLD
Re: dodgey idle Sat, 17 July 2004 14:24 Go to previous messageGo to next message
air is not leaking, in intake pipe is one complete piece and it is map sensored as in i don't have an AFM so i wouldn't change anything.
injector rubber?
dingaling
tas
Re: dodgey idle Sat, 17 July 2004 18:13 Go to previous messageGo to next message
maybe you guys can give me some advice for a friends celica (1st gen 3sge)
his idle is all over the place once the car warms up. the idle is changing from 1000rpm to a nearly staling 400rpm. My guess is it's the Idle speed controller, but i don't know for sure, maybe it is a leaky pipe but so far i have not found any leaky pipes. what are some things to check? is the TPS a possibility with these engines?
I don't have a 3sge service book wich makes it difficult.
[Updated on: Sat, 17 July 2004 18:14]
Toobs
Re: dodgey idle Sun, 18 July 2004 09:22 Go to previous messageGo to next message
Have you reset the ECU lately?
To reset the ECU properly you must:
1. Get the car to operating condition
2. Turn the car off and remove the EFI fuse
3. Wait 30 odd seconds then reinstall the fuse
4. Start the car... wait for the idle to stabilise
5. Then turn the car off and repeat process 4 a couple more times
6. Once the idle has stabilised go for a drive for 15 mins.
sik sx
Sunshine Coast
Re: dodgey idle Sun, 18 July 2004 09:36 Go to previous messageGo to next message
dingaling is ur mates A/C on when it is ideling like shit?..mine does that to..it still idles crap with out it on but like wayyyyyyy better then when the ac is on..oh and when my lights turn on the idle drops to..any ideas?
dingaling
tas
Re: dodgey idle Sun, 18 July 2004 10:36 Go to previous messageGo to next message
yeah those are the same symptoms. That's why i suspect the ISC (idle speed controller)isn't doing it's job. it should be revving the engine higher to compensate for the load on the alternator.
does your 3sge idle fine when you first start it up? then when it warms up starts doing the funny idle thing yet drives perfectly fine?
i'll try what toobs suggested.
Is there a 3sge service manula online anywhere?
[Updated on: Sun, 18 July 2004 10:39]
DunkyMonkey
Brissy QLD
Re: dodgey idle Sun, 18 July 2004 13:30 Go to previous messageGo to next message
i just want to get my new engine!!!! anyone know incurance is like on a car with a new engine ~different of course, i want a series 3 3SGE~
TA22
Re: dodgey idle Sun, 18 July 2004 16:26 Go to previous messageGo to next message
my celica does that too. its a 2TGEU and the idles keep hunting.. no ones ever been able to solve my problem. could it be the cam timings?
FKN16V
NSW, East Coast
Re: dodgey idle Sun, 18 July 2004 23:28 Go to previous messageGo to next message
dingaling wrote on Sun, 18 July 2004 20:36
This situation sounds like a dirty/old o2 sensor(disconnect it and see what happens), or extremely dirty throttle body?
DunkyMonkey
Brissy QLD
Re: dodgey idle Sun, 18 July 2004 23:31 Go to previous messageGo to next message
wow, there are a few celica's with dodgey idling speeds, all different models??
i think my cams might be out by a little bit but i don't see how thats possible, wouldn't the engine have a spack if it were?
DunkyMonkey
Brissy QLD
Re: dodgey idle Mon, 19 July 2004 00:08 Go to previous messageGo to next message
thanks to toobs, this appears to have fixed my problem by resetting the ECU, about to go take it for a drive, any thoughts on why the ECU would make it proform like that?
update: my car must be stuffed, its comming back but its not as sereve as it was b4 however its very notice-able rolling in gear!!
anyone know what could be wrong?
[Updated on: Mon, 19 July 2004 01:30]
TA22
Re: dodgey idle Mon, 19 July 2004 16:45 Go to previous messageGo to next message
these cars like to play games.. i got mine tuned at a carby place $40 on the o2 machine.. got it adjusted sweet as.. driving off 10 mins later back to the same shit...
DunkyMonkey
Brissy QLD
Re: dodgey idle Tue, 20 July 2004 01:59 Go to previous messageGo to next message
well thats gotta suck don't it
Toobs
Re: dodgey idle Tue, 20 July 2004 10:13 Go to previous messageGo to next message
I don't know why it does it but whenever I have to work on the car and pull the -ve terminal off the battery it idles like c-rap until i've followed the process above.
And yes my idle up switch thingy was stuffed too at one stage and the car idled really low when the aircon was on but a trip to pickies fixed that pretty quick...
DunkyMonkey
Brissy QLD
Re: dodgey idle Tue, 20 July 2004 13:40 Go to previous messageGo to next message
well hopefully the 3sge engine i'm looking at insalling wants kill me as much as this one.
dingaling
tas
Re: dodgey idle Tue, 20 July 2004 13:50 Go to previous messageGo to next message
i'll be working on my friends 3sge celica on friday or saturday, i will let you guys know what i find out.
DunkyMonkey
Brissy QLD
Re: dodgey idle Tue, 20 July 2004 14:22 Go to previous messageGo to next message
anyone tinkered with a series 3 3sge???? we didn't get the 202 celica here so that leaves MR2 drivers!!!
allencr
tallahassee FL usOFa
Re: dodgey idle Tue, 20 July 2004 15:05 Go to previous messageGo to next message
does this things throttle body have 2 small coolant hoses connected to a valve on it? if so, that valve can cause these symptoms.
DunkyMonkey
Brissy QLD
Re: dodgey idle Wed, 21 July 2004 08:06 Go to previous messageGo to next message
i dunno i'll look in the morning, where about is this valve usually situated, near the butterfly?
toynado
Re: dodgey idle Wed, 21 July 2004 21:11 Go to previous messageGo to next message
describe wen and how the idle goes bad
it idles smooth wen cold?
but higher rpm's, right?
how rythmic is it wen it's not right?
duz it stay the same or fluctuate the rhythym?
has to be air/gas mix, right?
so you got an air leak i assume
wut do the plugs look like?
hav you checked the spark wen it duz it?
dar_sbb
Re: dodgey idle Thu, 22 July 2004 00:55 Go to previous messageGo to next message
I got the same issue with my 1gen 3sge.
It happens to me after braking most of the time (the brake booster normally would lower revs for a lil but..) it will drop from 800rpm to 350rpm then back up to 1000rpm then back down to 350rpm and so on...
To stop it from happening a lot, cause i feel like a wanker next to people in traffic with the car like this... i turned the idle up to 1000rpm... it fixed the problem till i find out what is really wrong.
rb20det
Re: dodgey idle Thu, 22 July 2004 08:25 Go to previous messageGo to next message
i also have uneven idle on my car 3tgte, it idles smooth for about 10sec then drops to 300rpm and stalls if i dont rev it back up. (everybody thinks i want to drag them wen this happens Embarassed ) is there a way to manually adjust the idle without taking it to a dyno place. car also has microtech digi 1 computer.
Alchemist
Re: dodgey idle Thu, 22 July 2004 11:10 Go to previous messageGo to next message
I had a similar problem with my 2T-GEU in my TA23, adjusted the AFM and it seemed to solve the problem, lost a bit of fuel efficiency, but it certainly idled much more reliably.
DunkyMonkey
Brissy QLD
Re: dodgey idle Thu, 22 July 2004 14:16 Go to previous messageGo to next message
okay well my current engine is the one it question its a 5SFE, the actual problem is that it flucuates at idle or basically when no throattle is applied, this means that when in gear and no throattle is applied you can feel little "jerks" thru the car and if you didn't know better you would assume its just bumps in the road. the engine almost seems like its not balanced if you know what i mean, it will regularly fluctuate between lower and higher parts, and as my timming belt is too tight, and i have my idle turned up to lose the rotten shake it sends thru the car you can hear it.
toynado
Re: dodgey idle Thu, 22 July 2004 17:25 Go to previous messageGo to next message
i'm not familiar with that motor and efi
but
sounds like you hav a rhythmically regular idle offense
which means it's it's an intake air leak
could possibly be caused by the efi
i'd think the ecu is fine, it may be reacting to a sensor input
i dun hav a map sensor
on my 22re, there's not much to the idle circuit
you could try taking sum 02 sensor readings wen the idle goes bad
on a 22re, if you turn up the idle rpms, it soon starts surging up and down as the ecu tries to correct the idle a/f mix
i had a slight dip in idle speed every 2 1/2 seconds
it wuz an injector grommet sucking in air
i could see a spark plug looked 'dry' on one cylinder
so i knew where to start my search ...
dingaling
tas
Re: dodgey idle Sat, 24 July 2004 06:45 Go to previous messageGo to next message
Hey fella's I had a look at my friends 3sge ( has a fluctuating idle when warmed up)
i reset the ECU 5 or so times like toobs suggested, didn't fix it. disconnected the oxygen sensor and it didn't seem to make a difference, so perhaps the 02 sensor is bad? i'd need to measur its reading with a multi meter, actually the car smelt like it was running rich so perhaps the O2 was working.
I'm quite sure it's a sensor of some sort out of tune, or just not working, but i need a 3sge service manual to check it out properly.
any suggestions as to what to check?
ctan13
Malaysia
Re: dodgey idle Sun, 12 September 2004 07:23 Go to previous messageGo to next message
Hi guys,
This is my first post here, so hope you guys can help me out on this ...
My EE90 is using a transplated 4AGE 16V. What I am experiencing currently is this :
- each time I depress the brakes, RPM drops by 100. If the car is idling @ 750, it'll drop to 650, causing the car to vibrate quite badly and I have to release the brakes to stop the vibrations
- each time the radiator and engine fans come on, the RPM meter swings up and down, from 750 to 600 and back, and the whole car vibrates badly
All this is with the aircon off ... with the aircon on, sometimes the RPM will drop to 500, then go back up again. So when all this is happening at the same time, the engine like want to quit and the RPM swings up and down.
Any ideas anyone?
dingaling
tas
Re: dodgey idle Sun, 12 September 2004 08:18 Go to previous messageGo to next message
check the idle speed controller.
does the car drive fine otherwise?
amwtoy
Re: dodgey idle Sun, 12 September 2004 13:49 Go to previous messageGo to next message
I had that same problem with my RPM dropping when i hit the brakes. I even posted about it here Smile People said it was normal and nothing to worry about, but after a while my car would just stall when i hit the brakes. My mechanic finally figured it out this weekend - when all the stuff was on, the battery wasn't being charged. As a result, the spark would get weaker and weaker till the engine died... and then it wouldn't start again. I guess it could be an alternator problem (or maybe slipping fan belt) but in my case i needed a new regulator wired up. Now i still lose a bit of revs when all the accessories are on, but the battery is still getting enough juice to charge so the engine doesn't fall over.
ctan13
Malaysia
Re: dodgey idle Sun, 12 September 2004 14:04 Go to previous messageGo to next message
dingaling,
Yes, the car drives fine otherwise. Sorry, newbie here - just where is the ISC located? Thanks.
dingaling
tas
Re: dodgey idle Mon, 13 September 2004 03:39 Go to previous messageGo to next message
under the throttle body, i should find a pic to show you. (let me know and i will find a pic)
Thing is this Idle Speed Controller is ment to rev the engine up when there is a big electrical load on the alternator. The AC has it's own idle up sensor. It sounds like all your idle issues happen when there is a load on the alternator, so that narrowes out vaccuum leaks.
download this and have a read of it.
members.dodo.net.au/~urantiacjd/h60.pdf
ctan13
Malaysia
Re: dodgey idle Mon, 13 September 2004 03:49 Go to previous messageGo to next message
dingaling, yes a picture would certainly help a lot...
dingaling
tas
Re: dodgey idle Mon, 13 September 2004 04:02 Go to previous messageGo to next message
since i don't own the celica i can't get you a good pic, but i have a part i can take a pic of and draw in the rest to show you were the isc is. will post later.
also have a look at this PDF it will really help you i'm sure.
members.dodo.net.au/~urantiacjd/h26.pdf
ctan13
Malaysia
Re: dodgey idle Mon, 13 September 2004 05:15 Go to previous messageGo to next message
dingaling, yes ... will wait for the picture. thanks for the link ... will certainly read it up.
dingaling
tas
Re: dodgey idle Mon, 13 September 2004 10:46 Go to previous messageGo to next message
had to look hard on the toymod forums to find a pic to use. Don't sue me whoever took this pic, it's for educational purposes Razz
http://members.dodo.net.au/~urantiacjd/isc.jpg
ctan13: ok it's hard to tell from that picture, but the Idle Speed Controller is under the throtle body, it has a few pipes going into it. Someone here might know a simple way to test that it works properly. I'd take it out and check that it's not jammed up etc.
ctan13
Malaysia
Re: dodgey idle Tue, 14 September 2004 01:09 Go to previous messageGo to next message
dingaling, thanks for the pic. Should the inlet on the ISC, below the two connecting to the map sensor, be completely blocked or connected to something?
I was fumbling around that area last evening and something dropped into the engine bay and I can't find what it was. When I restarted the engine, the rpm shot to 3500 and stayed there. When I blocked the inlet, the rpm returned to "normal" - so I know something used to be connected to this inlet. This morning, I found that my idle speed after warming up has dropped to 600! What should be connected to this inlet or where should it be connected to?
dingaling
tas
Re: dodgey idle Tue, 14 September 2004 03:00 Go to previous messageGo to next message
Do you have a digital camera? sounds like you have a hose disconnected, and you dropped a hose clamp in the engine bay somewhere.
The ISC would stay shut when there is no big electrical loads on the alternator, and when the voltage drops the ISC opens to stablize voltage, and thus increase RPM by letting more air in.
Toobs
Re: dodgey idle Tue, 14 September 2004 03:46 Go to previous messageGo to next message
It could also be your throttle position sensor (TPS).
My 3TGTE used to idle like a bitch when the TPS connector fell off Sad
Corona RT142
Campbelltown
Re: dodgey idle Wed, 15 September 2004 03:48 Go to previous messageGo to next message
My corona was idling like shit so I just adjusted it up to 1000rpm it will idle okay at 800 but occasionally stutters and drops down.
When I pump the brakes in my car when stationary the car will start to rev at 1200rpm, quite funny.
ctan13
Malaysia
Re: dodgey idle Thu, 16 September 2004 01:12 Go to previous messageGo to next message
Hi all,
I finally found an image of the TB somewhere from this forum that shows the vacuum inlet I was talking about ...
http://home.swiftdsl.com.au/~benl1981/corolla/Throttle%20body%20pics/tbAE95.jpg
That's the one on the lowest right with the big red circle. Anyone knows where this inlet should be connected to? On my engine, the other two reds goes to the MAP sensor.
terrykoun
Re: dodgey idle Thu, 16 September 2004 01:14 Go to previous messageGo to next message
yer this sounds familiar.....
My brothers 86 sx celica 3sge has the exact same problem. Happens on and off for the last like 2 years. So i guess its not uncommon.
DunkyMonkey
Brissy QLD
Re: dodgey idle Thu, 16 September 2004 01:33 Go to previous messageGo to next message
ummm okay everyone i just found that this post of mine showed up again, its sounds like a common problem, remember my map sensor has just been replaced, however yesterday i noticed that the throattle didn't spring all the way back immidately when you play with it, i sprayed some WD40 on its, and its cleaned up this a bit, i also brought some tune up oil additive that is suppose to re lubricate the valve springs and all that fun stuff its seems to be more stable at idle but i still have little bit of a uneven idle but its doesn't seem quite so sereve now.
acouple of weeks i ran some injector cleaner, its all good now the engine sounds cleaner, ~intake got alittle louder, when it was suppose to get quiter, oh well so it sounds like my car is moving.
might i suggest to ppl that if the idle seems alittle dodgey get some stuff thru the engine and clean it out, at minimum it will rule it out as the problem.
Regards Duncan
b1gb3n
south Melbourne/KL
Re: dodgey idle Thu, 16 September 2004 05:21 Go to previous messageGo to next message
ctan13 wrote on Sun, 12 September 2004 17:23
Hi guys,
Any ideas anyone?
PPl, this guy is running a 4age, not a 3sge. just pointin out just incase u guys r leading him the wrong direction
DunkyMonkey
Brissy QLD
Re: dodgey idle Thu, 16 September 2004 13:27 Go to previous messageGo to next message
yeah well the original post was made by me, and was in regards to a 5SFE.
b1gb3n
south Melbourne/KL
Re: dodgey idle Thu, 16 September 2004 14:01 Go to previous messageGo to next message
yea. just didnt want the 4age dude to get wrong info. anyway, did u try cleaning throttle body? My guess is that problem
ctan13
Malaysia
Re: dodgey idle Fri, 17 September 2004 00:08 Go to previous messageGo to next message
ok guys ... I'm here to learn and I appreciate all the help and suggestions I have been getting so far from all of you.
b1gb3n, that could be a possible area, besides the ISC. Btw, no one has yet replied to my question with the image - where should that host connect to? There always a vacuum action there, with a cold or hot engine.
dingaling
tas
Re: dodgey idle Fri, 17 September 2004 00:15 Go to previous messageGo to next message
yeah i know he has a 4age, but the Things i told him are quite genaral and in the same place. (ISC) and 4age has TVIS too.
Anyway Can anybody help the man with that pipe connection? the one circled in red? I don't have the car here to look at, or the servive manual.
ctan13: are you sure you can't find a stray hose that fits that pipe? I'll have a look this weekend when my friend comes around with his car to see where that pipe connects to.
b1gb3n
south Melbourne/KL
Re: dodgey idle Fri, 17 September 2004 01:11 Go to previous messageGo to next message
i'll have a look at that pipe too on my car tonight if possible. goin mini cruise with few friends. Bound to check out each others engine bay!!
DunkyMonkey
Brissy QLD
Re: dodgey idle Fri, 17 September 2004 12:12 Go to previous messageGo to next message
damn it no matter what i do to the car it will fix it for a little while then go back its usual self, its less serve at the moment for now.
Rusty1
Tom Price
Re: dodgey idle Fri, 17 September 2004 19:38 Go to previous messageGo to next message
On some celica's that i have come across with aircon's, there is no idle up solenoid for when the aircon is on, more load on the engine, no idle up causes less revs, fitting an after market solenoid for the aircon idleup usually fixes the problem.
DunkyMonkey
Brissy QLD
Re: dodgey idle Sat, 18 September 2004 03:31 Go to previous message
yep mine idles up, however my aircon doesn't work now i think it need to be regased or i need to replace some things, all the aircon units are in the front of the car right? i might be able to install the ST202's aircon unit when i get the front cut.
Previous Topic:Lowering AE92
Next Topic:running on
Current Time: Sat Nov 21 03:04:51 UTC 2026
Total time taken to generate the page: 0.009533166885376 seconds
